Question about Bissell 1698-1 PowerSteamer ProHeat Plus Upright Vacuum
Bissell Proheat will not disperse water. Any suggestions
  • Bissell Master
  • 43,501 Answers
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
cm
Posted on Sep 30, 2010
Cleaner will not disperse water or solutiion
Hi Frances,
Please see the link below to the Repair Guide for the ProHeat 2X. This will help you diagnosis the problem you're having with solution not dispersing water or solution;
Bissell ProHeat 2X Repair Guide Troubleshooting and Repair Instructions
I hope this was helpful to you. If you have any further questions, or would like some additional help, please just ask, I'm happy to help you further.
Oct 06, 2011 | Bissell 9500 ProHeat 2X CleanShot Upright...
BISSELL 9500 PROHEAT MACHINE IS NOT DISPERSING WATER, CARPET NOT GETTING WET. HOW CAN I FIX THIS?
heatman101
try
Sep 14, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
My bissell proheat wont disperse water
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
heatman101
May 29, 2010 | Bissell 1698-1 PowerSteamer ProHeat Plus...
Hello.....my Bissell pro heat pro tech does not disperse the water....would you know why
heatman101
eytyet
May 21, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
The water won't come out. The carpet is still dry after repeatedly pushing trigger to dispurse water on carpet.
If it will not disperse water then that means that the pump belt needs to be replaced. Here is the belt you need:
Proheat pump belt
May 18, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
I have a Bissel Proheat Pro-tech. When turn ON the motor running but not work. The belt still good but tho rotor not turn. Please help me to fix.Thanks
Is this the carpet cleaner Proheat?
I have a Proheat 2X and it wouldn't disperse water unless I used the Water Rinse setting. I found water came out and was suctioned properly, but on the Light Clean, Normal Clean, and Heavy Traffic settings, the unit failed to do anything. Problem may be with leaving the soap dispenser in-place, which might scum up the tubing.
SO, an alternative to throwing out my unit and buying somethign else was to put one capful of the Bissell soap in the water resevoir and keep the unit on Water Rinse. IT WORKS BEAUTIFULLY NOW. Don't know if this will help, but at least I didn't have to buy a new unit. Rinse everything after using and there's been no problem.
Apr 23, 2010 | Bissell 9200 Upright Vacuum
I have a bissell proheat turbo 2x microban steam
heatman101
hgkklgh
Feb 02, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
I followed directions no water will come out
When water doesn't disperse that means that the pump belt is worn, stretched or broken. You can get belts and view the manual here:
Bissell ProHeat Belt and Manual
Dec 04, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
The water doesn't come out. I've taken it apart
The reason the water is not dispersing is because the pump belt is probably stretched or worn. You can get belts and view the manual here:
Bissell 1699 ProHeat Belt and Manual
Dec 03, 2009 | Bissell 1699 ProHeat Clear View Upright...
Bissell 1698-1 PowerSteamer ProHeat Plus Upright Vacuum Logo
153 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
