Question about TruTech TT1620 DVD Recorder
No disc DVD+RW - when I put in the dvd it trys to load and finally says no disc
  • 7 more comments
  • Anonymous Oct 28, 2008
    what name brand of dvd will it read. i have tryed - an + rw and it still it want read. it keep saying no disc;
  • bd26162000 Oct 28, 2008
    what name brand did it take.
  • ski11120 Dec 29, 2008
    I put a recorded disk in the machine and it tells me there is no disk.
  • Chuck Doherty Feb 21, 2009
    recorder worked for 3 years using TDK DVD+R discs, but now keeps saying NO disc even on discs I recorded on this machine and also new discs trying to format. Keeps saying NO disc
  • yellerpaws Mar 15, 2009
    Any disk I put in it says "NO DISC". I have tried all compatible disks.
  • Anonymous Mar 31, 2009
    no disk found if i started and stop maybe 30 times it might work and keep working I have only recorded about 15 disks about 30hr.
    opened unit and disk is not turning motor bad ???
  • byronhd Apr 05, 2009
    My trutech sais no disc and will only play store bought DVDs
  • Anonymous Mar 25, 2014
    Load the DVD and it says NO DISC
    Load the DVD, it says NO DISC
  • 975 Answers
With these types of DVD RECORDER unit ,you have to purchase a specific DVD+RW brand so the system can accepted . I have this problem once , I ended returning the unit and getting a DVD RECORDER that will be compatible for all DVD players . Like the PANASONIC DMR-EZ27 ,hope this info helps you.
Posted on Apr 26, 2008
Insert disk all i get i load then it eject disk
Well it seems that your DVD player is having an issue reading the disc, I guess the first question is what kind of disc are you trying to insert? Is it a burned DVD or is it a movie dvd? This model is not a Blu Ray so if you are trying to use a Blu Ray disc then it will not read it. If you are trying to read a burned disc from someone then more then likely the disc was not finalized and is unable to recognize the disc, because the finalization process is where all the the information is written about what kind of disc it is and the format, codecs, etc. OR maybe the laser is dirty or the DVD player has kicked the bucket. Finally, the product DESC says it can read DVD-RAM, DVD-RW, DVD-R, DVD+RW, DVD+R, VHS formats, but I have found that some DVD units do not like certain brands of Blank DVDs. I hope this offers some ideas for you and good luck!
Oct 29, 2013 | Samsung DVD-VR357
When I put a DVD+RW disk in trys to format the disk then says the disk is protected. If I open and close the door it trys to format the disk again
It may be the brand of disc you are using. Have you tried any other brands? Have you tried DVD-RW? Might make a difference. I'm using DVD-RW and most of them work flawlesly.
Dec 09, 2010 | Sony RDR-GX355
CAN RECORD FROM VCR TO DVD+R, CAN PLAY DVD ON SAME, BUT CANNOT PLAY ON OTHER DISC PLAYERS. I THINK THAT THIS IS BECAUSE I AM NOT FINALIZING CORRECTLY. WHEN AND HOW DO I FINALIZE A NEWLY RECORDED DISC?...
Usually you finalize the disc after loading it with all the desired content (leaving a bit of space for the finalization). So if you are recording a TV show, depending on the setting (SP, LP, XP), you might finalize the disc after recording 4 1/2 shows. The How may vary by model but on my DVD recorder, I find the finalize command in the same menu area as adding a title and initializing a DVD-RW disc. So I press Setup to enter the OSD menu, then go down to Disc (looks like an optical disc) then right arrow to enter the sub menu. Then press down to Disc Finalize and the right arrow again and press enter. Select OK and Enter again. (RW discs can be unfinalized to add more content.) Then wait until the process is done.
I hope this helps.
Jul 09, 2010 | Philips Magnavox DVD/VCR Dual Player
Sony handycam dcr-dvd105 + vista mini discs need software or driver???
You need to finalize dvd disc and then this can be playback in computer or dvd player.
When disc is completed or full with data, there is an option in camera menu to finalize it.
Need further info or help, let me know.
Oct 22, 2008 | Sony Cameras
About finalizing
Once a DVD+R or DVD-R has been finalized, it cannot be edited again. You are stuck with whatever you have. On the other hand, you have to finalize the disc to make it playable on other DVD players.
