Question about Vivitar DVR-390H Digital Camera
Dvr 390h switch on ok till date time set then blank screen and won't switch off only by removing battery can you switch off
  • 3 Answers
These cameras are notorious for overheating. The one that I have usually takes alittle while before it overheats, but when it does the screen freezes and i can only turn it off by pulling out the battery. The reason these cameras were only produced for about half a year is because of this problem. There is a major design flaw with the camera. If you look at it closely, you will not see proper ventilation areas. If you have noticed, after using the camera for maybe 10-15 minutes the back of it gets EXTREMELY hot. My best suggestion is to try to keep it away from ANY external heat sources when using it. Also, do not use it for prolonged amounts of time. The only thing I use mine for now is a backup harddrive because of the 20 GB harddrive on it and I don't have to worry about overheating because as soon as I am done uploading files, I turn it off. So if nothing else, you do have a pretty nice backup hard drive. Hope this helps!
Posted on Mar 05, 2009
DVR-535 Genius, I am trying to set the Time and Date. the quick quide that comes with the DVR does not mention how this is done.
first of all press menu then down button to down "date and time" then press menu go down to "date input" press rec button go down to set then press rec button use press menu button till u done time snd dste setup press menu buton to home screen check the date and time in red at botton see if correct or redo as listed here
Sep 20, 2013 | Cameras
I Need to update the time and date on my vmax flex DVR
Hold down the OK button on the remote for 30 seconds. Screen will ask you to reset password. DONE!!
Jan 19, 2013 | Digital Watchdog DW-VF16500G VMAX-FLEX...
Can not set date on kadak easyshare c330
The camera should be able to have its date and time set through the menu and it should hold the date if you switch batteries. If it doesn't then the internal battery may have to be changed by a kodak service center.
The camera screen displays "Date/Time have been reset." What should I do?
This message appears if:
  • this is the first time that you have turned on your camera.
  • the battery has been removed for an extended period of time.
  • the battery is exhausted.
To set the date and time:
  1. Press the Menu button.
  2. Use the arrows to:
    1. Select the Setup menu.
    2. Select the Date & Time feature.
    3. Set the date and time.
  3. When you are finished, press the OK button.
For more information, see your camera user's guide for your camera
Dec 18, 2010 | Kodak EasyShare C330 Digital Camera
I have a vivicam and it didn't come with a chager this is my frist vivicam ever what do i have to do to chager it?
I sense that your camera is not actually the DVR-390h in the title. That is an older multi-media device that came with a lithium battery and a charger.
If you bought your camera new and got no charger with it, it may be that your camera uses ordinary AA batteries, which can be rechargeable or just disposable Alkaline cells. You would have got a set of alkaline AAs with the camera, and when these expire, you just put in a fresh set, that you can buy anywhere. DON'T use cheap zinc or "long life" AAs, though. They are not up to the task, and can leak and corrode your camera.
If you want to, you can buy a set (or two sets, to have spares) of rechargeable AA cells. Get high capacity NiMH type, preferably 2300mAH or 2700mAH rated ones. You can often buy these with a charger relatively cheaply. These batteries can last longer, per charge, than alkalines, and will work out cheaper in the long run.
Oct 31, 2010 | Vivitar DVR-390H Digital Camera
How to re-set date in the camera?
turn on your camera and go to menu. top of the screen you will see 3 camera tabs. choose the 3rd screen with the wrench on the camera. this will take you to what you need to change the date. scroll down the screen till you see 'Date & Time', then open it up by pressing the 'ok' button. You should be seeing a screen that asks you to set format. continue to the month, date and year, then time after you have entered your settings, press ok. after your done, press menu button to return to the viewing screen for picure taking. your camera may go to a blank (black) screen while no action is taken. If this happens, just press your menu key and return to the 3rd tab and proceed with the instructions.
Aug 23, 2009 | Kodak EasyShare M863 Digital Camera
Vivitar dvr 390H cuts out when looding and power won't switch off
The Vivitar DVR 390H is notorious for overheating. When the Vivitar has been on for awhile and/or it is being used heavily(uploading pics/vids to your computer, playing music, viewing videos, etc) it will overheat. The bad part is that it overheats fairly easily.
I have one of these and I do like it, but I mostly use it for its 20 GB harddrive as a backup harddrive. My suggestion is to try and make sure that the camera is not near something such as the fan on your computer, under a lamp, or near a wall when trying to upload pics/vids to your computer. Also when downloading/uploading things to and from this camera, do not try to move ALOT of files at the same time. Also, try to keep it turned off as much as possible when you are not using it. I suggest setting the "power off" to 10 minutes just to make sure.
I hope this helps!
Mar 01, 2009 | Samsung HZ10W / WB500 Digital Camera
Setting up camera date
Took battery out overnight.
Nov 14, 2008 | Fuji Photography
Docking station
Vivitar was purchased by Sakar and they do not support anything that Vivitar used to make or carry any of the products. I suggest looking on ebay to see if anyone is auctioning it. If not, Google it for something like "Vivitar DVR 390H docking station".
But to be honest, it probably is not the docking station. I have had the same problem, as many others have had, that the connector in the camera is the issue. This camera has TONS of design flaws.
Jul 02, 2008 | Vivitar DVR-390H Digital Camera
No Disc
I have the same model ... you can't use DVD-R or DVD-RW discs, only DVD+R or DVD+RW
Apr 26, 2008 | Cyberhome DVD Recorder - DVR1600
I lost my adapter to recharge my camera
You might be able to buy a replacement or universal adapter at your local CircuitCity or Best Buy. If you can find one there, may I suggest that you contact the camera's manufacturer.
Mar 24, 2008 | Vivitar DVR-390H Digital Camera
Vivitar DVR-390H Digital Camera Logo
81 people viewed this question
Top Vivitar Cameras Experts
Tony
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
