SOURCE: have a carrier weathermaker 8000 model 58zav need
Match your transformer up with one of these transformers
There are transformers there for most any application...
heatman101
SOURCE: Carrier Weathermaker 8000 blower fan quit Was
Hi Jarliske,
If the motor needs to be replaced, then you need to follow the below steps,
You need to pull
the motor out and & check the data plate on the motor.
This data plate would list the HP number ,
You can get it from a local electric shop or a HVAC supply house the usually keep this in stock and will save you a good amount of money.
As most are reversible rotation you need to be sure to get a matching
capacitor.
Also note the motor type, if it is of the PSC type, it will have a running capacitor already.
You can check and replace the blower fan accordingly.
Hope this helps ...:)