The exceptions are DVD+RW, which, according to the manual, does not have to be finalized, and DVD-RW, which you can "Undo Finalize" in the "SETUP/Disk Edit" Menu
Aug 16, 2008 | Philips Magnavox MWR10D6 DVD Recorder
The magnavox zc320mw8 will not finalize a dvd for playback on anther dvd player
Try this. Insert DVD. Press SETUP button. Once DVD has loaded the DISK FINALIZE option will be available. You can then FINALIZE.
Jun 24, 2008 | Philips Magnavox DVD/VCR Dual Player
Presidian 3222
I don't know if this will help, but according to the operator's manual I have, on page 64, the only place it mentions "Full" or "Quick" Preparation, is when using a DVD-RW disc. Apparently, with this type of disc, you must use the Full or Quick preparation INSTEAD of Finalizing after you're thru recording onto the disc.
With the DVD-R and DVD+R, all you can do is "Finalize"; With the DVD+RW, if I'm reading this correctly, NIETHER Finalization OR Preparation is required.
But with the DVD-RW, apparently ALL you can do is a "FULL" or "QUICK Preparation.
If you're only getting "Erase or "Finalize" WITH the DVD-RW, then it appears there may be a problem with the machine.
Or, if you're attempting the "FULL or QUICK" Preparation with any disc OTHER than the DVD-RW, all you should get is "erase" or Finalize", since the QUICK or FULL Preparation is not done with discs other than DVD-RWs.
Hope this helps. I'm certainly not an expert on these things....I'm a "Vinyl" type guy.
Roy Davis
May 31, 2008 | Dual Presidian DVD Recorder
Recording problem
I have had two of these recorders, Using only Sony + discs or rewriteables is my solution, I will not use any thing else. It may work 1-3 times on others brands then start throwing coasters.
As to renaming, on my model I pull up the tiltle menu then select Try using rewriteables for the other problem as well My model is a little older and lets me take disc out without finalizing then when inserting select title, hit edit on remote and select rename. Maybe if you can skip the finalizing (as with rewritables it will help
Apr 01, 2008 | iLO DVDR05 DVD Recorder
Samsung R155 Recording from VHS Issues
The reason why you are having this problem is because you haven't finalized the disc. In able for you to play that Burned DVD that you have you need to Finalized the disc. Finalizing a recordable optical disc means writing the disc's lead-in (the Table of Contents or TOC) and lead-out information (blank data that fills up the unused space at the end of the disc) so that a DVD player will know where the various tracks begin and end. Without the TOC, a conventional DVD player will not be able to read the contents of the disc. Once the disc is finalized, no more information can be written to it. Finalizing takes about two or three minutes. To finalize a DVD-RW/DVD-R: 1. Press the Menu button with the disc stopped. 2. Select Disc Manager and press Enter or the right arrow. 3. Select Disc Finalize and press Enter or the right arrow. You will be asked twice if you are sure that you want to finalize the disc. Select Yes and press Enter. Once the disc is finalized, you cannot delete entries from the record list. After being finalized, the DVD-R/DVD-RW (video mode) operates in the same manner as a DVD-Video. Recorded discs must be finalized in order to play back in non-Samsung DVD players. A DVD-RW disc that has been recorded by DAO (disk-at-once mode) in a PC cannot be unfinalized. A DVD-RW disc that has been recorded in Video Mode on a non-Samsung recorder cannot be unfinalized by a Samsung recorder. A DVD-R disc cannot be unfinalized. Note: Finalization does not apply to DVD-RAM. If you cannot finalize a DVD-R or DVD-RW disc, make sure that Disc Protection is turned off. If you are still having difficulty, you may try calling technical support of SAMSUNG. Note: Do not turn the recorder off while it is finalizing the disc. Data on the disc will be damaged if the finalization process is interrupted.
Sep 17, 2007 | Samsung DVD-R155
Loading DVD-RW discs
My recorder has stopped accepting NEW DVD-RW discs and ejects them.
There is no problem loading DVD-R (new or recorded)or loading previous recorded DVD-RW, initializing and re-recording
I have tried several different DVD-RW makes. Puzzling??
Nov 03, 2006 | Pioneer DVR-5100H DVD Recorder
TruTech TT1620 DVD Recorder Logo
394 people viewed this question
Top TruTech Televison & Video Experts
Jason Morris
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
