Question about Honeywell International Heil Quaker Honeywell 1014460 Control Fan Timer
I HAVE A HEIL 5000 A/C CONDENSING UNIT.\r\nCAN YOU TELL ME WHAT SIZE IT IS (TON)? MODEL # CA5560 VKD2 STYLE # 60MCE-000095ZR SERIAL # L9811 50209MANF # NCA5560 VKD2 I APPRECIATE YOUR HELP. THANK YOU VERY MUCH. WAYNE TYLER wtyler1@nctv.com
  • 43,501 Answers
It looks like you have a 60,000 BTU unit or a 5 ton unit...12,000 BTU/ton is how you figure that...
The 60 in the model number indicates the nominal btu's of the unit... the exact output could be a bit more or less depending on the air handler...
heatman101
Posted on Aug 04, 2010
Testimonial: "THAT IS WHAT I WANTED TO KNOW. tHANK YOU VERY MUCH...I HAVE A 31/2 TON EVAP AND WANT TO REPLACE THE COND. GOOD UNIT, WILL IT WORK WITH 31/2 EVAP?"
NEED TO KNOW THE TONNAGE ON THIS UNIT
2 1/2 ton. home is about 1200-1400 square feet ?
Apr 18, 2016 | Ruud Matching Split Air Conditioner
Need Minimum Circuit Ampacity and the Maximum Fuse Breaker for the Condenser - Thak you
Serial numbers don't tell much.
Model. numbers describe the unit best an 18 in the model is for 1 1/2 ton,24=2 ton, 30 =21/2 ton 36=3ton etc
May 02, 2015 | Heating & Cooling
What size is my Heil unit?
look at model no. 24 is 2 ton 36 is 3 42 is 3.5 and 60 is 5 ton
Sep 04, 2014 | Heating & Cooling
What size BTU unit is my Crarrier model 38ck036330 condensing coil ?
The model you gave is for a 3 ton or 36000 BTU unit...that is what the 36 stands for in the model number...
heatman101
Aug 24, 2010 | Carrier Heating & Cooling
Can't identify ton rating of condenser unit
the model number tells me it's a 4 ton. the 048 is what it gives it away. 1 ton is 12,000 btu's . 4 ton is equal to 48,000 btu's
May 23, 2009 | Heating & Cooling
Need to know unit size
ckl60 5 ton about a 2003 model on most ac heat pumps the model number reflects the ton sized by 12000 btus per ton also as for the indoor unit cfm rating 400 cfm per ton
May 14, 2009 | Goodman CKL60AR60 Air Conditioner
A/C Size
This appears to be a 3 ton unit. The number 36 represents 36000 BTU`s. That would be 3 tons.
Nov 10, 2008 | Weather King 10AJA3601AH Air Conditioner
Size
Greetings jdreisbaugh,
The tonnage is usually found on the name plate on the condensing unit outside. 12000 btu = 1 ton, 24000 = 2 ton and so forth. In your case the unit is 36000 btu, therefore a 3 ton.
I hope this helps!
Dorothy
Go Ahead. Use Us.
Jul 24, 2008 | Intertherm P3RA-036K Air Conditioner
Honeywell International Heil Quaker Honeywell 1014460 Control Fan Timer Logo
670 people viewed this question
Top Honeywell International Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Honeywell International Hardware and Accessory Expert? Answer questions, earn points and help others
