Question about GE 29875GE2 Digital Answering Machine
How do you change the number of rings from 4 to more than4?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • GE Master
  • 102,366 Answers
Hold the STOP/SET button for two seconds to enter the change mode. Full details are in the "Changing the Settings" section beginning on page 10 of the manual at
http://www.home-electronics.net/ge/pc/IB/29875GE2_IB.pdf
Posted on Aug 13, 2011
Avaya 18D Change Number of Rings
Programming is done on extension 10 or 11
Press feature 00
Left intercom, Left intercom
#506
mode 1
line 01
number of rings 4
do the same for all lines
Cheers
Apr 13, 2009 | Avaya Corded Phone avaparp18d
I need to change the number of rings before phone goes to voicemail
First, call your voice mail. After the messages you will be given a menu to follow. On the Sony Ericsson W350 I went to Personal Options (4) then to Administrative Options (2) and finally Prompt Level (3). After reaching Prompt Level you have the option to shorten or extend the number of rings. At this point I chose to shorten the prompt and then I exitted the system.
Apr 12, 2009 | Lands Phones
Extensions don't ring
you will need to access system program mode to change ringing inmemory block 4-12
Mar 10, 2009 | NEC DTU 8-1 Corded Phone
Night ring change the number of rings
Auto Attendant
Answer Lines
1 – Feature 983
2 – Log: Dial 1020000 (3-digit DNs) or 120000 (2-digit DNs)
3 – Press AA
4 – Press LINES
5 – Line number: Dial line number (001-xxx).
6 – Line:xxx Ans:No Press CHNG to AA if auto attendant will always answer theline. If a Night Service key will be used to activate auto attendant answering, leave Ans: at No.
7 – If line has been changed to Ans:AA, press * then press TABLE.
8 – If Table:1 is OK press RINGS. (Table 1 is the default greeting table. Change to a different table (1-4) if alternate answering is required on the line being programmed.)
9 – Rings:0 – Press CHNG, dial number of rings before auto attendant answers the line, or leave at 0 for immediate answering. Allow at least 2 rings if CLID is in use.
10 – Repeat for each line to be programmed.
Notes For Night Service Mode Auto Attendant Answering
If the auto attendant will only answer lines in night service mode, line answering should be set to No as per step 6 above. Using night service will cause the AA to answer lines immediately.
Feb 11, 2009 | NorStar M7324 Telephone
Need to program extension to ring on incoming calls
Professional Level 1 programming to make a phone ring on incoming calls:  1. On the phone you want to change ringing, press <FNC> - 4 and the screen will show the port number and the station number. If it doesnt have a display, borrow one and plug it into the cord that is attached to the wall, then do this. The port number is needed since all station programming is port based.
2. From ext. 10 or 11 (or whatever the extension numbers are for ports 01 and 02 are), with the phone idle press ,<FNC>, <HOLD>, #,0,*. The screen should show "PROGRAM MODE".
3. Press Line Key 4, which is the 4th button across the top. Dial "15", screen should show "01 / 15: 12345678" if you're in the right place. In this mode, the * key moves the cursor right, and the # key moves the cursor left. The first two digits are the port you're programming, the next field is the program code, "15"in our case, which is Daytime Ringing, and the last field is the data setting for this port.
4. Move the cursor to the left so you can change the port field to the port number you found in step 1. After changing the port number, move the cursor back to the right to the data field, and press the digits corresponding the the line number you want to ring, e.g. for line 1 press "1", for line 4 press "4". Each digit pressed in this field is a toggle, so if you press "1" when the digit "1" is already displayed, you will turn off ringing.
5. Verify that the display settings are correct. For example, if you want port 04 to ring in day mode on lines 3, 4 and 5, the display should show "04 / 15:   345    ". If all is correct press <TRF>, and note that the screen advances to the next port automatically.
6. You can change Night Mode ringing by setting the program code field to "16" instead of "15", then the same procedures apply.
7. When all changes are completed, press <SPKR> to exit program mode (or lift handset and hang up).
Dec 16, 2008 | NEC Electra Professional ETW-16DC-2
Number of rings before recording answers
Choose how many times the line will
RINGS IS...” ring before the system answers a call.
• Set for 2 to 7 rings, or choose
Toll Saver 2/4 or Toll Saver 4/6.
• When set to Toll Saver 2/4, the system
answers after four rings when you have
no new messages and after two rings
when you do. Toll Saver 4/6 causes the
system to answer after six rings when
you have no new messages and after
four rings when you do.
• During setup, the Message Window will
display the number of rings (8 for Toll
Saver 2/4, or 9 for Toll Saver 4/6).
Sep 05, 2008 | AT&T 1738 Digital Answering Machine
Norstar M7310 auto attendant problem
As far as changing the # of rings, that may be your phone company. Feature 983 will get you in to change to number of rings. It goes as follows:
Feature 983
System coordinator mailbox # and password
OK
AA
Lines
Enter Line Number
OK
Table
Rings
CHNG
Enter the desired number of rings
If after changing the number of rings the Auto atendant does not pick up at all, You have to call your phone company and set up the second delay through them. We had the same problem here.
Mar 27, 2008 | NorStar Meridian M7310 Phone
Number of rings
Looks like 6 is the Max, according to the Manual.
Setting the Ring Time
Ring Time allows you to set the number of rings the caller hears before your
answering system plays the outgoing message. You can set the ring time to answer
after two, four, or six rings. If you enable the Toll Saver (TS), the answering system
picks up after two rings if you have new messages and after four rings if there are
none.
1) Enter the Answ. Setup menu, and then the Ring Time
submenu (see "Entering the Menu Option" on
page 16).
2) Press volume up/down to select a Ring Time (Toll
Saver, 2 Times, 4 Times, or 6 Times).
3) Press the OK soft key. You will hear a confirmation tone.
Toll saver is a feature where you can call the phone yourself, if there are messages it wil answer in 2 rings, if not it'll answer in 4 rings. The idea is to hang up on the 3rd ring and save the LD changes.
Hope that fixed Ya...
Geno
Mar 27, 2008 | Uniden TRU8885 Digital Answering Machine
How to change number of rings
Not sure how to change the number of time it rings but to change your voice message call yourself, put in your pass when it tells you to then press 4. Now press 3. Now press 1. To have a standard greeting with your number press 1, to have one with your name press 2, and to make your own press 3. Hope this helped.
Feb 22, 2008 | Motorola Mobility V325 Cellular Phone
Number of rings
press *94, then press the number of rings you want 1-9. The tone will change and thats it.
Nov 29, 2007 | Siemens Gigaset S455 Cordless Phone
GE 29875GE2 Digital Answering Machine Logo
71 people viewed this question
Top GE Lands Phones Experts
Dudeman321
Marvin
Marvin
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
