Question about Roper RGX4634KQ Gas Dryer
I have a heavy duty roper dryer - it runs but does not heat?
    President:
  • 1,218 Answers
Good day,
Here are steps to trouble shoot you problem. It is a Whirpool product.
Here are items to check. You will need an ohm meter to perform some of these tests.
1. Make sure the gas is turned on to the appliance.
2. Remove the back cover of the dryer. In the center bottom is a small skinny white ceramic device, held on with one screw.
Remove one of the wires, and check it with an ohm meter. It should show zero ohms of resistance. If not, it is defective, and needs replaced. This device on your brand causes 80 to 90% of all no heat problems.
3. As well, there are 3 or 4 other thermostats in the area, either round or rectangular, with 2 wires going to them. Check all of them if needed. They should all check zero ohms.
4. To check the igniter, you will have to remove the front panel. A tutorial follows, on how to do that.
Locate the gas valve, on the left side. Follow it forward, you will see the 2 wires on a plug, and at the tip of the burner tube, the igniter itself. Unplug, and check the igniter leads. It should read about 20 to 30 ohms. if not, it has burned out and needs replaced.
5. On the gas valve itself, are 2 black coils, held on with a 2 screw bracket. They can fail, but cannot be tested with a meter. If they are bad, the heating system will light the igniter, and shut down without firing the gas. All components must be in place to perform this test.
That covers 99.5% of all issues. There are others, such as the timer, heat selector switch, centrifugal switch in the main motor, but are extremely rare.
Here is the thermal device that causes many no heat calls.
The tutorial below is not about heat trouble shooting, but is supplied to show how to gain access to the front of the machine.
http://www.wikihow.com/Replace-a-Dryer-Belt-on-Whirlpool-Models
Thermal fuse.
Posted on Aug 04, 2010
Where is the heating element for a Kenmore heavy duty 60 series soft heat large capacity?
How to Replace Your Electric Dryer's Heating Element
www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
How to Replace Your Whirlpool, Kenmore, Roper, or Kitchenaid Electric Dryer's Heating Element. Here's a common job that many folks are afraid of, but it's ...
Whirlpool / Kenmore Dryer Heater and Thermostat Test ...
? 7:40
https://www.youtube.com/watch?v=KZY9CQ_CqvY
Sep 13, 2010 - Uploaded by Bill Newberry
Basic checks for a Whirlpool made dryer. ... Whirlpool & KenmoreDryer Repair - How To Diagnose No Heat ...
Whirlpool - Kenmore - Maytag Dryer Not Heating Repair ...
? 2:42
https://www.youtube.com/watch?v=i95okOr2rOI
Mar 1, 2011 - Uploaded by ApplianceAdvice
It will explain step by step instructions on how to test the thermostats, fuses, and heating element inside the ...
How To Fix Dryer With No Heat ' Dryer Repair - PartSelect
Dec 12, 2015 | Kenmore Dryers
Model #EL5030Vl1 - Heavy Duty Dryer stopped working. Has current and was heating up just fine before it stopped.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 23, 2011 | Roper Dryers
It takes at least 2 cycles to dry clothes. It is Roper heavy duty high capacity electric dryer. Thank you for any help you can give me. janebellard@yahoo.com
Check for air restrictions which cause the heat control to shut down faster than normal.
When the moisture cannot be removed fast enough the heat builds up and has nowhere to go so the heat control stays off longer and the clothes just tumble on.
Service manual and more HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 14, 2011 | Roper Dryers
Want heat roper heavy duty dryer
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 14, 2010 | Roper REX4634KQ Electric Dryer
When one opens door ------dryer keeps running
Simple repair. e45a747.jpg5fc411d.jpgf1e9000.jpgIf you gonna remove the front to do the repair I suggest you lift up on the panel to keep from damaging the clips that hold the bottom secure46c7a66.jpg
Jul 24, 2010 | Roper Dryers
Roper gas dryer does not heat.
If the ignitor is not powering , go to the switch. That has to send power to the ignitor, then on to the gas valve.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 22, 2009 | Roper RGX4634KQ Gas Dryer
Warm heat..clothes not drying
john there is only one heating element.ither it works or it dosent.when acustomer complains of low heat or long dry times 99out of100 its the venting or the dryer is blocked with lint.remove the dryer from the venting and try a load.if better clean house venting.you .........if not better you should have a great air flow leaving the dryer so if not drying well with venting off.take dryer apart a clean all araes that air is moving,where lint can block that flow.god bless .tom
Jan 01, 2009 | Roper REX3614KW Electric Dryer
Warm air but clothes not drying
Make sure u have seleced the high heat setting..The fact that it is heating more or less indicates that the element is o/k.
Check and clean any filter(s) that u can see,it is more likely to be a thermostat problem than anything else. and there are at least 2 of them, also check line voltage is correct.
Plz rate this solution.
thanks.
Roper RGX4634KQ Gas Dryer Logo
104 people viewed this question
Top Roper Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Roper Dryer Expert? Answer questions, earn points and help others
