Question about Canon NP 7130 Black and White Copier
HOPW DO I INSTALL TONER FOR THIS MODEL NP7130
  • 1,219 Answers
From the left sideway of copier you will see small "handle",pull it up and open the copier in right pulling her up.
Then on right side of toner tube holder you will see the handle wich you need to pull in anti clockvise direction, to remove toner unit from drum.
Rotate the toner tube clockvise and pull toward you.
Insert new tube, hold tube and pull out toner seal tape all the way out, rotate anti clockvise until its locked.Return handle in first position and close cover of copier.
Posted on Aug 04, 2010
Toner exausted replace toner
When the toner is exhausted it just like an inkjet printer running out of ink.
You need to install a new toner cartridge or a cheaper alternative, purchase a re-manufactured toner cartridge for your model printer.
Feb 19, 2011 | Samsung SCX-4300 Monochrome Laser...
I have samsung scx4824-fn all in one printer its shows the message the tonner exushted
The laser printer has run out of toner, you need to install a new toner cartridge or a recharged toner cartridge.
Check the internet for replacement toner cartridge for your model printer or purchase a toner cartridge from your computer shop.
Nov 18, 2010 | Office Equipment & Supplies
Samsung scx4725fn cannot seem to recognise new toner.Keeps on saying INSTALL TONER
Install Toner .When this copier is not recognized toner cartridge.If is not this model cartridge or some of missing.please check it properly.You can get an idea install your old cartridge.If the same massage,please check your printer any parts were broken.
Dec 27, 2009 | Samsung SCX-4725FN All-In-One Laser...
I don't have the disc so what do i do to install this webcam
plz follow this link and get the drivers for ur cam. i hopw u will get the solution.
http://www.jascoproducts.com/support/software-downloads.asp#pccams
Nov 13, 2009 | GE EasyCam Webcam
I need a service manual for an Canon np7130
I found a service manual for this model. If still need it let me know.
Apr 08, 2009 | Canon NP 7130 Black and White Copier
The start key does not stop its cycle
Control panel definitely needs replacement. Based on the age of the unit and the cost (at least $350) of the repair, I would recomend replacement.
Nov 10, 2008 | Canon NP 7130 Black and White Copier
Install Cyan Toner Error
ensure that the one you install is the exact model name and number, if this is correct, try unistallling once again and check one more time,
you might want to get a new cyan toner if this still fails, i dont think there is a prob in your machine, cheers
Aug 16, 2008 | Samsung CLP-510 Laser Printer
NP7130 drum problem
hi im jules_09,you should not use compatible consumables for the copier sometime np7130 copier are nasty specially with opc drum,if the copy is blnk the problem is in the high voltage unit or in the transfer unit and drum charge unit you might have the wrong process replacing the drum.re install the drum then try it again .
Dec 02, 2007 | Canon NP 7130 Black and White Copier
Canon NP7130 copier
Make sure that the black plastic arm just to the right of the gray drum release handle is in the proper position. This arm sometimes gets knocked out of position when engaging the tube of new toner. When the copier is clammed closed, this will sometimes come down on the right side of the post on the bottom front cover. This will move the developer far enough away from the drum to make blank copies. Hope this helps.
Nov 12, 2007 | Canon NP 7130 Black and White Copier
Canon NP 7130 Black and White Copier Logo
91 people viewed this question
old marine
old marine
