Question about Weber Genesis E-310 Gas Grill
What position should the 3 rubber,flexible washers that are around the gas jets be in? Should they be removed? It is ambiguous in the assembly instrustions. Thank you Ken Anders
  • 43,501 Answers
You are right...the washers are just there for shipping...remove them... you want as much air as possible to able to flow around the jets...
heatman101
Posted on Aug 04, 2010
  • ken6268 Aug 04, 2010
    Thanks! Ken
  • D. Floyd Kolb
    D. Floyd Kolb Aug 04, 2010
    Glad I could help...Please rate and accept my solution... Thanks!!
F dl error
1. Unplug washer.
2. Remove the outer portion of the door bellow. This is the gray rubber boot around the door. Feel around the edge of the door bellow where it attaches to the front of the washer. You will find a wire retaining hoop in the seam between the rubber and the front case. Follow this wire hoop to the bottom of the door bellow and you will find a tension spring. Carefully, stretch this spring apart and remove the wire hoop.
3. Pull the rubber bellow from the door facing on the front of the washer being careful not to rip or tear it. Once removed, fold the rubber backwards inside the drum so you can access behind the front panel. DO NOT remove the rubber bellow from the wash tub.
4. The door latch assembly is located behind the front panel of the washer on the right hand side. Locate and remove the three screws on the washer front that hold the door latch assembly in place. The whole assembly should come free from the washer front and be held by a plastic mounting bracket and several wire connectors.
5. Carefully remove the latch assembly from the plastic mounting bracket BEFORE attempting to unplug any wires. It makes it much easier to access if you do.
6. Unplug the wire connectors using care not to break any of the wires. You may want to write them down, but I believe they will only plug into their respective slots.
7. Remove the old door latch and install the new one in the reverse order of the steps I just presented to you. Plug the wires back in first, then place the whole assembly back into the plastic mounting bracket, and then reattach to the front of the washer.
8. Now, when you get the reinstalling the rubber door boot, you may want to get the assistance of a second pair of hands as it can be difficult sometimes to manipulate the wire retainer back into place. Carefully reattach the rubber bellow to the door facing on the front of the washer first.
9. Starting at the top of the door bellow at the 12 o'clock position begin inserting the wire hoop back into the groove. Work your way around with both hands to the 4 and 8 o'clock positions. (This is where you could use those second pair of hands). While holding a slight downward tension on the wire hoop to keep it in place, pull the tension spring apart enough to snap the remaining part of the hoop into place at the bottom. Once you've completed these steps make sure the door closes and latches properly. NEVER slam a door with an electronic latch. They can break easily.
Now plug the washer back in and test operate. NOTE: You can run diagnostics on these washers by referring to the tech sheet provided by the manufacturer. The tech sheet is located behind the lower panel under the door, or along the interior cabinet walls. Included, are instructions on how to run diagnostics and troubleshooting tips associated with the list of fault codes. It is recommended that this tech sheet remain inside the washer to prevent it from being lost.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Flashes dl f
1. Unplug washer.
Sep 12, 2010 | Kenmore Elite 45986 Front Load Washer
Dl error meassage sometimes f kenmore elite 2004 washer
1. Unplug washer.
Aug 01, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore elite HE 3 frontloader, we replaced the door lock and we are still getting F dL. I tried to unplug to reset but cant get the door open to get clothes out and repair wont be here for 5 days. Any...
1. Unplug washer.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!$!$
May 05, 2010 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Kenmore Front load He 3 I am getting a DL F error code. How do I fix it?
1. Unplug washer.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!
Feb 28, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore 417.44052400 Front Load Washing Machine about 3 years old. The door wont lock. Is there an easy fix to a problem like this?
1. Unplug washer.
http://media.fotki.com/1_p,wbwdbgswgksbgfwxgtqsskgwtqkq,vi/ktfgsrbbdxwtwtqtfwk/1/1303472/5961857/image45924img-or.jpg
Apr 04, 2009 | Kenmore Washing Machines
Constant dlf changed the handle still dlf 1/2 hour just to start
1. Unplug washer.
Mar 23, 2009 | Kenmore Elite 45986 Front Load Washer
Washer will not start cycle.
1. Unplug washer.
Mar 09, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
1. Unplug washer.
Mar 09, 2009 | Kenmore 46462 Front Load Washer
"Fdl" is definitely a door latch error. This will cause the washer not to start. You will need to replace the latch to keep from getting errors and intermittent problems. It will only get worse until it fails altogether. To replace, just follow these steps: 1. Unplug the washer. 2. Feel around the rubber door boot along the front edge. At the bottom, behind the rubber you will find a tension spring. Pull the tension spring out and remove the wire retaining hoop. 3. Remove the door boot from around the door opening and push inside the washer so you can access the door latch behind the front panel. 4. Remove the three screws on the front of the washer that hold the latch in place. 5. Carefully remove the wire connecting plugs to the door latch and remove latch assembly from plastic retainer holding it in place. 6. Replace the door latch in the reverse order of the steps given. 7. Reinstall rubber door boot around the door opening making sure you seat the rubber all the way around the groove. 8. Now comes the hard part - putting the retaining spring back in place. Position the tension spring at the six o'clock position and start inserting the hoop from the top first, working your way around to the 4 and 8 o'clock positions. The assistance of another person would be great right about now. Hold the hoop in place at the 4 and 8 o'clock positions, making sure you keep enough tension on the hoop to keep it seated in the groove. 9. Stretch the tension spring in order to snap the remainder of the hoop back into place. I know this may seem like a lot, but it is a fairly simple repair. I hope this helps you.
Aug 07, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Weber Genesis E-310 Gas Grill Logo
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Marvin
Marvin
Are you a Weber Grilling Expert? Answer questions, earn points and help others
