Question about Nakamichi PA-506 Car Audio Amplifier
Nakamichi pa-506 amplifier missing manual!
Where can i get one?
  • Anonymous Apr 30, 2008
    Where can I get a manual for a Nakamichi PA-506 amp?
How do I connect a Yamaha DSP-E800 amp to a Nakamichi RE-10 amp?
The Nakamichi would be your main channels, so the line out of the Nakamichi would go to the audio processor inputs of the Yamaha, and the original source would plug into the Nakamichi.
Mar 24, 2012 | Yamaha Audio Players & Recorders
I need a Nakamichi subwoofer amplifier for my '91 Lexus LS400.
I found a few on eBay with this link...all others are out of stock but I'm sure you knew that.
http://shop.ebay.com/i.html?_kw=nakamichi&_kw=amplifier
Jan 05, 2011 | Pioneer GM5400T 2-Channel Bridgeable...
My amplifier doesn't works! I live in Portugal,
If you put in another request to FixYa this time saying "Nakamichi Amp (insert model number) service manual wanted". Somebody on the sight might help you.
Alternatively if you are willing to pay a small fee, I haved used "Manuals-in-PDF" and found them very good.
Jan 11, 2010 | Audio Players & Recorders
Radio will not stay on fm
the wiring on the radio must be exposed cause them to touch and weird things to happen like your situation or there may be a defect in the radio my friend had the problem and i had to take apart the radio and reconnect a few wirings and change a few parts
Apr 21, 2009 | Nakamichi PA-2002 Car Audio Amplifier
I do not hear any music through my 10" M Audio Subs (M Audio Sound System)
If you know how to use a multimeter, you can test the amp this way:
-unhook the subs
-hook up a cheapie speaker you know for sure works to one of the channels
-unhook the audio inputs
-turn the amp on
-set your meter to VDC
-put the positive probe on the inside of the input connector, being sure you make contact with th inner contact
-take the negative probe and tap it on the outside of the connector
What you are doing is sending a low voltage (replicating an audio signal) into the amp audio circuit and allowing the amp to amplify it. If the amp makes the speaker pop each time you strike the probe, the amp is working.
You mentioned you need a 4 channel amplifier make the two, dual voice coil subs operate. The is not true and by hooking them up like that, there's a chance of damaging the subs. The reason is that the dual voice coils are interwoven and they have to get electrically identical signals or they fight against each other. The can mechanically fail, then, electrically fail, then even damage the amp too.
Nov 21, 2007 | Nakamichi PA-504 Car Audio Amplifier
Channel 2 volume is very low
You can check if channel 2 is blown by switching around your RCA plugs. If you are using the speaker wires as high power inputs you can change them. I.E. swap the left channel with the right one. I assume you checked the gain control on the amp. If channel 2 works with channel 3's inputs then its your head unit or the wiring. If you are lazy take the amp to a car audio store and ask them to bench test it for you. Hack
Jul 13, 2007 | Nakamichi PA-504 Car Audio Amplifier
1990 Lexus LS400 Nakamichi Car Stero Amp problems
if the amp is damage it needs to be repaired or replace but the age of any amp doesn't matter, all are compatible to work.
Jun 18, 2007 | Nakamichi PA-2002 Car Audio Amplifier
Car Audio & Video Logo
439 people viewed this question
Top Nakamichi Car Audio & Video Experts
Aaron Hackbarth
Level 1 Expert
Jaime Hernandez
Mohamed Ismail
Mohamed Ismail
Are you a Nakamichi Car Audio and Video Expert? Answer questions, earn points and help others
