Solution #1
posted on Apr 27, 2008
It may be in the startup mode. Try this:
Setting the Clock
1. Press Timer/Clock twice. Colon flashes.
2. Set time of day using Time Dial. Time appears in the display window; colon continues flashing.
3. Press Timer/Clock. Colon stops flashing; time of day is entered.
If that doesn't do it, try unplugging it for a minute or two then try again.
Is the Child Lock on?
To Set Child Lock Press Start 3 times. “LOCK” appears in the display window. "LOCK" continues to be displayed until Child Lock is cancelled. Keypads may be pressed but the microwave will not start.
To Cancel Child Lock Press Stop/Reset 3 times. The display will return to colon or time of day when Child Lock has been cancelled.
You can download your owner's manual here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Setting the Clock
Comment by MicrowaveSvc, posted on Apr 27, 2008
CORRECTION!
DEMO MODE ON/OFF
Demo mode is designed for retail store display. In this mode, the oven can be demonstrated
with no power in the oven.
4 taps ON The oven is in Demo mode.
4 more taps *OFF The oven is not in Demo mode.
DEMO MODE ON/OFF
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To:
GE JE2160 1150 Watts Microwave Oven
GE JE620 650 Watts Microwave Oven
GE XL1800 1100 Watts Microwave Oven
GE General Electric Microwave Microwave Oven
GE JE1360 Microwave Oven
GE JEM25 800 Watts Microwave Oven
GE JES1142SF 1100 Watts Microwave Oven
Can you Help with these Microwave Ovens problems?
Repair Service
Find Microwave Oven Repairman Near You:
