Question about Refrigerators
Need gasket for freezer section model # ET14AKXRnr1
2 Suggested Answers
  • 1779 Answers
SOURCE: door gasket for Kenmore upright freezer model 2539239712
Go to sears parts direct website. It's part #3206261 and is in stock, $93.07. Good Luck! countrycurt0
Posted on Aug 08, 2008
I have a 2013 Samsung frig model rf28hfedbww/aa. The top part is not cooling The freezer is ok
Freezer supplies cold air for the fridge section.. Check fridge gasket for tight seal, operating freezer fan along with proper operation of damper mechanism which directs flow of cold air into the refrigerator.
Sep 04, 2017 | Samsung Refrigerators
PARTS NUMBER
Hello Jerry;
My name is Peter. I am a retired field service refrigeration technician.
You need to provide a model number for me to give you the gasket part number and price. The model number is on a label in your fresh food section on the upper side wall.
You have a bottom freezer, Right? These bottom freezer drawers are had to seal all of the time. They can get off track and not seal properly. It is not uncommon for them to ice up around the door gasket.
Lets try this first:
1.) Clean the gasket.
2.) With a hair dryer and a kitchen spatula, Heat the gasket while pulling gentle out on the gasket, to expand the gasket.
3.) Run a piece of paper between the gasket and the freezer front. If you can do this, then you still do not have a solid seal.
Feb 25, 2015 | Freezers
Samsung SLR550DW - replace the freezer door gasket
Hello Kev;
The number that you have provided is your general manual number, which is common to several different models.
Your model number is on the upper inside wall, on a label in your fresh food section.
I have replace many a gasket. Post your model number and I will be glad to help you.
Dec 23, 2014 | Samsung Refrigerators
Frezzer keeps icein over
Hello;
There are several things to check:
1.) Door Gasket -Take a piece of paper. With the freezer door closed run the paper around the gasket. If you can do that, then you are not getting a good seal.
Repair: Clean the freezer door gasket with soap and water. While still wet, take a hair dryer and a spatula, going around the gasket, heat the gasket while pulling the gasket out to expand it.
Note: This only solves the problem if there is frost in the front area of your freezer.
2.) Freezer fan not working - In some cases, The freezer fan helps to prevent warm air from getting into the freezer.
3.) Food Storage - Make sure you do not overload the freezer, and that the food product is inside the bounds of the racks.
4.) Fresh Food Section Air Vent Wide Open - This is your probable cause: Heat goes to Cold like a magnet. When you open your fresh food section door and then close it you are forcing warm air up the vent that goes to the freezer. You probably have a broken air vent assembly.
Oct 08, 2014 | General Electric Top Freezer 21.0 Cubic...
Jenn-air gasket is hot
The refrigerator portion is fed cold air from freezer section to cool it. Check for the freezer fan and/or the damper mechanism that directs air into fridge compartment for proper operation.
Sep 03, 2017 | Jenn-Air Refrigerators
ICE DOOR SEAL IS LOOSE AND NOT SEALING CAUSING FROST BUILDUP
This is the step you will use to repair your ice door seal that is loose.
There are screws under the fold of the freezer door gasket that holds the brace for the gasket in place. Lift the rubber gasket to expose the screw head, one section at a time. Just loosen the screw, and do not take it completely out.
As you loosen the screws, one section at a time, carefully remove the old gasket. At the same time, fit the new gasket into the groove. Make sure your new gasket is lined up properly.
Continue around the freezer door, unloosening the screw, taking out the old gasket and fitting the new one in.
Tighten the screws into place. This may have to be done once the entire gasket is fitted into place.
Check the seal by closing the door. You should have a nice, tight seal.
Good luck.
  • Step 4 Tighten the screws into place. This may have to be done once the entire gasket is fitted into place.
  • Read more: How to Fix a Freezer Door Seal | eHow.co.uk http://www.ehow.co.uk/how_4855248_fix-freezer-door-seal.html#ixzz0rY7rn3O8
  • Step 3 Continue around the freezer door, unloosening the screw, taking out the old gasket and fitting the new one in.
  • Read more: How to Fix a Freezer Door Seal | eHow.co.uk http://www.ehow.co.uk/how_4855248_fix-freezer-door-seal.html#ixzz0rY7gYaZ2
  • Step 2 As you loosen the screws, one section at a time, carefully remove the old gasket. At the same time, fit the new gasket into the groove. Make sure your new gasket is lined up properly.
  • Step 5 fix-freezer-door-seal-1.5-120x120.jpg jQuery(document).ready(function(){ jQuery('#jsArticleStep5 span.image a:first').attr('href','http://i.ehow.com/images/a04/k5/eg/fix-freezer-door-seal-1.5-800X800.jpg'); }); Keep the gasket clean to last longer. Check the seal by closing the door. You should have a nice, tight seal.
  • Read more: How to Fix a Freezer Door Seal | eHow.co.uk http://www.ehow.co.uk/how_4855248_fix-freezer-door-seal.html#ixzz0rY7JfY8i
    Jun 22, 2010 | Refrigerators
    Fridge working not cold no freezer section
    first you should check the termostate how much temp you keep.then if your compressor is working properly so check the refrigerant in system.it may be more chances lake of the refrigerant.oil increase in L.P side.you also should check the thermostate is proper working or not.chaces of low pumping in the comp.either door gasket likage or freezer door ofently open.
    Feb 25, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
    My freezer door pops open everytime i shut my refrigerator door
    Good day,
    First, make sure the gasket including the bottom is clean, as well as the mating surface of the machine itself.
    The machine itself should be checked for being level. Side to side, if it's a top freezer model, the hinge side cannot be lower than the other side.
    As well, front to back it should be leveled but with a slight tilt to the rear to assist in closing.
    If none of this helps, then the magnets in the gasket itself have gotten weak and the gasket needs replaced.
    Notes: Heavier items keeped in the freezer door will help to a degree. Closing the door slower as well.
    The reason this happens, is that with the main door open, then closed, a large volume of air is forced into the fresh food compartment. There are vents that are open between the freezer section and fresh food compartment. This large volume of air when closing the main door is compressed into a smaller area, causing the problem.
    Feb 16, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
    Having a hard time finding gaskets for the refrigerator and freezer doors for Amana BX20QW. Do you carry them and is there anything I should be aware of in doing the job myself?
    Hi, Part # 67003551 is the freezer gasket in black. What color do you need and could you get the exact model # off the label inside the fresh food section. There should be another letter at the end.
    I can get you gasket #
    Vic
    Jul 04, 2009 | Amana ABB1927DE Bottom Freezer...
    Door gasket for Kenmore upright freezer model 2539239712
    Aug 08, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
    Refrigerators Logo
    44 people viewed this question
    Top Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
    Marvin
    Marvin
