Question about Garden
Where can i found an operating manual for my Hein- Werner Model J-10 Push and Pull Hydraulic Jack with serial # 7650 B...i have acquired this tool to a steel company 5 years ago...and still this is still good...i want to explore or maximize its use so it could greatly help my workers in their daily shop works using the different attachment in the kit...can you help and email to me this operating manual..thanks and good day.
  • 10865 Answers
SOURCE: My saw starts fine, runs great for about 5-10
Hello. Check the filter in the bottom of the fuel tank, I am betting that it is partially gummed up and restricting the flow of fuel. Regards, Joe
Posted on Jan 05, 2010
  • 324 Answers
SOURCE: I have a motorcycle and
craftsman tools are supposed to have a lifetime warranty, take it back and throw a fit, they will replace it
Posted on Sep 12, 2010
J-Chris Ward
  • 731 Answers
SOURCE: Hi I'm looking for a service manual for a Hein
Here a site you are looking for.http://www.ohiohydraulic.com/hein-werner%20drawing%20page.htm
http://www.ohiohydraulic.com/hein-werner/WS.pdf
Posted on Feb 15, 2011
dleemacc
  • 281 Answers
SOURCE: have had this rotary tool
You dont give model so that makes kinda hard.Some take a small wrench and button on the nose that you put pressure untill a pin drops in as you turn the chuck and locks it.There is another one that has a hole that lines up with anouhher hole and you put the spindle of a tool through both of the holes to lock the jaws and use a small wrench untighten or tighten as needed.some take little furls that go in side the chunk and tighten down. If it's not one of these then send the model number and I'll see what I can do.
Posted on May 30, 2011
  • 10865 Answers
SOURCE: I need a manual for
hello aru.... here are the schematics for this saw, and the parts lists.
http://www.searspartsdirect.com/partsdirect/part-model/Pro-tech-Parts/Saw-Parts/Model-3303/3073/0744440
Joe
Posted on Jun 25, 2011
I have a 2007 mustang convertible top that will not go down. with key on windows go to park down position but no hydraulic pump sound checking fuses to ensure good power. where should i begin?
Principles of Operation
Convertible top operation is controlled by the smart junction box (SJB). When the convertible top raise/lower switch is operated, the SJB commands the front and rear windows to the full down position. Window operation is disabled while the convertible top raise/lower switch is being operated. When the SJB receives a full down input for both rear windows, it commands the appropriate relay closed to raise or lower the convertible top. If the SJB does not receive a full down input signal for both rear windows, the convertible top operation is disabled.
The convertible top hydraulic system uses a 12 volt reversible pump and motor assembly. When active, the pump uses hydraulic pressure to extend the hydraulic lift cylinders to raise the convertible top, or retract the hydraulic lift cylinders to lower the convertible top. The convertible top motor/pump assembly is equipped with a thermal circuit breaker. The circuit breaker typically resets after 5 minutes depending on the ambient temperature. The thermal circuit breaker cannot be repaired and must be installed as a unit with the motor/pump assembly. In the event of a hydraulic system failure, the convertible top cannot be operated manually.
Inspection and Verification
  1. Verify the customer concern.
  1. Visually inspect for obvious signs of mechanical or electrical damage.
Visual Inspection Chart Mechanical Electrical
  • Convertible top brackets and frame
  • Convertible top latches
  • Convertible top pump and motor assembly
  • Hydraulic lift cylinders
  • Hydraulic lines
  • Bussed electrical center (BEC) fuse(s):
    • 13 (40A)
    • 51 (10A)
  • Circuitry
  • Convertible top ajar switch
  • Convertible top switch
  • Connector(s)
  • Convertible top raise relay
  • Convertible top lower relay
  • LH or RH rear power window motor
  • Smart junction box (SJB)
  • BEC
  1. If an obvious cause for an observed or reported concern is found, correct the cause (if possible) before proceeding to the next step.
  1. If the cause is not visually evident, connect the scan tool to the data link connector (DLC) and select the vehicle to be tested from the scan tool menu. If the scan tool does not communicate with the vehicle:
    • check that the program card is correctly installed.
    • check the connections to the vehicle.
    • check the ignition switch position.
  1. If the scan tool still does not communicate with the vehicle, refer to the scan tool operating manual.
  1. Carry out the scan tool data link test. If the scan tool responds with:
    • CAN or ISO circuit fault; all electronic control units no response/not equipped, refer to Section 418-00 .
    • No response/not equipped for SJB; refer to Section 419-10 .
    • System passed, retrieve and record the continuous diagnostic trouble codes (DTCs), erase the continuous DTCs, and carry out self-test diagnostics for the SJB.
