Question about Lexmark Office Equipment & Supplies
I have a lexmark x3350 all in one and now when i try to print it tells me to insert the correct cartridge i have the correct ones in 33 and 32 please help
I have the same problem. mine says that the color cartridge is wrong.. please advise..........
Posted on Jul 28, 2008
When printing on x3350 with a new cartridge... get lines that are double and some with thick black ink on some letters.
Try to reseat the cartridges into the printer. If problem continues, then maybe the cartridge nozzles need cleaning. Follow the simple steps below on how to clean the cartridge nozzles on the Lexmark X3350:
  1. Go to Start, Programs (Windows XP: All Programs) > Lexmark 3300 Series > Lexmark Solution Center.
  2. Click the Maintenance tab.
  3. Click Clean to fix horizontal streaks.
  4. Click Print. A cleaning page prints, forcing ink through the clogged nozzles to clean them.
  5. Print the document again to verify that the print quality has improved.
Source: How to Clean the Print Cartridge Nozzles on the Lexmark X3350
Jul 13, 2011 | Lexmark X3350 All-In-One InkJet Printer
My x3350 double prints text. It will overlay each sentence on itself. When I print worksheets on excel every other vertical line will be double-printed. I've tried to uninstall and reinstall the...
This may be a cartridge misalignment issue. First try printing with the settings changed to black and white print only. If this does not work then print in fast or draft mode (this should print in a single pass with less ink. Normal or best quality is usually done by passing the cartridges over the line twice.
Run the cartridge alignment test and see if it can be correctly aligned.
It could also be that the belt that moves the cartridge holder is loose and so two passes of the print head are misaligned. This may not be repairable (at least not economically).
Feb 20, 2011 | Lexmark X3350 All-In-One InkJet Printer
I have an lexmark all in printer and i just recently brought refill ink and when i install them it keep telling me unsupported cartridge please help
Though Lexmark does not recommend using refilled ink cartridges, you may try to refer to this article in the Lexmark website on Unsupported Cartridge Error on a Lexmark X3330/X3350 All-In-One to determine and resolve the problem. If error continues, try to insert a different known working cartridge. Thanks.
Feb 15, 2011 | Lexmark OfficeCenter X3350 All-in-One...
I have a Lexmark x3350 all in one printer. I
you can disable the monitor from the startup folder.
Msconfig (in the run box on xp or search box on vista/7) startup, and remove the printer monitor.
OR use a program like CC Cleaner ( Tools/startup)
Jul 16, 2010 | Lexmark X3350 All-In-One InkJet Printer
Lexmark x3350 says it's printing but nothing prints however I can scan.
Try to remove the cartridges from the printer. Close the cover. Unplug the printer from the power source and leave it unplug for now. Clean the nozzles of the cartridges using a damp paper towel. Plug the printer back in the power source. Printer should turn on automatically, otherwise, press the power button. When the printer's ready, insert the cartridges. Also, make sure the cartridges have substantial amount of ink left. If the cartridges are already old, maybe it's about time to replace them. Hope this helps. Good luck!
Mar 23, 2010 | Lexmark X3350 All-In-One InkJet Printer
It says
I'm sorry you are having problems with your Lexmark printer.
Please ensure you are using the correct cartridge.
Black 32
Color 33
Color: 29
If you are using the correct cartridge for your machine you can try to do the following:
Cleaning the print nozzles: (X5470)
1 Load plain paper.
2 Press Copy Mode.
3 Press .
4 Press or repeatedly until Tools appears.
5 Press .
6 Press or repeatedly until Maintenance appears.
7 Press .
8 Press or repeatedly until Clean Cartridges appears.
9 Press .
A page prints, forcing ink through the print cartridge nozzles to clean them.
10 Print the document again to verify that the print quality has improved.
11 If print quality has not improved, try cleaning the nozzles up to two more times.
Wiping the print cartridge nozzles and contacts:
1 Remove the print cartridges.
2 Dampen a clean, lint-free cloth with water.
3 Gently hold the cloth against the nozzles for about three seconds, and then wipe in the direction shown.
4 Using another clean section of the cloth, gently hold the cloth against the contacts for about three seconds, and
5 With another clean section of the cloth, repeat step 3 and step 4.
6 Let the nozzles and contacts dry completely.
7 Reinsert the print cartridges.
8 Print the document again.
9 If the print quality does not improve, clean the print nozzles. For more information, see “Cleaning the print
cartridge nozzles” on page 92.
10 Repeat step 9 up to two more times.
11 If print quality is still not satisfactory, replace the print cartridges.
If you are still getting the incorrect cartridge message it would be best to return the cartridge and exchange it for a new one.
Mar 03, 2009 | Lexmark X5470 All-In-One InkJet Printer
Lexmark X3350 printing
i just fixed this problem.  first i bought a new (remanufactured 3rd party) cartridge off ebay and found it wasn't working either.
there are cartridge cleaning instructions in the troubleshooting help section that show you how to carefully wipe clean your cartridges.  follow that, it solved my problem.
Jan 29, 2008 | Lexmark X3350 All-In-One InkJet Printer
Printer won't print
Open the Lexmark solution center that installed when you added the printer to your computer. Run the align cartridges. This should fix the problem.
Dec 12, 2007 | Lexmark X3350 All-In-One InkJet Printer
Can you help me please!!!!!!
Replace refilled ink carts with proper gen ones cause it sounds like the refill was not so good, print out photos next door till shops open.
Oct 29, 2007 | Lexmark X3350 All-In-One InkJet Printer
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
