Question about Maytag Refrigerators
Our Maytag refrigerator model MSD2542VEW01, ice dispenser is not working. The motor works but something is broken in the opening that allows the ice to come out.
the dr
  • 447 Answers
SOURCE: ice and water dispenser for Maytag H20 not working
You need a new high voltage control board. Ive had at least 10 do this.
Posted on Oct 05, 2007
SOURCE: Maytag Ice20 refrigerator
There's a very detailed guide explaining how to fix this yourself for about $5 in parts. Some basic experience with soldering is helpful.
My Maytag dealer did not offer to fix for free, so I resorted to doing it myself rather than spend $300-$400.
http://www.liny.net/MaytagIce2O.htm
Posted on Jan 30, 2008
  • 54 Answers
SOURCE: Broken ice maker in a GE side by side refrigerator
Most of the time the spring just pops out of the keeper on the ice maker, If you push the feeler arm back and it does not come back out on its own then the spring has poped off. Look where the feeler arm attaches to the ice maker and there is a round spring between the feeler arm and the icemaker housing. There is one hole in the feeler arm ans one on the ice maker housing that the spring pops into. Its usually the spring is out of the hole on the ice maker housing.
Posted on Jul 03, 2008
  • 36 Answers
SOURCE: Kenmore Elite refrigerator ice and water dispensers not working
check for a child lockout button it will look like a tiny padlock ,press and hold for 3 sec.(could be the freezer door light switch)
Posted on Jul 24, 2009
SOURCE: lights on panel blinking. ice dispenser keeps opening and closing
there is the HV board on the back under a cover . 2 680uf capacitors @ 35v are likely domed instead of flat on the top and are likely hot. replacing these with an equal value will cure the problem. they are in parallel so 1000 and 470uf will cure it. mine was same model except white. local dealer said no warranty. did not call maytag but he indicated it might help. good luck
Posted on Jun 02, 2010
Icemaker is making ice but will not dispense. continues to accumulate then over time ice in the bottom of the dispenser will freeze
I can think of two possible problems. The ice has frozen together and will not allow the ice screw to push the ice out the dispenser. Or the motor for the ice screw is broken.
1. Shut off icemaker with lever at icemaker
2. Remove ice container (either throw away ice or save in another container).
3. Put back empty ice container.
4. Leave ice maker off for about an hour.
5. After an hour , check if motor is working by trying to dispense ice. You should not expect any ice but you should hear the motor /auger moving.
A) If you do not hear any thing , you need to get your motor replaced.
B) If you hear the motor , mostlikely you had an ice dam which prevented the ice dispense from working..You can turn you icemaker on.
Oct 15, 2015 | Whirlpool Refrigerators
Frost builds up on the chute betwen the icemaker and the door dispenser unit.
I need you to confirm your model number. Is MZD2665HE correct? The problem is very likely a broken 12565502 Dispenser Door Spring or more providing you have the correct model number. There may be a kit if the model number is different.Thanks, John Tripp Appliance 911
Jan 31, 2014 | Maytag MZD2665HE Side by Side Refrigerator
Ice maker not working
Ice makers have a heating element to thaw the inlet and allow water to flow into them perhaps the heater is broken and it can't get water to make ice. Check the hopper to be sure it has ice in it. If it does check it for obstructions from the hopper to the door.
Apr 04, 2012 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a Maytag MSD2542VEW01 side-by-side. The door for the ice dispenser hangs open. How do I find out what's wrong and how do I fix it?
efeca318-e2b8-4558-9143-e4e40ef73b8e.jpg7f1d6c51-7f98-427a-86dc-9552b164533a.jpgI had the same issue. Mine was due to a broken plastic piece that holds the flapper. In my case it looks like there is not a easy fix. Take it apart and check for missing peices
Aug 03, 2011 | Maytag MSD2542VE Side by Side Refrigerator
Ice maker dispenser is not functioning (crushed or cubed), Ice maker makes ice but does not dispense, motor seems to be frozen. Kenmore Elite 106.57703701 model refrigerator
Open the door and hold the door switch down and try the ice dispenser. Do you hear any thing.You should hear the ice door open and the augur motor turning to turn the augur which pushes the ice out the door. If the augur doesn't turn Take all the ice out of the bin and try. perhaps the motor is too weak or the augur is locked up. Take the bin out and try to see if the motor will turn with no load. The motor is behind the back cover where the bin sits. See if you get power to it using a voltmeter when you try the dispenser. If you are, probably bad motor. If not ,dispenser switch or solenoid is not working.
There is a solenoid that operates the door that could have stopped working. Can you hear it?
The hinge on the door could be broken or the bracket it goes in could be broken. You'll have to look to see what's wrong.
Remove the dispenser cover by gently prying starting at the bottom going round and round a little at a time to prevent from breaking it. When it's off the screws will be exposed to access the other components.
Dec 01, 2010 | Refrigerators
MAYTAG Model MSD2656KES: The refrigerator works
Sounds like the control module is u/s or the motor is u/s. Try switching off and on at the mains. If this does not cure it then you can try to unplug and plug back the ice motor, if you have access to it, if not call service engineer.
Aug 28, 2009 | Maytag Refrigerators
My maytag MSD2556ae side by side refrigerator water/ice dispenser may be locked. Is there a method or code to unlock. The water dispenser started shooting water out with no warning and the dispenser light...
I have a Maytag model 2556 AE refridgerator. The ice maker works but the ice and water dispenser, the light and everything else on the front of the unit doesn't work. Is there a fuse that operates this or is there other problems? Thank you Bob
Jun 10, 2009 | Maytag Dual Cool 25 cu. ft. Side-by-Side...
Ice maker dispenser
i own a similar model for 2 years now and have had no problems with it. maytag is better than kenmore sad to say
Jan 13, 2008 | Maytag MFI2568AE Side by Side French Door...
Refrigerators Logo
87 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
