Low disk space
My C drive has only 2.92 GB of total size instead of 35 GB and my E drive which was my dvd rom now has the 35 GB from C drive.I have an Acer SA80 desktop how can I fix the problem
  • sacron Apr 27, 2008
    dilipdagdi,still have same problem C drive total size 2.92 GB free space 643 MB. My E drive used to be in (devices with removeable storage) which was my dvd - rom drive now its in with (hard disk drives)is there a way to total wipe my C drive clean (free program on the net) and start fresh or how to get my E drive drive back to its proper location in (devices with removeable storage) any help will be regateful
    President:
  • 1,257 Answers
Just go to desktop > click start button at taskbar > all program > accessories > system tools > and now select the application Disk Clean up .when the application starts delete the files that you dont need.....
low feed backs hurt my ratings and I am tring to help you with your problem,so let me know that the information i given you is helpfull or not
Regards :
dilipbagdi
Technical Associate
Posted on Apr 26, 2008
When requested to install told that not enough space on hard drive 39111 MB required and I have 32GB. Documentation on box indicates 4 GB of disk space required not 40 GB. Configuration data file on DVD...
It may need additional temporary space. Now you say you
have 32 GB and it requires 39 GB. That's 39 GB- 4 GB= 35
leaving a 3 GB play room. Too close for comfort. Eliminate
those videos of the dog and cat playing, and you'll have tons
of space.
Nov 04, 2013 | Square Enix Video Game Consoles & Games
File size limit for Buffalo HD 250 GB Hard Drive backup
The file is too large meaning that the size of that SINGLE file is too large. Your hard disk is probably formatted to a FAT32 file system, this results in a maximum of 4gb PER FILE maximum transfer. What you could do is archive it into a few parts using winrar and then moving it onto the disk, and when you need the file just extract the archive. Your problem isn't the total free space, it's the size of that file chunk.
Nov 03, 2012 | Buffalo Technology 250GB USB SATA 2.0 HD...
Hi, I have WD 1TB Elements SE. When I checked the usage space on the partition after I plug in the drive, it shows a total capacity as 1,000,200,990,720 bytes (931 GB) and it shows 921,753,505,792 bytes...
If you have a 32bit system, it is expected to have miscalculations, a 32 bits can only go up to 4Gb for calculations (that is, 2^32 = 4'294'967'296 bytes) a 64bit system can make calculations to 2^64 bytes this is also why you couldn't copy a file larger than 4Gb in a 32bit operating system...
So, if you are running a 32bit OS, you should expect a discrepancy for the total space of the Hard Drive and the amount it shows (that's the 93Gb you are missing as total capacity).
Another reason why it can show you incorrect calculations are damaged sectors on the hard drive it-self. These will present themselves either as occupied memory or missing memory.
So, you should expect some miss calculations and you can expect some damaged sectors on the hard disk (a external drive spins on and off too often, eventually damaging sectors... its a problem of physical drives).
In the end, your disk might be fragmented, so run a disk analysis and a defragmentation on the disk so it can recalculate.
A note: A disk is like a shelve, you put things where there is space, if you remove things, that space will be open, and if you want to put something there it has to be the exact size or small enough to fit there. This effect, when things are small enough leaves blank spaces unusable, consuming space on the hard drive and making the access of files slower, this is fragmentation. In order to expand your disk life expectancy you should run defragmentations...
To run a defragmentation, go to START, write "Disk Defragmenter", choose your disk and run and analysis and defragmentation.
Jun 24, 2011 | Western Digital Wd Elements Se 1tb...
MY HARD DISK TAKING SPACE 35 GB ONLY FOR OPERATING SYSTEM
If you have windows 7, the size should be around 15 GB. More space can be taken up by updates and system restore points created by updates and software/driver installations. You can try running disk cleanup to see if this is the case or not.
Regards,
katharsys_i
Mar 06, 2011 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Hello. I just want to know how many gigs of space do all external LG CD-ROM hard drives have?
All full size CD-ROM disks should hold .680 GB of data.
That's *POINT* 680, or 680 MEGA bytes, which is LESS than 1 GB.
The capacity of some CD-ROMs may be slightly more 700MB or so (the capacity is usually stamped on the label), and of course the mini CD-ROM disks hold significantly less.
Sep 24, 2009 | LG (GCR-8523BB) Internal 52x CD-ROM Drive
Long periods of hard drive activity
Most likely, it could be the amount of ram you have in your computer. If your running low on ram and it is using the virtual memory your computer can be running all the time causing a slow down in whatever you do. Check to see how much ram you have :)
Mar 24, 2009 | Computers & Internet
Maximum size of hard disk supported
Hi Bijay.
Neither is at fault. Please click on this Seagate link:
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=How_To_Install_and_Troubleshoot_ATA_Hard_Drives&vgnextoid=559e5b1142aec010VgnVCM100000dd04090aRCRD
Scroll down to: Partitioning the drive in Windows XP / Windows 2000 (for systems where this is the 2nd drive in the system).
Follow the instruction on the web site.
This Seagate web site will help you setup the Seagate 160 drive.
If you feel the drive is still at fault you can run Seagate’s SeaTools. Click on the next link:
http://www.seagate.com/www/en-us/support/downloads/seatools
This software will check the 160GB drive.
(Follow the online instructions for), SeaTools for DOS.
In a Windows XP system & using a FAT 32 & a cluster size of 16kb instead of NTFS. Windows will see the total size of the drive but can only access 149GB of drive space. 11GB of drive space will be used by the FAT. File Allocation Table. The FAT is windows guide to every cluster on the drive.
XP uses NTFS & sets each cluster to 4kb. This 4kb size lowers the total usable GB size & uses more GB's for the FAT. You're 127GB size may be correct for a Win XP system using a NTFS file system. The FAT is using 33GB of drive space as a locator for every cluster on the 160GB drive.
Help with understanding the NTFS file system: http://www.microsoft.com/windowsxp/using/setup/expert/russel_october01.mspx
Bijay if you are still having trouble understanding please post any questions here.
Mike
Aug 12, 2008 | Intel D845GLLY Motherboard
HARD DISK CAPACITY PROBLEM
When your hard disk capacity says 320, that does not mean 320 GB fo free space, Total capacity is 320 GB, from this space required for the partition table, boot sector, etc will be taken, Dont worry only the available free space will be shown.
This is not a problem, so dont worry.
Dont forget to rate me fixya
Jan 10, 2008 | Computers & Internet
Verbatim usb drive 8 gb help
Microsoft Windows 2000 help Processor:, Intel Pentium 133 MHz or equivalent 8 CPUs Supported. Memory:, 256 MB. Drives:, 1.0 GB Disk space CD-ROM / DVD drive ...
Computer questions and answers listing 200 - 299 CH000273, Not able to see over 8.4GB hard drive. CH000274, Not able to see or boot with hard drive over 33.8GB. CH000275, Unable to see over 8GB with ...
Good Luck, Please dont for get to Vote, Thank You.
Dec 20, 2007 | Verbatim STORE-N-GO (95312) 8 GB Hard...
Computers & Internet Logo
142 people viewed this question
David Payne
David Payne
