Question about Brother Office Equipment & Supplies
I have a Brother MFC 6550MC and the error message say "SET CARTRIDGE". No matter how many times I take the cartridge out and put it back in the message stays the same
    President:
  • 3,278 Answers
Hello.
The toner sensor may need to be cleaned or replaced. Clean with a clean, soft, dry cloth.
Look under the cover for the "U"-shaped part in the rear center of the MFC.
Hope this helps.
Posted on Aug 04, 2010
MFC 9440CN does not detect yellow cartridge!!! it
THERE ARE A COUPLE OF SOLUTIONS HERE.
1) With a clean cloth or compressed air clear the sensor are on both cartridge and area around where cartridge plugs in.
2 Check for blockage in cartridge
3) Try a new Yellow cartridge
Oct 10, 2013 | Brother MFC-9440CN Multifunction Printer
Error message "put the black toner cartridge back in"
I got this same error message on a newly acquired Brother DCP-7040 that I purchased used off of ebay.
As I was troubleshooting this unit (that I bought untested off of ebay - hey gambling has paid off handsomely for me many times before!), this error message kept popping up.
I checked the COUNTERS (page & Drum life) and found out that the DRUM had 0% life left. BUT, the reason it showed ZERO was because this unit did not have any drum! The toner cartridge (TN-360) needs to sit WITHIN the drum (DR-360) on this DCP-7040 unit, as well as in models DCP-7030, MFC-7340, MFC-7345C, and MFC-7440N.
So perhaps some of these "put the black toner cartridge back in" problems could be related to the DRUM (or lack thereof). A possible tipoff (since the toner cartridge actually does slide into the unit much like other units that do not use Brother's DRUM carrier) seems to be the relative ease with which the toner cartridge slides into the DCP-7040 and really doesn't seem to "lock" into position real firmly.
DCP-7040 USER GUIDES: http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_index.html?reg=us&type2=-1&prod=dcp7040_us_as&c=us&lang=en&flang=all
Apr 23, 2012 | Brother MFC-7340 All-In-One Laser Printer
My Brother MFC-7220 shows the error message "Dust
Try cleaning the drum in the toner cartridge with a soft cloth. If this does not work then a replace toner cartridge is the other solution.
Nov 26, 2010 | Brother MFC-7220 All-In-One Laser Printer
I tried replacing the printer toner-I get a message saying "Cartridge error. Put black toner cartridge back in"
Remove the "new" cartridge, and re-insert the "old" cartridge, to see if _only_ the "new" cartridge causes the error.
Otherwise, take the printer to a qualified technician.
Jan 23, 2010 | Brother MFC 7840W Printer
NO CARTRIDGE message when new cartridge installed
Make sure there is ink in all cartridges and unplug the machine. Plug it back in while you hold the stop key and it should clear the error.
Nov 23, 2009 | Brother Multi-Function Center MFC-240C...
MFC 660CN
message says"removescanner cover,then reinstall cartridge," just renewed cartridge.
Jun 05, 2008 | Brother MFC 420CN All-In-One InkJet...
Reset drum - brother mfc-8860dn
Open front cover
Remove drum unit and toner cartridge assembly
Put drum unit and toner cartridge assembly back in machine, but do no close front cover.
Press Clear/Back
You will get a message "Replace Drum?"
Select Yes to confirm
Jan 06, 2008 | Brother MFC-8860DN Printer
Ink cartridge (not) installed properly
unplug machine from power outlet. take all carts out. wait 5 min. plug machine to power. wait until machine demands carts. reinsert carts and make sure they are secured. answer display when asked if you have changed.
If you still have the error message use a original brother cart.
Dec 16, 2007 | Brother MFC 210C All-In-One InkJet Printer
Mfc-7220 replaced starter cartridge, new Brother one gives error no cartridge
there is a new toner detect sensor left front upper inside of printer, when a new toner is put in reset lever on cart hits sensor then fall back to front of cart, remove gear asst and put lever in new position, 3/4 the way back. reinsert toner into drum and insert.
Nov 03, 2007 | Brother MFC-7220 All-In-One Laser Printer
20 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
