Question about Hoover F7431-900 SteamVac Vacuum
F7425-900 hoover steam vac
The water won't shut off. it sprays water all the time. detergent is still on demand and works fine.
is there a valve for the water that might be stuc open ?
    President:
  • 1,673 Answers
There is a valve at the bottom of the tank, push it in and see if it goes in and out ok. The tank sits on the reservior asm., a rod in the handle pushes it when you squeeze the trigger. You may have a problem with the rod not releasing or a bad reservior asm.
Posted on Apr 28, 2008
My Hoover steam vac dual v clean water and detergent tank leaks water before attached to the vac and during cleaning
This is a common problem with the earlier models which had a separate soap tank glued to the clean water tank. The plastic was too thin beneath the valve on the clean water side and would develop cracks. You most likely will need a new one piece tank. ( Part # 42272104)
May 21, 2011 | Hoover Steam Vac Dual V w/ SpinScrub...
Hoover steam vac dual v carpet cleaner has stopped dispensing soap. Water is still flowing fine
You probably have a solenoid valve which has failed and will not open. This will require replacement of the valve. For temporary use you can mix a soap solution and put it in the rinse tank. The correct mix is 5 ounces of Hoover shampoo to a gallon of hot water.
May 17, 2011 | Hoover Steam Vac Dual V w/ SpinScrub...
Hoover Dual V steam vac model F7425-900 won't dispense detergent
Check the spring loaded valve at the bottom of the detergent bottle.
Push it up with your finger or a pencil or some such thing and see
if fluid comes out. If it does, then the problem is the valve or tubing I
would suspect.
Tom
Oct 22, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Hoover steamvac won't spray water/cleaning solution
Clogging of the pump that sprays water/cleaning solution is very common in Hoover and Bissell Steam Vacs. Try running a cycle of 1part vinegar or CLR to 3 parts warm, distilled water through the vacuum pumps. The heads get clogged with soap and the water pumps get clogged at the opening of the flash heater due to minerals in hard water. If you want to extend the life of your steam vac, don't use the heater unless you are using distilled water. This can get expensive, so I recommend not using the heater.
Sep 11, 2009 | Hoover F7431-900 SteamVac Vacuum
Hoover Steam Vac clean water tank valve leaks
a) make sure that there is not a place for a stair attachment. If
there is make sure air is not leaking through where the attachment goes
on because of damaged or misplaced fitting.
b) some steam vacs leave water behind them and **** up in front of
them. If you just walked forwad with the steam vac nothing would be
sucked into the tank.
c) try taking your finger off the trigger and using the steam vac. If
the tank still empties the trigger is stuck open.
d) try putting clean water in the dirty water tank only and using it on
a dry rug. If water goes somewhere from the dirty water tank you have
a leak.
e) take apart what you can and look at the parts. A good visual
inspection can solve many of these types of problem if you are careful
not to miss anything.
Nov 06, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover steam vac
in most cases you will need to replace the dirty water tank assy. this is usually around $40 to $50.
Aug 14, 2008 | Hoover F7431-900 SteamVac Vacuum
We purchased a Hoover Steam/Vac (F5915-900) cleaner. We assumed it be a combination STEAM and Vacuum machine. Where is the Steam? I will await your reply. Thank You.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=761645
Generic problem for all Vacuums
Posted by hjopmi on Jul 09, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. I have a similar Hoover “SteamVac” and the vacuum does not create steam as you stated, but you do have to use the hottest water with cleaning solution and the Hoover will clean your carpet by spraying down the solution, the scrubbing brushes will loosen the dirt and the vacuum will pickup the excess water until the holding tank is full and then you have to empty it, and then start again. The word “Steam Vac” is something that the Hoover factory labeled but so far I have not seen anything that actual produces “Steam” while cleaning. Feel free to contact the Hoover factory with your complaint @ the information listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 09, 2008 | Vacuums
HOOVER F7430-900 STEAM VAC
I recommend to use the same detergent that came with the machine. Some detergents can cause problems such as damaging seals and causing build up. Hope this helps, post back.
Jun 23, 2008 | Karcher DE4002 Steam Vacuum
Vacuums Logo
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
