Question about Marantz SR-7200 Receiver
Marantz SR-7200 Goes to pure static and volume spikes
While watching a DVD or listening to music, the receiver will spontaneously lose the correct audio and instead spit out pure noise at very high volume.... it sends my toddler running for the other room.
I believe it maybe related to the Optical inputs but hard to say since that is all I typically use. Have tried replacing Toslink cables. Bought a Cheap Sony and no more issues, so I am pretty sure I have isolated it to the Marantz. Would like to use it in another application, but wondering if it is worth the $ to fix, or maybe I spend $400 on an Onkyo... Thoughts ?
    New Friend:
Did you ever find a solution? I have the same problem. Thanks
Posted on Jul 15, 2013
  • Fred Lutcher Jul 15, 2013
    Problem Solver:
  • 6 Answers
If the noise is not present in Direct or Pure Direct mode it is definitely associated with digital circuits.
I assume, the unit is not under warranty. Open it and inspect connections to and from digital board. If this does not help it might be faulty connection on the board and it is better leaveing this to a specialist. I hope you did not fiddle with the service menu?!
Posted on May 18, 2008
Marantz SR-7200 volume -29dB blinking
Check Speaker connections at BOTH ends and double check to see that they are on the right terminals.
If you need a manual . the Marantz site will have one . PLus they may have FAQ notes for that receiver
Cheers
Mar 01, 2014 | Marantz SR-7200 Receiver
Tip
Marantz SR-7200 reset
This was documented on the Marantz website briefly a year ago and is no longer available. My SR-7200 develops "click/pop" problems and a reset cures it of these issues.
While powered "off," on the front panel, press: A/D + FP +Dimmer (3 buttons) and power the unit on.
This reverts to original (out of box) settings. You then must reprogram input sources, speaker setup, levels and radio stations.
on Oct 03, 2011 | Marantz SR-7200 Receiver
Static
Check for a burn resistor
Jan 07, 2010 | Marantz SR-7200 Receiver
Marantz SR5001 Rapidly Blinking Standby Light
if u want to sove your problem then contact me on my number 9555503717
Jun 21, 2009 | Marantz SR-7200 Receiver
Marantz SR6001 AV Surround Receiver - Blinking Standy Light
For resetting sr6001: When power lights blinking, press "clear" + "pure direct" + "7.1 ch input" simultaneously for 3 seconds.
iskender
Nov 10, 2008 | Marantz SR-7200 Receiver
Marantz sr 500 going to "protect" mode when on.
Change the audio amplifiers IC´s because are on short circuit
Oct 02, 2008 | Marantz SR-7200 Receiver
Marantz sr7200
most likely the audio pre amp & volume control chip
Sep 27, 2008 | Marantz SR-7200 Receiver
Marantz sr-7200 no OSD
Press AMP then OK on your remote. If the menue does not appear press 9 on the remote. You must have your monitor connected through composit Monitor Out or S-VHS.
Also check your multiroom settings. Maybe your OSD signal is diverted through to other room. I do not have SR-7200 any more, unfortunately.
Jul 24, 2008 | Marantz SR-7200 Receiver
Marantz SR 7200
It is likely that the PA stage has developed an offset voltage in the output stage. The faulty amplifier channel can be found by progressively disconnecting the collectors of the of the power transistors until the protection fault disappears. Once the faulty channel is found the the cause of the offset has to be traced to the faulty transistor or resistor. Don't forget that if you can smell smoke or burning then there are likely to be components(esp transistors) that have been damaged by the fault.
I had a Luxman unit that destroyed 5 transistors in the output stage that was due to an open .5W resistor in the driver stage.
Good luck.
Jan 29, 2007 | Marantz SR-7200 Receiver
Ghosting effect???
The video switching on your receiver is bad. This is a sore spot in an otherwise excellent unit. IFfit is out of it's 3 year warr. the repair will be prohibitive so I suggest getting a video switcher and use it instead. Some of them can be programmed to work with the Marantz remote so you don't have to switch with 2 remotes.
Dec 26, 2006 | Marantz SR-7200 Receiver
Marantz SR-7200 Receiver Logo
248 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
