Question about Car Audio & Video
I have an audiobahn sn-ma2 model a2401x. the cooling fan in it shorted out and i have to replace the black and red wires but where you are supposed to soder the wires back into the circut board. it is melted so my question is, is there a way to wire the cooling fan directly to the main power supply so when the amp turns on the fan will turn on and when the amp turns off the fan turns off?
  • 3 Answers
U put the red wire to the remote and the black to the ground thats the best way good luck
Posted on Mar 11, 2011
I have a Fedders air conditioner but cannot tell if it is 110 or 220. the numbers are 146y and SN #141448
Well 110 v will have black, hot, white, neutral and green for ground. 220v usually will have black, hot, red, hot, white neutral wires. hope this helps.
May 20, 2017 | Fedders Heating & Cooling
Wiring problems
Looking at this from a purely wire color stand point, you have a 220v motor and a 110v motor. What are the model numbers on the unit, and each motor?
Dec 18, 2017 | Heating & Cooling
I have a hunter with 3 wires black white green how do I wire it to a three wire cable black red white ground the fan also has a light and remote but remote is Brocken want to use it with no remote model...
Black to Black - White to White, Green to Green (copper). Put a wire nut on the red wire.
The Black is suppose to run the light (or the fan) while the Red is suppse to run the fan (or light). The White is common and the ground is ... well the ground.
If you have a light kit on the fan, you can control the light and the fan separately ... or you can run them together.
Let me know how this comes out ...
Thanks for your question @ FixYa.com
Jun 29, 2011 | Vacuums
Need to know what the four wires are for, red black yellow and blue, I am wiring it to and ancient apple, no choice. just need to know how to set it up at hi speed constant operation. I am using a rf-120...
Usually the red is +12 volts DC, the black is ground, the yellow is the tach sensor, and the blue is speed control. The fan will run at full speed off the red and black. The yellow and blue are of no use unless the motherboard is designed to use them.
Mar 29, 2011 | Rocketfish Gaming 120mm Case Fan RF-120FAN...
2001 Neon cutting out, but only in the heat of the day
SOUND LIKE ENGINE RUNNING HOT.MAKE SURE COOLING FAN TURNING ON. WHILE ENGINE IDLING WATCH TEMP GAUGE AS THE TEMP CLIMB COOLING FAN SUPPOSE TO TURN ON IF NOT.CHECK FAN FUSE AND RELAY. IF BOTH GOOD HOT WIRE IT. NO RUN REPLACE FAN MOTOR IF FAN MOTOR DO RUN. YOU COULD HAVE A FAULTY COOLANT TEMPERATURE SENSOR OR SHORT IN FAN CONNECTOR OR WIRES. CHECK COOLANT LEVEL.MAKE SURE YOU HAVE 50/50 MIXTURE OF WATER AND ANTIFREEZE.TO BE ON SAFE SIDE REPLACE THERMOSTAT AND PRESSURE CAP.
May 30, 2010 | 2001 Dodge Neon
Gateway laptop shuts off even when plugged in
Well, I'm not exactly sure if it is the cooling fan (you would have to see if its working), but it definitely could be an overheating problem. Another problem could actually be the battery, even if you have it plugged in, the battery can still cause it to shut down. If your computer is able, I would try using it without the battery and see what happens. And I believe that the cooling fan will fit. Here is a good site to help you troubleshoot your problem
Feb 24, 2010 | Gateway MT3705 Notebook
Exchange a cpu fan connector
You can connect it red to red; black to black; and yellow
to white. That's it. Hope this will help you.
Dec 12, 2009 | R.A.M. Computers 486 CPU COOLING FAN WITH...
Replaced fan relay but now lowing fuses
This might be a ground wire loose somewhere. Or a hot wire exposed to a ground. Electrical problems are the worst part of a car to fix. Try to replace just the wires or the entire harness to the fan relay.
Hope this helps.
Aug 23, 2009 | 1992 Volkswagen Jetta
Replaced cooling fan relays,the cooling fan
check temp sencer wire at bottom of raditor
Jun 04, 2009 | 1989 Buick Regal
Fridge Heats but dosen't cool
This fridge uses a Peltier effect cooler sometimes referred to as a TEC or "Thermo Electric Cooler".
In order to cool it must be able to dissipate heat and it sounds like the fan in the back that it uses to do this has failed.
Replace the fan with an 80mm by 80mm 12v computer cooling fan and make sure the fan blows the correct direction.
The fan will have small arrows stamped into it on one of the 4 sides indicating the direction of rotation as well as the direction of air flow.
NOTE: You can use a 3 wire fan (yellow, black, red) if that is all you can locate, just don't connect the yellow tach wire (the wire that reports fan speed to the motherboard of a computer).
Good luck and have fun.
Mar 25, 2007 | Sharper Image (SI714SL2) Compact...
Car Audio & Video Logo
250 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
