Question about AmcorAire UCHW-H12AF2 Split System Air Conditioner
Hello unit has been running then just stop with F1 showing how can i fix this thanks cameron
  • 73 Answers
The F - 1 error code shows a failure of the PFC & IPM circuit boards inside the outdoor unit.
We stock a complete line of Amcor parts.
Support@Pridiom.com
201-266-8234 option 2
Posted on Jan 04, 2011
Stopping after start with F1 error
Hi
Thanks for using FixYa. Error code F1 indicates primary control failure and to resolve this you'll have to replace the machine control assembly. Yes you are right, this error should be fixed by whirlpool as its a common issue with whirlpool Cabrio washers, you can call 1-800-253-1301 whirlpool will send a tech. to fix it and pay for the part. Please rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Oct 11, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Display shows F1
The F1 code is an error code indicating that there is a loose of wire from it position or an over flow of liquid substance in the sensor /panel reading error i.e F1
what you need to do to fix up this problem is to unscrew the range with bass tools then clean up all form of liquid around the lens ,panel and also the wires and fix up the loose wire if any please do this with care in other to avoid more damage on it and while doing this DO NOT USE WATER or AND LIQUID substance in cleaning use only clean rag to do this service then allow it to dry up for some time then couple it back to it position with this the problem of f1 code is solve.
Thank you and thanks for using fixay.
Sep 10, 2010 | Dacor ER36D Stainless Steel Island Trim...
F-1
According to the manufacturer instructions the "F1" error code means a primary control failure. The correction is to replace the machine control assembly.
There is a recall on the unit - sometimes they will cover it even out of warranty.
Here is the number to call:
1-866-698-2538
ALSO - SEE THIS popular thread about the F1 error.
There is a SMALL chance something is clogging the pump (small sock toy etc.) SEE HERE for all possibilities to the F1 error
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 02, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Oven problem
Hello,F1 means the circuit board is defective and you need to replace the control board.
Thanks
May 31, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Gas range beeps non stop and the panel shows F1
Hi bobctsai,
F1 error code description is a defective touch pad or clock (ERC). To resolve this error, replace touch pad or clock (ERC). Touch pad is a more common problem.
Hope it helps.
Thank you for using FixYa.
Apr 23, 2010 | Magic Chef 31000 Gas Kitchen Range
Electric Range.-oven stopped working. Error Code F1 show on electronic display
Hello there:
Here is the 2 most common f1 codes for this oven and what the problem is and what repair procedures that should be taken
F1 Defective touch pad or membrane Replace touch pad or membrane (this problem is usually the touch pad) F1 Watchdog on board Replace touch pad or clock assembly (also called the ERC)
Dec 13, 2009 | Jenn-Air JGR8850 Gas Kitchen Range
Hi Both drawers show error F1 flashing beeping with rinse light on and both pumps run after power is applied to machine
F1 error indicates flood switch in base has activated, meaning machine has leaked. This causes machine to drain continously, and can only be stopped by switching off power. Not easy to fix if you don't have experience- bottom drawer has to be removed to access flood switch, then machine needs to be test run and checked for leaks. Best to call the professionals!!
Oct 03, 2009 | Fisher and Paykel 23 in. DD603H SS...
Clock
What country are you in. This model does not show up in Kenmore USA
Perhaps you gave me the serial number by mistake, rather than the model number?
Dec 21, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
F1 Error Code
According to the GE website, F1 usually means a problem with the keypad. You might try my solution for the F7 problem which is similar in nature. Go to the following link:
http://www.fixya.com/howto/h155060-dreaded_f7_error
I have shared my solution with more than 1900 folks and most report success.
Please let me know if it works for you at:
hutchipop@yahoo.com
Good Luck,
Powerman
Jul 16, 2008 | Ovens
Sharp ar-163 model Error code F1
You can hold down the start key when the F1 is displayed it will show a sub code. The service manual for that model shows only one F1 code which is an F1-06. That is a shifter motor trouble. That is the section after the exit that offsets the copies.
You can reset the code with the instructions below. If the error recurrs then chech the exit section shidter for proper movement. You may require an on site technician to remedy this issue.
To reset the error code:
Hit <clear> <interrupt> <0> <interrupt>
14 <start>
Jan 05, 2008 | Sharp AR 163 Copier
AmcorAire  UCHW-H12AF2 Split System Air Conditioner Logo
292 people viewed this question
Top Amcor Heating & Cooling Experts
AJMAL KHAN
Michael Youngman
Michael Youngman
Are you an Amcor Heating and Cooling Expert? Answer questions, earn points and help others
