Question about Whirlpool SF357 Gas Kitchen Range
When I set the oven to 350 it gets there but then as it cools down in the oven and the oven tries to re-light to continue cooking at that temperature it clicks and clicks but just does not seem to re light. Nothing gets fully cooked as the oven does not maintain the correct temp.
  • Whirlpool Master
  • 43,501 Answers
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Posted on Aug 04, 2010
Whirlpool oven not right temperature
thermostat or try raising set point from 350 to 450 and monitor oven temp.
May 14, 2018 | Whirlpool Kitchen Ranges
Temperature when using frigidare oven, keeps getting hotter and does not cool down
Good Afternoon Andrea,
I see that you're having issues with your Frigidaire oven, and the heating element being red hot the entire time you were cooking no matter how much you turned the temperature down.
I suggest giving your appliance a hard reset. You will do this by either unplugging it or cutting the power off at the circuit breaker for at least 2-3 minutes. When power is restored to your oven, you will need to set the clock by entering in the time and pressing start. Preheat the oven, to whatever desired temperature, and if it is still running hotter than it should be, I suggest you contact your local authorized technician. I hope this is helpful.
-Best Regards-
WP
Apr 22, 2014 | Frigidaire Ovens
Is it dangerest when your oven beeps f2
Typically an oven beeps when the interior temperature macthes the temperature where you set the dial. This is an audible signal to that fact and particularly helpful when you need to pre-heat the oven. For example it you want to cook something at 350 degrees, you set the dial at 350. When your oven reaches that temperature it beeps to let you know. Some cooking directions tell you to preheat your oven. In that case, when you set the dial to 350 and wait for the beep...you know you are safe to start your cooking process because the oven is now pre-heated to the temperature you set. If your recipe requires a pre-heated oven, and you don't wait for the beep, your taking a guess at what temperature you're cooking your food. Additionally, if you want to know what the internal temperature of oven is and your oven is heated...you simply turn you dial setting and listen for the beep. Again, if you set your oven at 350 and you want to know how hot your oven is... slowly turn the dial setting. If the oven beeps at 275 then that's how hot your oven has gotten. To let it finish heating to 350 just reset the dial and wait for the beep.
Jan 13, 2012 | Stoves 600GR Gas Single Oven
When using the oven at, let's say 350 degrees, it will be cooking fine then sometimes the oven goes off, oven light included, then we have to shut everything off ,wait for 15-20 minutes for things to cool...
Hello & Welcome to FixYa
This indicates a open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you wan to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
Feb 03, 2011 | Kenmore 40523 Electric Single Oven
Oven does not cook at temperature set at. 2 hrs.
Could be the gasket is not sealing in the heat and you are experience heat loss through the door. Does it seal tightly? Can you feel heat coming around the door area? If so, replace the gasket
Nov 05, 2009 | Wolfgang Puck BTOBR0040 Toaster Oven with...
Gets hot too quickly food cooks too quickly
no oven heats to what the dial says, all are to hot or to cold. try reducing the cooking temperature by 50 *, so instead of cooking a roast at 350, set at 300. i have never seen a stove that is heating to the temperature of the setting.
Jul 05, 2009 | Zanussi ZBF260 Electric Single Oven
T3 electric wall oven - Temperature set buttons
I had the same problem. The entire control panel had to be replaced. That included the display, keypad and all the hardware behind it.. it's one integrated unit. Luckily I had the extended warranty, otherwise it would have cost close to $400.
Jan 20, 2008 | Maytag 30 in. Electric Single Wall Oven...
Kenmore electric oven
Sears Kenmore Electric Wall OVen, Mod.#9114012192 purchased in 1993. Set oven for 425 degrees, reaches set temperature, stays on about 10 minutes and temp. display goes out and oven starts cooling down. Will not stay on desired temp.to cook. Can you tell me what my problem is? Thanks. Doug.
Dec 02, 2007 | Ovens
Whirlpool SF357 Gas Kitchen Range Logo
172 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Ismael Rodriguez...
Sal De
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
