Question about Kenmore Elite Oasis 27052 Top Load Washer
How do I get the top off/or open to get to the tub? Making a funny noise like there maybe a necklace or coins stuck!! makes this noise when really spinning
    Novelist:
  • 127 Answers
There are hidden spring releases about 2 or 3 inches in from each left and right corner under the top. you need a narrow putty knife to push and find them, but you push in towards the rear of the machine to release them, then lift the top as you do..
good luck, have fun.
Posted on Aug 04, 2010
Kenmore he3 dryer front load knocking noise
Check the tensioner pulley that keeps the belt tight. It is next to the motor and the bearing may be shot.
Mar 08, 2014 | Kenmore Dryers
While in spin cycle our washer is making this noise like metal balls clanking together. I thought maybe the washer was out of balance, but it wasn't. My husband thinks it's a bolt or a penny that's stuck...
Yes, your husband is correct, it is coins. There is a filter trap at the bottom of the tub. You can access this after removing the rear panel. My husband pulled 45 cents worth of coins out of ours. You will need to disconnect a hose and remove a couple of screws to get to it. Hope this helps. This has been just one of the many problems we have had with this machine.
Oct 17, 2010 | Kenmore Oasis HE 27082 Top Load Washer
My washing machine is making a funny noise when it spins
well this is not very help full, funny noise's? hhmm? ok, cat stuck in the drum? no? lets try the bearings wearing out or braking up? broken spider? yes i did say spider, its the bit that holds the back of the drum to the driving shaft!! maybe you left a coin in a pocket and its found its way behind the drum, lets hope it dont find its way into the pump as well! broken suport springs? any number of other things????? but as for funny noise's,,, im stumped now,,oh, yes, just the one spring's to mind! my dog snores??? but he's no a very good washing machine!!!!!!!!!!!!!
Oct 20, 2009 | Washing Machines
Front load washer makes funny noise when pump turns on
The pump sounds like it may be plugged wih a coin or something like that. If the pump is plugged it will make a funny noise. Remove the pump and clear everything out of it
Jun 07, 2009 | Frigidaire Affinity ATF6000F Front Load...
Whirpool Duet Sport Washer still making noise now it s leaking
make sure to look really close all it takes is alittle whole in that seal anywhere to cause a leak try to look close while it is running but first dry everything you can and then run it. also make sure your door glass is clean if it is leaking down the front just alittle dirt or hair can cause a leak aswell
Mar 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirpool Duet Sport Front Loading Washer is making a funny noise
open top cover (two or three screws on rear and slide back) and look at rear of tub checking clearance to rear panel and nothing touching belt or pulley. whirlpools tend to have a high pitch low volume whine anytime motor operates.
you really dont want to replace that bearing. part of tub assm. $400 part plus labor
Mar 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer won't spin!
I doubt if that would affect it unless you got the chain between the inner and outer tub. The pump might have a coin in it. Tip the washer back,remove the belt and turn the pump by hand to see if it is locked up.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 21, 2009 | Maytag PAV2300 Top Load Washer
LOCK AND LOAD ISSUE
can you be more specific about the funny noise. When does it occur, during agitation or during spin? something might me stuck in the drain area of the tub and as the tub rotates it rubs against it.
Jun 28, 2007 | GE WSXH208A Front Load Washer
Kenmore Elite Oasis 27052 Top Load Washer Logo
137 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
