Question about Yard Man Yardman Riding Lawn Mower 38in Deck 12 12 Hp
Yardman T604H 46" cut..manual pto will not stay engaged
    Loyalty:
    Visited the website for 30 consecutive days.
  • Yard Man Master
  • 1,495 Answers
Try PartsTree.com they may have one
Posted on Mar 20, 2018
  • 33 Answers
SOURCE: motor stops when the pto or cutting blades are turned on or engaged.
you most likely have a bad safety switch. there is one under your seat,one on engagement lever for blades,and probably one or two more in other places.start with the one under your seat by unplugging it and then going ahead with normale start up and implement engagement. you will have found the bad switch when everything works as it should.replace switch if you feel its necessary or just leave unplugged. it will not affect performance or longevity of the tractor
Posted on May 02, 2009
SOURCE: need diagram or instructions on putting on new cutting belt
bex bissell proheat
Posted on May 21, 2009
panilling9
  • 284 Answers
SOURCE: cub cadet mower pto will not stay engaged while
be sure your battery is good and your system is chargingning the battery while run
Posted on May 26, 2009
  • 109 Answers
SOURCE: Cub cadet Z Force 48 inch zero turn blades won't engage
I hope this will help you...under the side panels on each side of the mower, there are "reverse lockout safety switches", they are supposed to stop the blades when both handles are pulled back. If one or both of the switches are out, the deck will not engage. Also, under the right side panel (when sitting on seat) there should be 3 relay switches, the one closest to the motor controls the PTO., if this is out, the PTO will not engage.
Posted on Jun 29, 2009
  • 130 Answers
SOURCE: electric pto won't stay engaged on LT 1045
you have a shortage or your clutch is going bad
Posted on Jul 18, 2009
My blade will not stay engaged to mow. how do I fix the problem?
When you say will not stay engaged you are saying that it comes on then cuts off ? If you turn on the PTO and it engages and the mower is not moving does the PTO stay engaged and for how long (if OK then need to check connections for PTO ) . If it is not engaging at all then we have to look at interlocks / safety switches . Give me some Details
If you need further help, reach me via phone at https://www.6ya.com/expert/richard_b70d968cd1a1d293
Apr 18, 2016 | Husqvarna Rz4623 46" Ztr Lawn Mower Zero...
How to change a Yardman M.T.d. transmission drive belt diagram on 46" cut?
You can go to the Yardman website and download the service/owner's manual.
Aug 18, 2014 | Garden
Pto on yardman 42 lnch cut belt will not go tight
A spring keeps the tension on a PTO belt. It may be broke or unhooked.
Jan 13, 2013 | Craftsman Garden
Pto won't engage after it had stalled out when in reverse
Did you take it out of reverse? You need too look closer at the linkage and at wear it gos, look for the switch on the trans mission, it going to work one of two ways positive or negative if it work from ground unplug it and see if it will work, if it doesn't try running a wire from one side of the connector to complete the circuit .
If you need further help, I’m available over the phone at https://www.6ya.com/expert/edward_020b3320326d263d
May 18, 2012 | Yard Man Yardman Riding Lawn Mower 38in...
I have a 97 yardman 20hp 46 " deck pto stays on in off position, slows down but doesnt totally disengage, any pointers would be greatly appreiciate it thx!
here is the manual bottom of page 16 and page 17, Good Luck Tim:
http://www.managemylife.com/mmh/lis_pdf/OWNM/99030004.pdf
May 29, 2011 | Mtd Garden
How do i change the pto cable on a yardman riding lawn mower
Hi,you can download the manual for your device at;www.manualsonline.com and www.manualnguide.com.
Thanks and good luck
May 02, 2010 | Mtd 46" Dozer Blade, Fits All & Yard -...
Smoke when blades engaged on yardman 42'' yard tractor
The oil on your pulley could definitely be the culprit. You need friction in order for your belts to work properly.
Apr 17, 2010 | Mtd Garden
I need a belt diagram for a ranch king king plus also i need to know the size for the main drive belt
Ranch King is a brand name of the manufacturer MTD.
Product manuals with part blow-up diagrams are available from MTD's web site,
http://www.mtdproducts.com/
Models are identified from the model number printed on a label under the mower seat.
The PTO and deck drive belts are shown on one diagram and the transmission drive belt is shown on another. The Form number on my printed Operator's Manual is 770-10526A (22HP, 46in cut) for Hydrostatic 817/818 models.
Parts can be ordered directly from MTD or other distributors on the web.
It is my experience that original brand name MTD belts work best.
The 22HP, 46" mower deck Ranch King Pro has 3 belts:
The drive belt which runs from the engine pulley back to the hydro drive unit to provide over-the-ground propulsion is part #754-0349.
A mower has either an electric PTO or a manual PTO, not both.
The electric PTO belt the provides power to the blade deck (runs around the electric clutch on the engine shaft (activated by electric switch, not the mechanical hand lever that engages the mower deck) is p/n 754-0476 for the 46" deck.
The manual PTO belt the provides power to the blade deck (runs off the pulley on the engine shaft (activated the mechanical hand lever to the left of the steering wheel that engages the mower deck) is p/n 754-0228 for the 46" deck.
The deck belt that goes around the 3 blade spindle assemblies on the mower deck, to drive the grass cutting blades is p/n 754-0349
In my experience, the PTO belt lasts about half a season, the other belts break about every other season when mowing 4 acres weekly.
Sep 07, 2009 | Mtd Garden
Yard Man Yardman Riding Lawn Mower 38in Deck 12 12 Hp Logo
149 people viewed this question
Top Yard Man Garden Experts
Phil Walker
Phil Walker
Jim Parker
Jim Parker
john h
Are you a Yard Man Garden Expert? Answer questions, earn points and help others
