Problem: Konica 7022 Call for Service..F-51-5..Help pls..
SOURCE: error code f-35-8
Ensure there is no jam in the fusing unit. Turn copier off. Turn the copier back on while pressing down on the 2 and 5 keys. Select 1, the software switch settings. Using the arrows on the touchscreen, select dipswitch 3-1. Touch the off key. Press return, then turn the copier off and back on. If the code returns, you may have to replace the temperature sensors in the fusing unit.
Posted on May 20, 2008
  • 18 Answers
SOURCE: error code f35 konica 7022
Turn on the main and sub power switches.
Keep pressing the
* button until the message
“Please enter service password.” appears.
Input 9272 as the password and press the
[Start] key. (The password is fixed and cannot
be changed.)
[Mode Select Menu Screen]
Press the key of the mode to be selected on the
screen. To return to the Mode Change Menu
Screen, keep pressing the
* button until the
screen appears.
When the adjustment ends, press
[1. Normal Mode] key and the basic screen will appear
Posted on Jul 16, 2008
  • 87 Answers
SOURCE: Konika 7022 copier F 51-6
That is for laser motor problem.just check it .check its supply or replace it.code will bi removed.MIAN AKHLAQ
Posted on Jan 03, 2009
firecontrol7
  • 6696 Answers
SOURCE: Replaced Konica 7022 toner and add toner light stays on
Remove the toner bottle carefully, pwr off and unplug the machine , then plug it in and turn it on do not put toner bottle into machine until asked for.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Jul 13, 2009
firecontrol7
  • 6696 Answers
SOURCE: Konica 7022 with Problem code F-26-1
There is toner/starter spilled onto a sensor near the drum, it mite just need to be cleaned, this sensor monitors the drums abililty to develope a image, if the cleaning does not work it mite be the sensor or the drum. The drum needs to be removed to clean the sensors.
Posted on Aug 01, 2009
Konica 7022 26-3
Yes I stated what I recommended to do in your last post!
Jul 12, 2014 | Konica Minolta 7020 7022 7025 Copier Drum...
Konica 7040 trouble code 51-4
This 51-4 code is directly related to the write unit. It can either be a bad lazer index control board mounted externally to the side of the write unit or a bad M5 polygon motor. It is better to replace the whole write unit. Konica P# 26WA-6500.
On a side note, the 7020 write unit can be used in place of the 7022 write unit & is far less prone to failure then the 7022 write unit! 7020 write unit Konica P# 26NA-6500.
Nov 07, 2012 | Konica Minolta Copier Toner 7033/7040...
I have a Konica Minolta 7022 printer, scanner, fax, and copier machine. How do I get it to scan?
Please see this website complete manual for Konica MInolta 7022 printer I think i can help your problem
http://help.nceas.ucsb.edu/images/2/2a/Konica.pdf
Thanks
May 10, 2011 | Konica Minolta Office Equipment & Supplies
I have a konica 7022, it says call for service code F-35-3. what's wrong with it. please help me.
Fixing upper roller low temperature error.Verify the continuity the heater lamps and remove and clean the thermofuse.If the thermofuse not working change it.
Sep 25, 2009 | Konica Minolta Office Equipment & Supplies
Jun 30, 2009 | Konica Minolta Office Equipment & Supplies
Mar 23, 2009 | Konica Minolta Office Equipment & Supplies
Konica 7022 (code F-26-1) Pls call service 0870-2425050)
i have a konica 7022 it say call service code F-35-3, what's wrong with it, help me.
Mar 21, 2009 | Toshiba 2060 Copier
Error code f-51-6
this is your WRITE UNIT CODE.''''PRIT HEAD''''
you chould try to reseat all connectors ,and especially the write unit ,how handy are you?????
let me know
Oct 23, 2008 | Konica Minolta Di1610 Copier
Konica 7033 error code F-51-4
my machine incounter problem F 51 - 4 KONICA 7040 ,pls help to solve this problem.I already done checking the drum cart.
Sep 18, 2008 | Office Equipment & Supplies
225 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
