Question about Gateway FPD1760 17" LCD Monitor
Monitor will not stay on. blue light in front comes on, then shuts off
  • 11,361 Answers
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Capacitors kit: http://lcdalternatives.auctivacommerce.com/
Posted on Aug 04, 2010
Monitor wont power off
The blue light probably simply means that the computer is not turned on, but the monitor is. Just turn off the monitor, and the blue light should go away.
Mar 16, 2014 | Computers & Internet
My Hewitt Packard flat screen monitor keeps shutting off, it will come back on then shut off again.The green light stays on.
my HP w1907 flat screen keeps shutting off after playing a game, but does it frequently when changing browsers also.The blue lite stays on, if I click and return it back on blue the monitor opens for one second.
Also I can't return the screen resolution back to its original setting, which is 1440x900 because any browser home page has a 4"white space on both sides of the monitor. I can't hit my auto selectbutton because that causes the problem. I spent $60.00 for tech support but no help on fixing the problem. One tech directed to buy hardware helper,that was about$30.00! I just keeps directing me to my original chipset setting which I told the tech that's where my problem started! My daily important update keeps popping up with it,so where's the HP support when you paid for it? Problem still not resolved. Joe...aka jljoekool@charter.net,,I bought the HP monitor and tower together,so it's a HP PROBLEM
Dec 12, 2010 | HP Vs17 17" LCD Flat Panel Monitor
Hp flat panel monitor comes on shows logon and then blank screen
Ok, another words, monitor powers up for few seconds and shuts down by itself. If green LED on the front panel turns off as well or stays on?
If stays on, then inverter turns into protection mode because of old backlight lamps.
If it turns off in same time with an image on the screen, then there are some bad electrolytic capacitors in the power supply.
Sep 11, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
My picture is green the it shuts off with light blinking in front
that's very hard to fix, you need to monitor every test voltage pin if is in normal. try also replace crystal capacitor thats one monitor with the jungle IC.
Apr 30, 2009 | Sony KP-57WV600 57" Rear Projection...
HP vs19e Computer turns on Monitor stays Black. blue light blinks
Same here- I understand that the capacitors are bad and need to be replaced. I am going to undertake it myself. Radio Shack sells them.
Apr 08, 2009 | HP vs19 19" LCD Monitor
Dell inspiron 530s is giving me major trouble. When ever I turn it on, the power button lights up and the fan turns on but then thats it. There is no activity on the monitor, just the loud noise of the...
my inspiron 530 giving me trouble. Blue light is on, but the computer goes no where. Try to start by shutting down and restarting but the start sound keeps coming fora long time and nothing happens. So to say having trouble starting and sometimes it shuts down but the blue light stays on. Sometimes I cann't even turn off the computer by pressing blue light - trouble trouble trouble
Feb 22, 2009 | Dell Inspiron 530s Desktop Computer...
Monitor does not come on when powered on, it says no input signal
Check your video card. It sounds like it has went bad. Hope this helps.
Jan 08, 2009 | Gateway 420GR PC Desktop
Monitor problem
erickalin - it sounds like your computer might have shut down and failed to come back up again. If you have access to another monitor, try hooking it up to your computer instead of the one you normally use (that won't stay on). If the second monitor won't stay on, the problem is your computer. You might have to take it to your local computer geek or computer store to get serviced. If your computer DOES work with the second monitor, you might need to have your monitor serviced or replaced. Good luck!
supposed2b, I think you have the same problem, although your computer doesn't even sound like it's powering up. Your power supply might be faulty or an internal component (CPU or memory most likely) of your computer has died. Double check your power connections and ensure that when you press the power button you hear the computer start up and the light on the front comes on (hopefully green or blue, but not yellow or red). Again, you might need to take your computer in for service.
Jun 10, 2008 | Computers & Internet
Gateway FPD1760 17" LCD Monitor Logo
53 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
