Question about Andis T-Outliner Hair Trimmer
My T-Outliner trimmer is making too much noise. how can i reduce this amount of noise? Thank you
My new andis t outliner making a loud noise
The Andis T-Outliner that you purchase from the USA is not for UK voltage 220 50 HZ, the Voltage is too high, the only way to control the voltage is transformer from 220V to 120 V. The Andis Trimmer that may work for you is the GTX trimmer this trimmer was manufactured for Canada and there voltage is 220V 50HZ.
Manny's Sharpening 323 237-2885 f175053b-23eb-4546-bbc5-bb86bc86dcf9.jpg Manny Mobile Sharpening and Clipper Parts Supplies
Mar 04, 2014 | Andis T-Outliner Hair Trimmer
Andis t outliner is making a loud noise someone help please?
This unit will not work correctly in the UK as it has a magnetic motor. No matter how you try to tune it it will be very loud and eventually the motor will burn out.
Brand new andis trimmer pulling hair and not cutting good
The questions about Andis T-Outliner or Andis Styliner II, about not cutting or pulling hair.
On the Andis T-Outliner trimmer if the sharpness of the blade is worn out, all the tricks and treats won't make this blade to cut hair. Before I do any kind of work to the trimmer, I first test the coil for the right amount power, I can get out of the coil, without this power, it doesn't matter how new or old the trimmer is, the trimmer will not cut hair at all. If the coil is good, I will sharpen the blade and set it according to your needs (lineups or shave setting) after the blade is sharpened and set. The trimmer will need to be, adjusted for alignment to the blade, adjust the power of the coil, and adjust the tension for the blade. All these factors are involved in the Andis T-Outliner to cut hair clean especially lineups or shaving. These adjustments work together for the trimmer to work properly. I know that we all trying to save money, which is part of life, but sometimes frustration will take over and say hell with it, I'll buy another or forget it. Manufactures make mistakes, sometimes the trimmer was not sharpened or adjusted correctly. Any case, what I'm trying to say here, if you try all the tricks & treats and can get your trimmer to work, it may be easier for you to send it to a professional to sharpen & repair the problem and set the blade according to your needs (lineups or shave setting) We specialize on Andis T-Outliner Trimmers. Our complete sharpening & repair service is $19.99 each trimmer, this includes return shipping. We sharpen the blade, adjust and set the blade according to your request (Lineup or Shave setting) make all the necessary adjustments for alignment, power, tension to make your trimmer work better than new. Our mail order service is one day turn around. We are well known throughout the United States for our service in sharpening. Check us out at www.mannys-sharpening.com or call us at 323 237-2885. Service You Can Trust Since 1990. Manny Mobile Sharpening and Clipper Parts Supplies
Nov 26, 2013 | Andis T-Outliner Hair Trimmer
Andis outliner ii
OHOHOHOH
It is always the same to be careful of el. current in different countries.
By my experience I would think that the trimmer will not recover from the exercise.
I hope I am wrong
Kolbrun
Feb 25, 2012 | Andis Outliner II Hair Trimmer
My andis T-outliner is makeing a loud noise
The problem you describe is most likely due to the fact that the machine you bought is designed to operate on 110v/60Hz electrical supply as used in North America. In fact the T-Outliner is only designed to operate on 110v/60Hz so even if you use a transformer you will only convert the voltage from 110v to 230v. You will not convert the frequency 'Hz' from 60Hz to 50Hz which is necessary with an electrical product with many moving parts such as a clipper to operate correctly on the European electrical supply which is 230v/50Hz........Check on ebay 'Voltage and Frequency Converter' about 65 pounds. The only solution
Nov 20, 2009 | Andis T-Outliner Hair Trimmer
Botton don't work on trimmers
Please send your trimmers into the Andis Co at 1800 Renaissance Blvd Sturtevant WI 53177. We will be able to repair your trimmer for you. If you would like to speak with a customer service rep first please call 1-800-558-9441.
Thank you,
Jul 24, 2008 | Andis Outliner II Hair Trimmer
Andis T-Outliner
adjust the brown plastic on the blade all the way up.remov the blade and the brow plastic is held with screws
Apr 23, 2008 | Andis 04603 Hair Trimmer
Andis T-Outliner Hair Trimmer Logo
234 people viewed this question
Top Andis Health & Beauty Experts
Anglia Clipper...
shaveroutlet.com
shaveroutlet.com
Kolbrun...
Are you an Andis Health and Beauty Expert? Answer questions, earn points and help others
