Question about Dryers
Hi, My gas dryer has no heat. I checked and do not see any spart on the ignitor. How do I know it is gone bad? Could there be something else that could stop the ignitor from sparking. A fuse etc.. I want to check before I buy a 28.00 part and that is not it.
  • Dryers Master
  • 43,501 Answers
First off, please list the model and make of your dryer so that we can help you better....
That being said...most modern dryers do not have a spark ignitor but rather a hot surface ignitor that just glows red and ignites the fire...so you will see no spark...
If it is not glowing it isa bad and needs to be replaced... actually they can glow and still be bad for that matter...
Here is a tip that I wrote about the dryer ignitor problems...
Gas DryerHi,
My gas dryer - 2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
heatman101
Posted on Aug 04, 2010
Kemore 80 series gas dryer runs but no heat. I have seen 3 differnt solutions, how do I know which one to do? The gas valve solenoid, the thermal fuse or the ignitor????
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 18, 2011 | Kenmore 72802 Gas Dryer
It works but the heat has gone out.
heatman101
Apr 16, 2011 | Dryers
My dryer just quit heating in the middle of of a heat cycle. checked for vent system lint clogging but air flow seems good. the whole gas valve system doesn't seem to operate now. is there a thermal fuse...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 12, 2011 | Maytag SDG2606A Gas Dryer
My dryer stopped heating and spinning in the middle of a cycle of laundry. Is this the element that has gone bad?
heatman101
Nov 20, 2010 | Estate EED4300TQ Electric Dryer
Dryer is a Kenmore Heavy Duty 80 series electric. Runs fine but very little , and often, no heat. Is the element gone?
heatman101
Nov 20, 2010 | Dryers
I have a gas dryer, modle number mdg9700aww.There is no heat. drum rotates and fan works. Checked the heat sensor and ignitor and both work. The dryer heats intermittantly when the back is opened up....
heatman101
Nov 05, 2010 | Maytag Neptune MDG9700A Gas Dryer
Dryer works but heat is gone. Any advice?
heatman101
Oct 14, 2010 | Maytag Neptune MAH5500B Front Load Washer
No heat.I checked the vents and everythign is clear. Is the heating element gone?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 02, 2010 | Whirlpool LEQ9858P Electric Dryer
Ignitor? dryer runs through cycles, but NO heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
gfgf
Oct 16, 2009 | GE DBL333GB Gas Dryer
Dryers Logo
Top Dryers Experts
Marvin
Marvin