  1. If the DTCs retrieved are related to the concern, go to the Smart Junction Box (SJB) Diagnostic Trouble Code (DTC) Index.
  1. If no DTCs related to the concern are retrieved, GO to Symptom Chart .
  2. Smart Junction Box (SJB) Diagnostic Trouble Code (DTC) Index DTC Description Source Action B1141 Convertible Top Full Down Position Switch Circuit Failure SJB Go To Pinpoint Test E . B1142 Convertible Top Full Up Position Switch Circuit Failure SJB Go To Pinpoint Test E . B1402 Driver Power Window Down Switch Circuit Failure SJB Go To Pinpoint Test A . B2068 Convertible Top Up Output Circuit Failure SJB Go To Pinpoint Test A . B2069 Convertible Top Down Output Circuit Failure SJB Go To Pinpoint Test A . B2481 Convertible Top Up/Down Switch Fault SJB Go To Pinpoint Test A . B2578 Passenger Power Window Down Switch Circuit Failure SJB Go To Pinpoint Test A . All Other DTCs - SJB Refer to Section 419-10 .
  3. Your best bet ,take it to a qualified repair shop !
Nov 05, 2017 | Cars & Trucks
Hydraulic jack manuals
Look for a rubber or plastic grommet on the cylinder in the jack. That is the fill hole.
Aug 03, 2014 | Hein-Werner Hein Werner HW93642 2 ton...
I need to no how to take my 1994 honda accord transmission down and put back together
If you have Nantes book it will help slot also go to autozone and rent a tranny jack if not u can take a 2/12ton floor jack take a tie down and have someone help balance tranny as u slowly pull it out and lower down also if has quick fit tranny line (white snap ring on end of line securing line into tranny) u can use small flat head screwdriver use litte pressure to push in and pull on line in stead of wasting money on that tool if it's a hydraulic quick connect hope this helps but buy the manual it will help so much for the do it yourself guy
Feb 21, 2013 | 1992 Honda Accord
How to change a Xantia bottom ball joint
Depressurize the hydraulic system. Jack the front and put on jack stands (both left and right side). Remove wheels. Slacken and unscrew the ball joint nut partially. Release ball joint from knuckle using a proper separation tool. Once dislodged, remove ball joint nut and pull out strut/knuckle away from lower arm. You may need to push down the arm with a lever. Remove dust cover from the ball joint. The ball joint can be removed by unscrewing it using a tool that locks into the notches on the sides of the ball joint. Install new one by screwing in the ball joint back into the knuckle.Tighten well.
Sep 01, 2012 | 1998 Citroen Xantia
I just inherited an older 3 ton floor jack. Guardian make, Model 4-102, 3000 lb. capacity. What type of fluyid does it take. who would I contact for repair parts? thanks
It was made by Hein-Werner, Similar to the WS model also 3,000lbs (not 3 tons). Been out of production at least 20 years or more. Guardian was Hein-Werner's cheaper off brand. Kind of a "dumbed-down" version. Also made an H-101 which was similar to H-W OS (O-Boy) model of 2500lbs.
Try a hydraulics dealer who sells Hein Werner parts. although obsolete, about 1/2 the parts are still available.
Lastly: Hydraulic jack oil. Never use brake fluid. Engine oil in a pinch, by I would never do it.
Jun 22, 2011 | Garden
Can you please mail me a user manual ? Best regards Werner
Mr werner, Kindly let me know that if you wish to have a manual to a cell phone kindly let me know the make and model of the cell phone.
Mar 27, 2011 | Cell Phones
How do you fill a ac delco hydraulic 3 ton floor jack model 34123 with hydraulic fluid
DONT KNOW WHO BUILT THIS JACK- AC DELCO JUST PUT STICKERS ON IT. TYPICALLY YOU REMOVE A PLASTIC SCREW IN PLUG OR A POP IN RUBBER STOPPER FROM THE TOPSIDE OF THE CYLINDER. WITH THE JACK ALL THE DOWN, FILL IT COMPLETELY UP AND IT SHOULD WORK. SOMETIMES THEY GET AIR IN THEM - JUST LEAVE THE PLUG OUT AND JACK IT UP A FEW TIMES, THEN INSERT PLUG. USUALLY 10 WEIGHT HYD OIL. OR "JACK OIL" AT THE STORE.
Mar 26, 2009 | Plumbing
Hi i have a 3 ton sears floor jack i can not
I think I have the same jack. Th serial number was on a little sticker that is long gone,but the model number you need might needs is: 875.501390.
Hope this helps.
Gary
Mar 01, 2009 | Plumbing
Garden Logo
78 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
