Question about Sony Cyber-shot DSC-W120 Digital Camera
When i turn on my sony cyber-shot DSC-W120, the lens goes in and out several times, and then the screen says "turn camera off and on again" but the same thing happens.
    President:
  • 1,382 Answers
If you've recently dropped the camera you may have lens damage that is causing the camera to shut down. If you haven't dropped it, your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try solution before you do anything else:
Step1: Remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper).
Step2: Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced.
Step3: Remove the lens from the camera. Put the body cap on the camera, and put the rear lens cap on the back of the lens. Make sure you are in a clean environment.
Step 4: Take the rear cap off the lens and use the blower to blow large pieces of dust off the lens. Go around the entire rear part of the lens with the blower.
Step 5: Dip the swab in the isopropyl alcohol or cleaning solution. You should use only a light amount; the best way to ensure this is to wear light vinyl gloves, like those used by health care providers, and squeeze the swab with your fingers after dipping it in the solution. Gently clean the contacts on the lens with the swab. After you have done so, use the blower on the lens contacts again.
Step 6: Repeat the procedure on the contacts on the camera body.
Step 7: Reattach the lens to the camera and test it to see if the error or focusing problems still exist. If they do, try cleaning the contacts again.
Thank you !!
Posted on Aug 04, 2010
Turn power off again sony dsc w120 shot
disculpe tengo una camara sony DSC-W120 la bateria esta cargada y la quiero encender y no prende que puedo hacer saluda atte rodolfo
Jan 14, 2013 | Sony Cyber-shot DSC-W120 Digital Camera
Sony Cyber Shot DSC-W120 My camera has been dropped, whilst the lens was out. When I turn the camera on now, the lens goes in an out several times and on the display it says "Turn the power off and on...
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them.
Oct 29, 2011 | Sony Cyber-shot DSC-W120 Digital Camera
Sony camera wont take pictures
It is problem of lens mechanism that does not send initialize signal to system control chip and camera tries 3 times for that then give up so that error message comes in result.
Replace lens assembly to fix the problem.
Local camera repair shop will help you to replace it.
Thanks.
Jun 13, 2010 | Sony Cyber-shot DSC-W120 Digital Camera
Same promblem
Such a common problem with an amazinging simply fix. bang it face down on your palm several times quite hard. Turn on and check. keep doing this till the lens extends properly.
Whilst this sound like a joke it is not A Sony tech shared this with me and said that they charge $90 to do this. Amazing isn't it!
Jul 22, 2009 | Sony Cyber-shot DSC-W120 Digital Camera
Sony Cyber-shot w120 digital camera won't pop lense out
Your zoomunit is defective. Rotronica has replacements for this camera.
Or contact your Sony repaircenter.
Regards,
Rob NL
Apr 06, 2009 | Sony Cyber-shot DSC-W120 Digital Camera
Cannon cyber shot DSC-W120
If you contact with a service center they can change the lens. It is avaible as a spare part
Mar 27, 2009 | Sony Cyber-shot DSC-W120 Digital Camera
Turn the power off and on again problem
Your lens may need adjusting. This info may help . Other People solved problem. Lots of Info on this link.
http://www.fixya.com/support/t102982-e_18_problem
Mar 21, 2009 | Sony Cyber-shot DSC-W120 Digital Camera
Sony Cyber-shot DSC-W120 Digital Camera Logo
185 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
