Question about Thermador CM301U Electric Single Oven
How do I unlock the panel control for my thermador electric single oven?
  • 87 Answers
SOURCE: AMANA SINGLE CONVECTION OVEN CONTROL PANEL SOME KEYS INOP
Usually the keypad is separate and connected with a ribbon cable.If so, you just need to order a new keypad assembly
Posted on Jun 08, 2007
  • 3 Answers
SOURCE: frigidaire single wall oven
We had a similar problem. When the repair person arrived he turned of the electicity to the oven then turned it back on. The control panel is a computer and he rebooted it.
Posted on Jan 08, 2008
SOURCE: Control panel disassembly
Shut the breaker off to the oven first. Frame around mircowave is a snapped on front. Removing allows access to two screws under control panal. Must actually pull entire unit out about 9 inches to access top of control area to remove access panel. Once front control panel is removed and top is opened, easy access to what you need to get to. Carefully write down color coding of wires before removing any of them. Remove old power supply board and display and reconnect. Reverse process. A bit of work but if you watch the disassembly process carefully, pretty easy.
Posted on Jul 12, 2008
SOURCE: Lighting panel in my electric Thermadore double oven is dim.
I just replaced two of the capacitors and it worked thank God. I couldn't get at the 3rd capacitor with the soldering iron because the display blocks it and I couldn't see how to remove the display unit. We had already begun shopping for a new double oven. This was the last resort. The capacitors were $1.78 apiece at an electronics store. A repairmen quoted us a $780 fix - with him shipping the parts out to be rebuilt because Thermador is out of business and not producing parts anymore. There is a great place in Canada called Appliancetimers.com which will rebuild the timer for you inexpensively ($109) but they also want you to send the Power Relay Board which requires removal of the double oven to get at it. We found that it was much too heavy to consider that solution.
Posted on Mar 27, 2009
SOURCE: thermador oven control panel light is not working
Please see post by bonanzsapilot on 14 March 2009; he gives exact & easy to follow directions for making this repair for <$10. It's listed uner 'Thermador SC301IT oven - FixYa'. In a separate post I added the correct capacitor numbers from Newark.com. I made the fix in abt 30 min & it's good as new. Thermador no longer makes control panels for this oven & no wiring diagram is available to help. Shop price was estimated at $500.
Posted on Apr 13, 2009
Thermador 30" wall oven.
Your touch in put key is stuck, replace ,power relay board and the touch panel
Always unplug the oven first before service
May 20, 2011 | Thermador C301U Electric Single Oven
Oven displays Off with every button you push
touch panel has failed . may need replacement . . this unit may require a update kit .. ( new p c control and panel .. ) very costly. mm
Jul 13, 2010 | Thermador SMW272 Electric Double Oven
Thermador wall oven doesnt heat up after being self cleaned
This may be the thermal fuse mounted on the back panel or you may have a failed control. We rebuild Thermador control boards at www.fixyourboard.com
Jun 02, 2010 | Thermador C302U Electric Double Oven
Oven is locked cant open. please help
the oven lock is controlled by a microswitch. it is not working so you have to go in and manually unlockl it. take top front panel off and look for 2 wires that are going to to lock jump these wire and it will lock
look at a diagram to do this on the web
Mar 22, 2010 | Thermador C301U Electric Single Oven
Thermador oven control panel light is not working
Nov 16, 2008 | Thermador SMW272 Electric Double Oven
Thermador SEC301BPSS Electric Single "service Message"
Sometimes, you can reset the panel by turning off the circuit breakers. Look for a linked pair of 40-50 amperes. Turn them off then on. If this doesn't fix it, you will need to change the circuit board...first things first, though.
Dec 21, 2007 | Thermador SEC301BPSS Electric Single Oven
Heating elements do not heat
it sounds as if you have a tripped thermal cut out. This is accessed by removing the 5 or so screws on the black grate below the control panel and pulling the grate out. Somewhere in the middle towrds the front should be a little button wiht 2 wires hooked to it. make sure you have the power off to the oven, then reach in with a screwdriver or your hand if you can and push the little red buttton down untill it clicks. The cause for this to trip could be bent door hinges not allowing the door to close fully (common thermadore problem), bad door gasket especially in combination with running a self clean cycle, broiling with the door ajar, or a bad cooling fan (the one behind the electronics, not the one in the oven) Hope this helps.
Jun 16, 2007 | Thermador SEC301 Electric Single Oven
Thermador CM301U Electric Single Oven Logo
209 people viewed this question
Top Thermador Ovens Experts
goober123
Level 1 Expert
Oloyede Monsuru
Marvin
Marvin
Are you a Thermador Oven Expert? Answer questions, earn points and help others
