Question about Honda 3000 Watt Portable Generator
I have a honda generator but i change the cordon starter and now i dont now how ensable it, i need a diagrama of this
  • 3,740 Answers
What you need to do is first remove the new cord that you installed.
(This next process is best performed by 2 people)
Pre-wind the spool gently COUNTER CLOCKWISE until the spring prevents further winding. Have the 2nd person grip the spool so that it does ot unwind. Back off the spool until the re-wind rope hole is aligned with the outer cover rope guide. Insert the new rope through the outer cover rope guide hole and into the spool hole. Pull the new rope through the spool hole and tie a single small knot. Pull the knot into the hole. 2nd person releases the spool and the rope will rewind into the re-coil assy.
Posted on Aug 10, 2010
Starter cord replacement of EF 1000IS Generator
Mentioned here and a general video
Search Results
Recoil Starter Assembly - Yamaha EF1000iS Service Manual [Page 39]
https://www.manualslib.com > ... > Inverter > EF1000iS > Service manual Yamaha EF1000iS Manual Online: Recoil Starter Assembly. ... RECOIL STARTER ASSEMBLY. 1. Install: 1. 2. Install: NOTE: Hook the edge of spiral spring to the ... Inverter Yamaha EF6300iSDE - 5500 Watt Inverter Generator Owner's Manual.
How To Replace Pull Start Cord on Honda eu2000i Generator ...
? 7:07
https://www.youtube.com/watch?v=5WAuEW8decY May 27, 2016 - Uploaded by Tula's Endless Summer
http://tulasendlesssummer.com Here is a short video on how to replace the pull cord on a Honda 2000 watt ...
Yamaha EF1000iS Service Manual Recoil Starter Assembly
May 20, 2018 | Garden
How to change recoil rope
How To Replace The Starter Rope On Your Recoil ...
? 4:47
www.youtube.com/watch?v=Q3NjVomUQJM
Feb 25, 2009 - Uploaded by craig1974 Me showing you how to replace your starter rope on your recoilassemblies.
Sep 11, 2015 | Honda EU6500iS Inverter Generator
How do i remove the starter on a Honda ES6500 generator
Remove ground wire from battery post. Make sure unit is off too. Remove start wire and cable from starter and both bolts. Reinstall in reverse order.
Feb 11, 2014 | Honda Electrical Supplies
Starter wont engage,battery is good
Remove the starter and bench test it with auto booster cables /put the black on the starter case and touch the stud on the rear of the starter. It should spin rapidly and the drive should advance if neither
happens the starter will need rebuilding or replacing. if the starter spins rapidly but the drive does not advance you may only need to replace the drive.
Jan 01, 2014 | Honda 3000 Watt Portable Generator
Took my ev6010 generator out and put it back in but hooked up the starter motor to the ground not to the positive and now it wont start. I also changed the oil and coolant.
On the ev6010 Honda generator the posive starter wire is black and was accidently hooked up to the chassis ground wire. Then the start button was pushed and nothing happened. I corrected the wire hookup to the positive side but will not start still
Aug 28, 2013 | Honda Ev4010 Ev6010 Rv Generator Inverter...
1979 honda cb750k running on seems like 2 cyl. have changed both ign. coils,4 plugs,pulse generator --no change
Clean your fuel system with seafoam for starters...
Sea Foam Motor Treatment
I used to have that same exact bike when I was a kid but I can't remember how many carbs it had??
Jan 25, 2018 | Honda Motorcycles
I have a Honda Sabre 1100cc, and I perforated the exaust and now is doing back fire.....Friend told me just open the air needle, on carburator but I don't find the air needle, and I want if you can send me...
NO dont go down this rout,*you will totally screw up your fuel consumption ,and possibly ruin your engine, Fill any holes in your exhaust as this is why it backfires, If you want a good noise then get aftermarket silencers. ,check they dont need re-jetting most road legal ones dont.
Mar 02, 2010 | 2004 Honda VT 1100 C2 Shadow Sabre
Ihave a honda ganerater MODEL#ES3500 and dont know were the battery goes.
The battery '+' attaches directly to the starter and the '-' cable is grounded to the frame/block.
Nov 03, 2008 | Honda Electrical Supplies
Honda 3000 Watt  Portable Generator Logo
351 people viewed this question
Top Honda Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
