Question about Mtd Yard - Man 160cc, 21" Self - Propelled Lawn Mower
Mower will only run in choke position - Mtd Yard - Man 160cc, 21" Self - Propelled Lawn Mower
  • 755 Answers
Partially obstructed main jet. Remove carb bowl and clean main jet with small strand of wire. Drain carb bowl and clean out any dirt or rust.
Good luck and be careful.
Posted on Aug 04, 2010
How to determine the on position for the choke on snowblower
if the choke is pushed in the butterfly should be all the way open. when the choke is pulled then it will close the butterfly to choke it making it run on less air and more gas till it starts.
Dec 11, 2016 | Garden
What is the running position for the choke lever on my Briggs Stratton 35 classic engin
on the oldie but goodie briggs engines it's easy to look right down the air intake collar while its running and see the choke plate , straight up is the run position
Aug 27, 2015 | Garden
Lx176wont runs on choke only
Gas cap vent could be plugged. clear it up or replace the gas cap.
Oct 19, 2014 | John Deere Garden
How do you start it?
what kind of mower is it?
For any mower you need to check that you have proper oil level, and that there is gas in the tank. If it is a riding mower there are a few things to know before you start. There are safety interlocks that have to be complied with before a start is permitted. The blades must not be engaged. Someone must be in the seat, and the brake must be fully engaged. Move the throttle to choke for starting (or pull the cable out if that be the case), start mower. Return choke to normal operating position.
For a push mower check your oil and fuel. Prime the carb. if necessary, push the button by the carb. until you are pushing fuel and then a couple more times. If it has a throttle cable put in choke position. Pull back on the safety bar. Pull cord to start. Throttle cable to normal running position, generally full throttle right before you start to engage the choke.
I hope this helps, if any questions just reply. Be sure you let me know what you did and what kind of machine it is.
If this is really helpful, please rate.
Jul 13, 2011 | Garden
Tractor only runs with choke on , stalls when you take choke off
The choke cable needs adjusting. There is a strap holding the sleeve on the carb. loosen it and adjust the choke position, then tighten it up again.
Thats it
Mike
Aug 30, 2010 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Qualcast petrol 35s mower will only operate with choke fully open, closing the choke causes the engine to cut out. Mower has been operating fine until now following a full service. What is the likely...
The chole is only ment to be used to prime the engine on cold start up, the engine is supposed to be run with the choke in the normally open position.
Aug 10, 2010 | Garden
New honda hrr auto choke hard to start
sounds like it may need the carb clening out, but it could be the auto choke not closing when cold. there was an issue with some of the early auto chokes on the gcv135/160 engines so check to see if the choke flap is in the closed position when starting from cold, run the engine for approx 10-15 minutes and see if the choke flap has opened fully.leave it to go cold and see if the choke flap has returned to the closed position
Apr 12, 2010 | Husqvarna 160 CC Honda OHC Engine 21 in
I have trouble initially starting my MTD Yardbug mower. Once going, the engine runs great, but it seems like when the throttle lever is set to choke, it doesn't actually choke. I usually have to either...
Sounds like your throttle cable is out of adjustment (i.e. when you put the carb in choke position is doesn't actually go into choke).
Aug 24, 2009 | Garden
Forgot which position switches should be and choke on/off position
choke on when starting one pull or two choke off when running. line up/ down is full choke , slant line is no choke.
Apr 22, 2009 | Garden
Sputters & quits at proper RPM for engaging trans or mowing deck
If the choke has an adjustment point, then adjust the choke to a good overall working powerband. If it still doesn't act correctly, look for vacuum leaks. If it is an option, you may want to install a manually operated choke lever.
Nov 23, 2008 | Garden
Mtd Yard - Man 160cc, 21" Self - Propelled Lawn Mower Logo
214 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
