Question about HP Pavilion a305w (DM181AR) PC Desktop
How do I remove the CD drive and install a new one? lynnwood@kctc.net
  • 21 Answers
Switch off the pc and unplug from AC. remove screws at the back of ur case( located vertically on the slide case). remove both right and left covers and look for internal cables i means power, ide or sata cable. remove them and remove the screws of ur drive and pull it in front and in the same spot push ur new drive in the same place. replace the screws, reconnect cables, power,ide or sata. then place side covers and make sure to have tighten all power and internal cables to their slots well.
Posted on Aug 04, 2010
Requires hdd password
Get started with this 3 simple steps:
Website: http://lost-password.net/products/windowspasswordrecoery.html
Step 1 - Download windows password recovery utility and install it.
Step 2 -Burn your Windows Password Reset CD:
To burn your CD, you'll need a blank CD-R and the .ISO file of Windows Password Reset.
Step 3 - Put in your newly created CD and remove your Windows password
Mar 17, 2011 | Toshiba (HDD2181) (hdd2181-50pk) 30 GB...
The problem is not with this computer, It's with a dell laptop and it is not mine, the trouble with it is the CD\DVD driver never worked since it was new and the fried did not know anything about computers...
First, I would try an external cd rom and see if it works. If it does then that means that the drivers or the drive itself is bad. If there are drivers for this drive then try to install them. If it did not come with drivers (most of them don't only the older ones) then replace the cd\dvd drive. It's pretty easy to do but you have to take the machine apart. Usually it's a matter of taking the keyboard off (the screws for the cd rom are found under the keyboard) removing the two screws that hold the cd/dvd rom drive on and applying a little pressure on the drive to remove it. Perform the opposite operation to install the new one. The new drive will run you around $30 - $35 or less if you can find one on ebay.
Nov 25, 2010 | Dell Dimension 3100 PC Desktop
Just bought a laptop cheap as on trade me for extra battery was told that it was broken but fired it up and works but is asking me for a user name and password to log on to windows. can i over ride it or...
keep the laptop, hope it got a working cd-rom/dvd-drive !(if not, take-out /replace the harddisk)
-win xp has to be removed from harddisk,
the hd must be formatted so you got a blank hd to set up your new system
you'll need :
- antoher PC with internet connection and cd/dvd-burner
- a win98 installation cd or bootable savecopy of it,
- a new win-xp install cd plus cd-key
- a program called PC Wizard(download)
and a bit of time...(one night or two:-)
follow instructions:
if you can enter bios (press F1 or F2 or Del)
during booting), youre lucky...
enter bios while booting, in the menu look for boot otions or devices, change order of boot devices, so that cd/dvd-drive is 1st, then save and exit (F10)
insert win98-CD, boot from cd, try to setup win98, you'll be asked to erase/ format all data/installations/partitions
on the harddisk (drive c:,probably), do so, format the drive using the FAT32-file system,
then end installation without fully setting up win 98.
now you should have a blank disk witout any operation system on it.
now put in win xp cd, go through the whole installation process
install and run pc wizard(it'll tell you all hardware devices of the laptop)
get the proper drivers for the notebook for win-xp from the net(google might be helpful)
install them.
happy computing!
if all this did not work, remove the harddisk,(you'll have to unscrew a lot of the laptop)
replace it by a new s-ata ide-drive()and..
erh.. come again then, this is a long process as well
Jul 23, 2009 | Microsoft Windows XP Professional SP2 Full...
My CDR Drive is not working
your problem is very clear... your cd-rom is corrupted.. install new windows... im very very very sure of your problem... NOTE-do this only if your cd drive is NOT displayed in my computer.. do this....
please vote for me...im sure this will solve your problem...
Jun 27, 2009 | Compaq Evo Notebook PC n800v Presario 2800...
I AM TRYING TO INSTALL ON MY LAPTOP WHICH HAS WINDOWS VISTA
Welcome Back linda202, please folow thos step then try to installe your application Windows Vista: Click Start button, and select Control Panel. Under Programs, click Uninstall a Program. Select Microsoft .NET Framework 1.1, and click Uninstall/Change. Click Yes to confirm the removal of Microsoft .NET Framework 1.1. Re-install Microsoft .NET Framework 1.1. If QuickBooks is being installed from the installation CD, please follow steps 1 through 6: Insert the QuickBooks installation CD in the CD-ROM drive. Click the Microsoft Windows Start button and select Run. Enter the CD drive letter (for example D:) and click OK. (For Vista users: click the Windows button and type the CD drive letter in the Start Search field) With the QuickBooks installation folder open, locate and open the ThirdParty folder. Open the DotNET11 folder and double-click dotnetfx.exe.
Jun 11, 2009 | Intuit Quickbooks Premier Manufacturing &...
Unable to install Audio driver in Intel DG31PRI board for Windows 2003 server.
You can’t install DG31PRI board sound driver automatically it install manually
Go to cd room drive right click and open your main board driver cd
Then find sound driver then install sound driver manually. Click twice then
Next –next-finish.
Bibekpaul@in.com(india)
Apr 29, 2009 | Microsoft Windows Server 2003 Standard...
Lost of driver cd for ht 3250 wecam
what shoud i do to install the drives in my pc so that i can use my webcam
i m nt able 2 download from anywhere on net...n the new cd is not available
Mar 12, 2009 | Computers & Internet
DVD/CD Combo drive, removal/installation.
I believe that this model has a built in drive the only way to remove it is to remove cover to the laptop. If the drive isn't working go into hardware profiles right hand click on the drive and select remove. This will remove it from windows then when you restart windows should find the drive and install the drivers. Make sure you have the software drivers before you do this.
Thanks J
Feb 05, 2008 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Crappy computer
the solution on the cd disc is to remove the cd out then uninstall the all games installed in this cd drive replace cd drive when it comes to uninstalling sim delux is goto where saved games in sim deluxe and save folder to a different location then uninstall then re-install with new cd drive and hunt net for nc patches for games that work if this still doesn't work time for re-install windows from scratch if you have a spare hard drive use it to copy all game saves to it then redo windows and all drivers then all games then place saves back into place where they came from. good luck.
Aug 13, 2007 | Gigabyte G-MAX MA6CU (GB-GMAXMA6CU) PC...
HP Pavilion a305w (DM181AR) PC Desktop Logo
63 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
