Question about Aiwa Audio Players & Recorders
LOST USER MANUAL!!! Power failure in-house caused time to revert to AM/PM, how do I change the display back to 24Hr? Any ideas?? Thanks Ian Clarke..
  • 4,472 Answers
If you can give me the model number I can assist you further.
Thank you,
Lee
Posted on Aug 04, 2010
  • 4 more comments
  • ian_clark34 Aug 04, 2010
    Yeah - Model number is NSX-AVH9.
    Any good to you ??
  • Lee A.
    Lee A. Aug 04, 2010
    What country are you located in/was the unit purchased in? There are a few places online that have the manual but they charge 14.99. You may want to contact aiwa directly depending on your country.
    Thank you,
    Lee
    Unit was purchased in the UK, though I am happy to purchase a manual for 14.99 ($?) - if
    you can point me in the right direction, Lee.
    Thanks,
    Ian C..
  • Lee A.
    Lee A. Aug 04, 2010
    http://www.manuals-in-pdf.com/index.php?...
    That is the only link I could find to download the owners manual. I hope this will work for you.
    Thank you and good luck,
    Lee
    OK thanks Lee I will give them a try.
    Ian C..
  • Lee A.
    Lee A. Aug 04, 2010
    Sounds good. Feel free to update me when you get it.
    Thanks again,
    Lee
How do you change the time from a 24hr clock to a 12hr clock. For example clock says 19:50 instead of 7:50 pm on a Brookstone 5-in-1 Sensor Clock.
Selecting 12- or 24- Hour Mode While in the Time screen, press or to select either 12- or 24-hour mode. If 12-hour mode is selected, PM displays for the afternoon/evening hours. AM does not display for the morning hours http://origin-www.brookstone.com/webassets/pdf/740687p_manual.pdf
Apr 06, 2016 | Brookstone Audio Players & Recorders
Watch Manual for Sergio Valente model# F-IAGAG
These are operating instructions for an SV F-IAGAG (Sergio Valente) watch.
There are four buttons on the watch.
A: upper left
B: lower left
C: upper right
D: lower right
Pressing A turns on the watch face backlight.
Pressing B changes the mode.
From the normal time display mode, one press of B enters the stopwatch mode. In this mode, pressing C will start the stopwatch time count. Pressing C again will stop the count. Each additional press of C will start/stop the count. While the count is proceeding, pressing D will freeze the display of stopwatch time, yet the count will continue. Pressing D again will cause the display to begin updating with the running count. Each press of D will freeze/unfreeze the display update. When the count is stopped (with a press of C), pressing D will reset the count to zero. From this mode, press B again to return to time display mode.
From the normal time display mode, two presses of B enters the alarm time set mode. In this mode, either the hour or minute portion of the time display will be flashing. That which is flashing can be changed by pressing C. Pressing D will switch to the other portion (hours or minutes). Any time the alarm mode is entered and a change is made, the alarm is set to "on". This is indicated by a check mark in the circle display next to the "9" on the watch face. The alarm can be toggled "on" and "off" from the normal time display mode by holding down button D and pressing button C. Return to the normal time display mode by pressing button B while in the alarm time set mode.
From the normal time display mode, three presses of B enters the time set mode. Upon first entering this mode, the seconds display in the circle near the watch face "3" will be flashing. Pressing button C will reset the seconds to zero. Each press of the D button will advance to a different value field for adjustment. The field of adjustment will be flashing. The sequence of fields is (seconds - minutes - hours - date day - date month - date day). Pressing C will change the value. When adjusting the hours, both 24hr format, and 12hr AM/PM format is available. Each press of button C will advance the hour value. The sequence of 24hr format will be indicated with an "H" in the "seconds" circle (near the watch face "3"). After hour value 24 of the 24hr format, the next hour is a "12" value, with an "A" in the seconds circle. Twelve presses of button C will step through the AM hour values and present an "12" value with a "P" in the seconds circle. Twelve more presses advances through the PM hour values and returns to the 24hr format. Pressing button B will return to time display mode.
Pressing button C while holding down button D will toggle the alarm "on/off" state. The "on" state is indicated with a check mark in the display circle next to the "9" on the watch face.
Jan 08, 2012 | Watches
I am not able to set the time properly. When it is AM, the camera shows PM. When I use the Setup Menu to adjust AM/PM, I am able to navigate only up to the minutes and seconds portion. The AM/PM remain...
Hello - sounds a strange menu - I have a FinePix 100fs and that gave me a 24hr clock so the am/pm wasn't an issue. I'll have a look and see if I can change mine over.
Did you get a 24hr clock option in the menu ? -- Ray
Feb 21, 2011 | FUJIFILM FinePix HS10 / HS11 Digital...
I have a pf code and it wont cool
PF = Power Failure. Refer to your user manual to reset unit after a power failure.
Jun 12, 2010 | DeLonghi Pinguino PACL90 Portable Air...
How to set the clock on a Sanyo DC-DA1100 stereo?
This is taken from the user manual.
If switched on, press the ON button to turn the unit off.
Press the CLOCK/TIMER button for at least 2 seconds so that the clock icon blinks on the display.
Press the MEMORY button. The hours display blinks.
Turn the VOULUME control to set the hours.
Press the MEMORY button. The minutes display blinks.
Turn the VOULUME control to set the minutes.
Press the MEMORY button. The clock starts.
NOTE: the time can be set accurately by pressing the MEMORY button when a time signal is heard.
Changing the clock to 12 hour display.
When the clock is display, press the MEMORY button and hold it, then press TUN UP buttom (this will change from 24hr format to AM/PM format)
Nov 02, 2009 | Sanyo DC-DA1000 CD Shelf System
I need to reset my tomtom clock from A.M. to P.M. It's a 340-S
i have a tomtom one, not sure if they are all basically the same, but try this. you should be able to via the settings menu. tap screen, tap 'change preferences' and scroll through the screens until you see 'change time' use the little arrows to set the correct time, and then select 24hr mode. if you are not happy with 24hr mode then select 12hr mode. if you know it is pm but sat nav is showing the correct time but in am, then simply increase the hours by 12.
Aug 05, 2009 | GPS
Clock is in Military time...can't change it back...
If you call Dacor they will talk you through the solution but you have to have another person ready to turn the breaker off while someone is pushing a button. I have contacted them and am trying to get the instructions emailed.
Dacor Toll free: 800-793-0093 have model # ready
Oct 11, 2008 | Dacor Preference RSD30 Gas Kitchen Range
Military time
I have the same problem. The clock changed to military time after we experienced a power failure. I have tried to correct it by holding down the "Alarm Set" button and hitting the "On/Off" button at the same time. It works while the buttons are pressed but immediately reverts to milirtary time. Any other suggestions?
Mar 30, 2008 | Bose Wave Radio II
My MOTOROLA V3 clock on my phone is on military time
settings, INITIAL SETUP, time and date, turn off auto update, change from 24 hr to am or pm.
Nov 18, 2007 | Motorola Mobility RAZR V3
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
