Question about Breville Coffee Makers & Espresso Machines
Operation how do I operate
Problem solved
Posted on Apr 26, 2008
How to Create my Own Windows Based Operating System?
You cannot create your own Windows-based operating system because the windows is the operating system. In order to create an operating system for a computer you have to know a great deal of programming. For even a rudimentary operating system to have a Windows like environment it would take years of development and would not even be as effective as a windows 3.1, windows 95, windows 98 or Windows 2000 operating system. Linux has free operating system that you can install on a PC look up "Redhat" or "how to install Linux on a PC" this is a little involved but people have already done a lot of the work you are speaking about. The Linux operating system is a great operating system of you throughout the world.
Oct 19, 2016 | Computers & Internet
F 56-2 ERROR CODE
Key Operator Mode
To the Key Operator
The key operator is trained to handle all special key operator functions that are not
accessible to the general user, such as monitoring overall copier activity, machine
performance, and service information; modifying machine settings; and controlling user
activity, for billing purposes.
A unique 4-digit key operator password is normally set by service at installation. If the
unique code is not set by service, the copier will not display Key Operator Password
Entry Screen when the Key Operator mode is being accessed, and a key operator
password will not be required. A service-set 8-digit ECM master key code must be
entered by the key operator to access the Electronic Copy Monitor functions, and a
service-set 4-digit Weekly timer master key code must be entered by the key operator to
access the Weekly timer functions.
To ensure the security of Key Operator mode, it is recommended that you establish a
unique key operator password, along with the key operator ECM master key code and
Weekly timer master key code, and keep them in a confidential file.
r HELP is unavailable in the Key Operator Mode
Key Operator Mode Screen 2
NOTE: The function number [12] Call remote service center and [13] Save ECM data to memory card on the
Key Operator Mode Screen will be dimmed and cannot be selected on the copier without the remote
diagnostics activated.
Key Operator Password Entry Screen Key Operator Mode Screen 1
Key Operator Mode 13-3
Key Operator Mode
To the Key Operator (continued)
How to Access the Key Operator Mode
1 First, be sure the copier power switch is OFF.
2 Then, turn power back ON while pressing the [HELP].
The Key Operator Password Entry Screen displays when the 4-digit key operator
password is set by service.
Otherwise, the Key Operator Mode Screen displays without the password
requirement.
3 If the Key Operator Password Entry Screen is displayed, use the keypad on the
touch screen to enter your 4-digit key operator password; then touch OK, to display
the Key Operator Mode Screen. (See note.)
If the key operator password is not valid, check with your service representative.
4 To display menus [11] to [13] of the Key Operator Mode Screen, touch the lower
arrow key. To return the menu [1] to [10] of the Key Operator Mode Screen, touch
the upper arrow key.
5 Make setting changes from the Key Operator Mode Screen, as described on the
following pages.
NOTE: If an invalid Key operator password is entered, continue by entering the valid 4-digit password.
13-4 Key Operator Mode
Key Operator Mode
Function Menu Map
FUNCTION MENU SUB FUNCTION MENU AND SETTING OPTIONS
[1] Initial setting [1] Copy mode: [RADF; 1-1; 1-2; 2-2; 2-1]
[2] Copy density: [AES; manual]
[3] Lens mode: [AMS; ratio 0.33~4.00]
[4] Paper tray: [APS; trays 1, 2, 3, 4, 5, or Multi-sheet bypass tray]
[5] Output: [sort; group; staple-sort]
[6] Staple: [Normal 1 position left; Normal 1 position right;
Normal 2 positions left; Normal 2 positions right; Upsidedown
1 position left; Upsidedown 1 position right; Upsidedown 2
positions left; Upsidedown 2 positions right]
[7] Image scan: [Normal mode; High mode; Very High mode]
[2] Lens mode ratio [User Set ratio]
[3] ECM [1] ECM Password and User name setting
[2] ECM Count limit setting
[3] ECM Count Reset
[4] ECM On/Off Setting
[5] Copy-Limit-reached effect
[4] Lock/delete [1] Lock Job memory
job memory [2] Delete Job memory
[5] Paper type [Recycled; Colored; Letterhead; Special; Labels; Invoice; Legal;
Ledger; Blank]
[6] Control panel [Dimmer; Brighter]
contrast
[7] Key operator
[5-digit number]
Tel. No.
