Question about Ducane 3055MER2 Gas Grill
I want to replace the old burners with new ones
  • 2,272 Answers
The procedure to replace burners is as follows:--- Remove the GratesOpen the grill. Put on a pair of rubber gloves. Remove the grates, and set them aside. Remove any of the V-shaped metal tent pieces above the burners, and set them aside. Remove whole briquettes with your hands and set them aside. Push the ash through the small hole in the bottom of the grill; the ash will fall into the ash drawer. Use your fingers to scoop the ash into a pile, and help feed it through the hole. Pull the ash drawer out of the grill, and empty the ash into a trash bag. Replace the ash drawer.
Remove the BurnersDisconnect the wire on the back of each burner that is connected to the collector box. Remove the pins or clips on the bottom side of the burner that connect it to the bottom of the grill; you may have to get on the ground and look up at the underside of the grill to remove them. Pull the burners up gently a few inches, and disconnect the gas lines. Remove the burners.
Install the New BurnersClean out the area around where the old burners sat. Connect the new burner to the gas line, and set it down into the grill. Install the pins or clips to the bottom of the burner to hold it in place. Reattach the wires from the collection box to the burner. Replace any briquettes. Replace the V-shaped metal strips and grates.
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Posted on Aug 04, 2010
Popping of gas from new burners and going off and on
check to see if there is any packing in the burners , they could be just not in the right postion or the air mix could need adjusting .
Apr 20, 2012 | Brinkmann Charmglow 810-7400-S Propane...
Need to replace stainless steal buners. 17" long
You have to remove the front panel to remove the old burners and install the new ones.
Mar 20, 2011 | Ducane 30400040 Stainless Steel Grill
How to remove and replace burners on model 3673G-regal
Be sure the gas is turned off before preceding:
Remove the cooking grates and set off the side, out of the way.
Remove the Flame Tamer cover plates.
Looking toward to the rear of the inside of the burner compartment, you will see that the cast stainless steel burners are resting in place on top of a bracket or ledge. There is a tip on the bottom of each burner that goes into this bracket. There is a cotter pin or lynch pin that holds each burner in place. Remove the pin(s) and carefully lift the burner up and toward the rear of the grill. This will allow the burner to slide off the burner orifice and out of the grill. Before installing the new burner(s) compare the old one to the new one and match the air intake valve's opening to the new one. Most burners come preset. But, it's best to make sure. When you look at the burner where it fits over the burner orifice, you will see how to adjust it if necessary.
Now, just install the new burner(s) in reverse of the way you took the old one(s) out. It is not necessary to reinstall the cotter pin(s) or lynch pins (unless you want to), as they are on there to hold the burners in place during shipping.
Take your time and you'll do fine.
Hope this helped you. Happy Grilling!
Feb 15, 2011 | Grilling
How can I replace the burner firve for my Toshiba
remove the screw behind on you laptop the full it out. then insert the new one
Jun 11, 2010 | Toshiba Satellite U305-S5107 Notebook
How do I remove the old burners to replace with new?
Should be as easy as removing the screws at the ends of the tubes and sliding the tubes away from you and putting the new ones in like you took out the old ones.
Apr 10, 2010 | Ducane 30400040 Stainless Steel Grill
Computer will not recognized new dvd drive. Old one was broken and could not load software needed for new one. It only recognizes the old one. help
This suggests that the new drive either does not have power or the data cable isn't completely connected on one side or the other. Does the drive eject its tray when you press the button? That test confirms the power connection. Double check the data cable (consider replacing if it is seated properly); make sure it is fully seated and in the correct orientation.
You might have a bad SATA port, try other ports (if available) or a bad drive out of the box.
I hope this helps.
Jan 01, 2010 | Samsung SH-S223L 22X SATA DVD Burner Black...
My cd burner will not burn cd's. it just makes a funny sound and pops up insert disc.
If the system is not in warantee, you will need to replace the CD burner drive. You can generally find a replacement for around $30. Depending on where you live you can find one locally or online.
Replacement is very easy.
Open the system to access the old CD burner, make sure you take note of where the cables (power and interface cable). Remove the old CD burner and replace it with the new CD burner replacing the power and interface cable.
If I were you, I would op for a CD/DVD burner so that you can read and write both CD;s and DVD's. Cost should be around $40.
Jul 14, 2009 | E-Machines emachines (emachinees) CD-ROM...
Burner stops cycling-stays red on medium
Kinetic,
The dial you're talking about is called an "infinite switch" and the burner only does as it is told to do by this switch. Since you'r having issues with it, I can guarantee that it's the switch that giving you grief and needs to be replaced.
You didn't mention which burner is the problem, but there are only 2 inf. switches for this machine.
Small Burner Large Burner
P# 7403P238-60 P# 7403P239-60
Easy to replace and the bonus is that which ever one you need, the cost is ~$45.00!
All you gotta do (after you have the switch) is to pull the oven out so you can get behind it to work. If it's plugged into the wall UNPLUG IT! If it's hard wired and there is no plug, go outside to your main breaker panel and kill power to the oven.
Now remove all the screws holding the aluminum rear control panel cover and set it aside. You'll now see all the inf. switches. DO NOT REMOVE WIRES FROM THE FAILED SWITCH JUST YET! Remove the knob from the failed switch, under there you'll see 2 screws holding it in place... remove these AFTER you have noticed which direction the "D" shaped shaft is oriented (is the flat side of the "D" at the top? the bottom? the side?)
Now you have the old one out... still without removing the wires from the old one... install the new one with NO wires connected just yet. Now.... pull one wire at a time from the old one and place it on the EXACT terminal on the new one. Do this for each of the wires until the old one is bare and the new one is loaded with wires.
Replace the rear panel, push it back in place and fire it up!
Easy-Breezy... in and out in less than an hour.
SG
Apr 14, 2009 | Maytag MER5751A Electric Kitchen Range
I want to replace an erratic element on a really old Viking stove. The new element plugs into a new recepticle,but the latter has 2 wires, whereas the old stove has 4 wires that were connected directly...
This can't be done. The old elements were a two part element with 2 seperate coils. The heat was controlled by using one or both elements at different voltages to select the heat output. The new 2 wire element just pulses the current on and off to control heat. It is just one big element. Try to purchase a generic replacement burner that will fit the hole. Usually these come with the chrome ring and everything. They are somewhat adjustable but will not match your existing burners. GE used to make this. Another possibility is if the control to the burner is a knob that turns, Replace the switch with a new infinate heat switch. If this switch will mount properly. Just grab the two 220 volt legs from the old switch, Ignore and tape the neutral, ground, and pilot leads. Connect to the line side of the switch. Use only 2 of the old wires going to the burner and connect them to the new one.
Jun 29, 2008 | Kitchen Ranges
Ducane 3055MER2 Gas Grill Logo
48 people viewed this question
Top Ducane Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Marvin
Marvin
Are you a Ducane Grilling Expert? Answer questions, earn points and help others
