Question about Frigidaire Heating & Cooling
My Frigidaire AC/Heater unit model number FAS25EQ2H2 messed up during the winter when the heat unit was in operation. How would you disconnect the heat unit so only the AC will work?
The problem was in the power cord. I didn't have to disconnect the heat after all.
Posted on Apr 27, 2008
What does error code E56 mean?
That error is an E5b error. This indicates a problem with the heating element, the thermistor or the control board. You'll need to unplug the unit and access the wiring. Inspect the heating coil for breaks. Then test the voltage across the element (should see the line voltage) and check the resistance at the thermistor (should be ~50000 Ohms in a room temperature environment). If the above are okay, your control board is probably bad.
If you post a comment with the model number, I may be able to point you the appropriate parts. If your dryer is under warranty, contact Frigidaire.
I hope this helps.
May 19, 2015 | Frigidaire Dryers
How do you insulate a tankless water heater for winter
If you have tankless electric, it can simply be insulated... but tankless electric are seldom mounted outdoor.
Service bulletin says: "the only way of assuring protection is to completely remove the heater during those times the area may experience freezing temperatures.
There are tankless with built-in heater for exterior installation.
Check your manual, or add a comment with specific model number and maybe I can find the information.
Here's why they install tankless outdoors: Because tankless burn more fuel per gallon of hot water. This requires larger gas line and larger vent pipe than typical tank-type gas water heater that is usually installed indoors.
They install tankless outdoors, so there is no need for expensive vent pipe, and because there is ample incoming air to support combustion.
So if tankless does not have factory-installed internal heater, then the unit can freeze easily when the combustion draws in cold air.
Of course you can put heat-tapes on the pipes but the heat exchanger inside will quickly freeze during periods when hot water is not being used, and combustion is not taking place.
You can move the tankless installation inside and use correctly-sized vent and intake pipes directly through the wall. This will generally protect tanklesss from freezing if room is heated adequately.
Sep 26, 2012 | Rinnai Webstone The isolator EXP tankless...
We have a Weatherking Heater/AC unit the heater works and the AC worked last summer when we tried the furnace this winter no heat found out it was the 24 volt transformer replaced it and heat worked fine...
I think you have a definite short and it's in the 24 volt circuit. The only problem is - 'finding a low voltage short' is not the easiest thing in the world to do - so - I would guess you'd need a Service Tech.
good luck!
Jun 28, 2010 | Heating & Cooling
My ac blows warm air upstairs only but not downstairs in winter
Sounds like you have a zone system? Is it a bypass type? If it is the fan speed of the heater must be to slow to override the bypass damper. Wire the fan to operate at a single speed same speed as on the A/C.
Jan 05, 2010 | Heating & Cooling
My heater on 1998 Achieva is still blowing cold air after 3 thermostats and 3 different mechanics. Help! I'm going broke!
Ok, I have been in your situation. Locate the Coolant line from the radiator to the firewall, there are actually 2. One has a valve type device on it. Remove that device and replace it with a piece of straight pipe. Locate your AC compressor. Disconnect the Wires to the Compressor so it can not activate when you select defrost. During the Winter you want the heat and should not need the AC side or your system anyway. This should fix you up for the rest of the winter, in the spring re-install the valve and reconnect the AC. Also, make sure you plug any vacum lines taht are connected to that valve on teh radiator line.
Dec 12, 2009 | 1998 Oldsmobile Achieva
Front heat does not heat..but the back heat does..
your vacuum hose to the mixing valve is likely disconected
Nov 01, 2009 | 1999 Ford Expedition
Cool air not working with honeywell Model # RTH230B
Do you have a heat pump? If so, not compatible. What i did was move the jumper on the thermostat (RH RE). This is on the inside of the thermostat - NOT the red jumper!!! and got the AC working (the heat had already worked during the winter, problem only became apparent when I needed to use AC). I may have to change the jumper again when the season changes...not sure yet.
Apr 26, 2009 | Honeywell Programmable Thermostat Heater
1999 Mustang heater problem
The heater/AC temp control blend door is warped and sticking, this is a very common problem in this series of mustang, in order to fix it the dash must be removed.
Nov 17, 2008 | 1999 Ford Mustang Cobra
3ton heat pump googman 14 seer
Give me the model numbers on the heat pump and the coil, I would expect its a really poor match.
Nov 11, 2008 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
105 people viewed this question
Top Frigidaire Heating & Cooling Experts
Electrolux
Electrolux
Dan Webster
Dan Webster
Donni Steen
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