[8] Weekly timer
[1] Weekly timer On/Off setting
[2] Summer time setting
[3] Date & Time setting
[4] Timer setting
[5] Timer action On/Off setting
Feb 22, 2013 | Konica Minolta Copier Toner 7055/7065...
What is a E4 code mean
Error Code:
E1 Loss of communication between the Single Zone LCD thermostat and the mod-ule board. LCD will cycle between E1 and the previous mode setting. System
will shut down.
E2 Open circuit or out of range Indoor Temperature Sensor. Heating and cooling
operation will be locked out. Fan operation can continue to operate.
E3 Shorted Indoor Temperature Sensor. Heating and cooling operation will be
E4 Open circuit or out of range Outdoor Temperature Sensor (select models). Heat
Pump operation will be locked out. Air Conditioner, Fan and Furnace operation
E5 Open circuit or out of range Freeze Sensor. Air conditioner mode of operation
will be locked out. Furnace, heat strip, heat pump and fan mode of operation can
continue to operate but displays the last temperature set-poi
Dec 18, 2012 | Dometic 3313192.000 White Single Zone LCD...
What is the operating machine ?
If you mean operating system then:
An operating system (OS) is a set of software that manages computer hardware resources and provides common services for computer programs. The operating system is a vital component of the system software in a computer system. Application programs require an operating system to function.
Time-sharing operating systems schedule tasks for efficient use of the system and may also include accounting for cost allocation of processor time, mass storage, printing, and other resources.
For hardware functions such as input and output and memory allocation, the operating system acts as an intermediary between programs and the computer hardware, although the application code is usually executed directly by the hardware and will frequently make a system call to an OS function or be interrupted by it. Operating systems can be found on almost any device that contains a computer-from cellular phones and video game consoles to supercomputers and web servers.
Examples of popular modern operating systems include Android, BSD, iOS, GNU/Linux, Mac OS X, Microsoft Windows, Windows Phone, and IBM z/OS. All these, except Windows and z/OS, share roots in UNIX.
Jun 24, 2012 | Computers & Internet
What is the 5 types of operating system?
This are the Operating system types:
As computers have progressed and developed so have the operating systems. Below is a basic list of the different operating systems and a few examples of operating systems that fall into each of the categories. Many computer operating systems will fall into more than one of the below categories.
GUI - Short for Graphical User Interface, a GUI Operating System contains graphics and icons and is commonly navigated by using a computer mouse. See the GUI definition for a complete definition. Below are some examples of GUI Operating Systems.
System 7.x
Windows 98
Windows CE
Multi-user - A multi-user operating system allows for multiple users to use the same computer at the same time and different times.See the multi-user definition for a complete definition for a complete definition. Below are some examples of multi-user operating systems.
Linux
Unix
Windows 2000
Multiprocessing - An operating system capable of supporting and utilizing more than one computer processor. Below are some examples of multiprocessing operating systems.
Linux
Unix
Windows 2000
Multitasking - An operating system that is capable of allowing multiple software processes to run at the same time. Below are some examples of multitasking operating systems.
Unix
Windows 2000
Multithreading - Operating systems that allow different parts of a software program to run concurrently. Operating systems that would fall into this category are:
Linux
Unix
Windows 2000
Hope this information could help you to solve your problem. Mam/Sir don't forget me to rate me up I really appreciate what grade/ratings you will be given to me, it could help me lot to answer more questions especially in explaining in more detailed. Thanks a lot and God Bless.
Jun 27, 2011 | Computers & Internet
Series print no worked in my pc
The list below includes the operating systems supported by this model.
Compatible Operating Systems
Windows Macintosh Windows 95
Windows 98
Windows ME
Windows NT4
Windows 2000*
Windows XP*
Windows Vista*
Windows Vista64*
*Driver included in the Operating System
To download drivers for this model, click Drivers & Downloads tab above, and then select your operating system.
Incompatible Operating Systems The following list contains some of the more well known operating systems that are NOT supported with this model.
Windows 3.1
Windows 2003
BeOS
Mac OS X Linux
UNIX
Mac System 7
Note: This is a compiled list and may not include all possible incompatible operating systems.
Jan 01, 2011 | Canon BJC 3000 InkJet Printer
What are the heirarchy of operation?
The following information on "Hierarchy of Operations" was taken from Pages 45-46 of the "Microsoft QuickBasic 4.0: Basic Language Reference" manual for Versions 4.00 and 4.00b. This information also applies to the following products:
  1. Microsoft GW-Basic Versions 3.20, 3.22, and 3.23
  2. QuickBasic Versions 1.00, 1.01, 1.02, 2.00, 2.01, 3.00, 4.00, 4.00b, and 4.50
  3. Microsoft Basic Compiler Versions 5.35, 5.36, 6.00, and 6.00b
  4. Microsoft Basic PDS Version 7.00.
MORE INFORMATION The Basic operators have an order of precedence, that is, when several operation... loadTOCNode(1, 'moreinformation'); The Basic operators have an order of precedence, that is, when several operations take place within the same program statement (without being grouped by parentheses), some operations are executed before others. Operations are executed in the following order:
  1. Arithmetic operations
    1. Exponential (^)
    2. Negation (-)
    3. Multiplication and division (*, /)
    4. Integer division (\)
    5. Modula arithmetic (MOD)
    6. Addition and subtraction (+, -)
  2. Relational operations (=, >, <, <>, <=, >=)
  3. Logical operations
    1. NOT
    2. AND
    3. OR
    4. XOR
    5. EQV
    6. IMP
An exception to the order of operations listed above occurs when an expression has adjacent exponentiation and negation operators. In this case, the negation is done first. For example, the following statement prints the value .0625 (equivalent to 4^-2), not -16 (equivalent to -(4^2)): PRINT 4 ^ -2 If operators on the same precedence level appear in the same expression, they are computed from left to right.
For more information on the "Hierarchy of Operations," consult the Basic language reference manual for your version of Basic. Please post your feedback and Vote if the problem resolved as per your satisfaction.
Jul 13, 2010 | Microsoft Windows XP Professional
B6300n Printer: Hello i have oki B6300 printer and its showing e...
Step#1: Turn on power, press the left and right arrow buttonssimultaneously,, release both buttons then press the online button to get intothe DIAG. Menu Step#2: Press the down arrow button twice the operator panel willdisplay Diag.Menu Adjustment Step#3: Press the right arrow button the operator panel will displayAdjustment DC131 NVM R/W Step#4: Press the down arrow button the operator panel will readAdjustment DC132 Set Serial Step#5: Press the right button the operator panel will read SerialNumber XXX Record this serial number SYS1: XXXXXX Step#6: Press the Down Button 24 times. The operator panel should readDC132 Set Serial Target PWA SYS1 Step#7: Press the Select button Operator display Enter Serial No. 000000 Enter the serial number thatyou recorded in step#5 Action: Please reference this photo as a reference for the up, down, left, andright keys, when performing the following procedure. Step#1: Turn on power, press the left and right arrow buttonssimultaneously,, release both buttons then press the online button to get intothe DIAG. Menu Step#2: Press the down arrow button twice the operator panel willdisplay Diag.Menu Adjustment Step#3: Press the right arrow button the operator panel will displayAdjustment DC131 NVM R/W Step#4: Press the down arrow button the operator panel will readAdjustment DC132 Set Serial Step#5: Press the right button the operator panel will read SerialNumber XXX Record this serial number SYS1: XXXXXX Step#6: Press the Down Button 24 times. The operator panel should readDC132 Set Serial Target PWA SYS1 Step#7: Press the Select button Operator display Enter Serial No. 000000 Enter the serial number thatyou recorded in step#5 Step #8: Press the select button operator display Re- Enter Serialnumber XXXXXX enter the serial number from step #5 again. Press Select Step #9: The operator panel will displa Note: The Operator will now display "DC132 Set Serial NumberCompleted". Step #10: Press the left and right arrow button, release both buttonsthen press on-line button to get into the Diag MODE Step #11: The operator panel will display Exit Diagnostics Incomplete Exit Step#12: Press the down arrow button the operator panel will read ExitDiagnostics Complete Exit Step #13: Press the select button the operator panel reads Complete Exit If OK Press SEL Step #14: Press the select button the operator will read Please Reboot Printer (103-208) --Power the unit OFF Wait three seconds then power the unit back ON.Operation is now complete.--
May 17, 2010 | OKI B6300n Printer
Need ecm code for konica 7055 or a reset code is there an override code?????
Key Operator Mode
To the Key Operator
Key Operator Mode
requirement.
following pages.
Key Operator Mode
Function Menu Map
[3] ECM Count Reset
Ledger; Blank]
contrast
[7] Key operator
[5-digit number]
Tel. No.
[8] Weekly timer
[4] Timer setting
Jul 23, 2009 | Konica Minolta Office Equipment & Supplies
Coffee Makers & Espresso Machines Logo
37 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
Steve
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
