Question about Uniden DECT 6.0 Cordless Phone ID
Not able to hear dialing sound after connecting to allvoi phone adapter.
I have a netzero dialup and when i try to establish a connection i get "dialing, redialing in 5 seconds, dialing..., unable to establish a connection" How do i establish a connection?
If you turn your sound up on the computer, do you hear a dial tone? Does it then begin dialing? If not you may have a bad modem. Try dialing the ISP's number with your phone, it should dial in and you should hear various beeps and so on, if not the ISP is down.
Dec 24, 2014 | Compaq Presario 2100U Notebook
Bluetube is connected to my cell phone but I can't hear anything
There may be linking issues between the headset and the phone. Page 11 of the user guide offers these suggestions. Also, here is a link for re-pairing your headset to the phone:
Plantronics Explorer 230 Pairing Instructions
Remember that you want to purge any possible bluetooth interference from your phone.
"Callers cannot hear me or I cannot hear caller/dialing tone:
The headset is not turned on or the headset is not connected to mobile phone. Press the call control button for 2 seconds until you hear a beep or see the indicator light glow blue to turn headset on.
Your headset is out of range. Move the headset closer to the phone or Bluetooth device.
Your headset battery is drained. Charge your battery using the AC power adapter supplied.
The listening volume is too low. Press the volume key up (toward the earloop) to increase the sound heard in the headset."
Good luck from Headsets Direct!
Jan 10, 2012 | Plantronics Explorer 232 Bluetooth Headset
What is cause of Buzzing dial tone
This phenomenon is the phone lines and phone instrument rectifying the RF signal from your cell phone as it communicates periodically with the cell sites. The energy is rectified (turned into voltage) by the phone lines and appears as a buzzing pulsing noise in the home phone. This will trash a fax completely. There is NO solution except to turn off the cell phone or orient it away from phones and phone lines sufficiently to stop the interaction. You could put hte phone in a RF proof bag (metalized film) which would then prevent it from receiving an incoming cell call. Either way, you lose some usability of either home or cell phone for the duration of the issue.
check Grounding Connection. Also check Security Alarm interface
Static (buzzing) on your line are produced from analog equipment in your phone system (your phone and phone cable). When the phone adapter receives the sound data, it digitizes the data and eliminates the possibility of producing static or buzzing. Try using a different phone or replacing the phone cable and test if that resolves the issue.
not hearing a dial tone.
If you do not hear a dial tone, please check the following:
• Make sure the telephone and VoIP telephone adapter are plugged in
• Disconnect and re-connect the telephone cable
• Make sure your telephone is set to ring (not set to pulse) If the above items have been checked, it is possible your phone adapter needs to be rebooted.
• Reboot your equipment as described in "Rebooting Your Equipment."
• If this doesn't work, try the solutions as described in "Calling Issues with Firewall/Router"
Take care..
Sep 20, 2011 | Uniden Cell Phones
Everytime i hit the blue button on the desk set i don't hear a dial tone in my head piece
Two things to remember. If you're connected through the handset jack, the handset (receiver) needs to be lifted off the phone to get a dial tone. Secondly, if you're connected through the headset jack, you may need to adjust the configuration dial (round dial on left-hand side of base) to make it work when the headset button on phone is pushed.
Aug 24, 2010 | Plantronics Voyager 500A Deskphone Adapter...
How can I rig up an aux input??? sos that I can play music through my pone
The only way you can connect a phone to this particular deck is to purchase and aftermarket FM antenna adapter that will allow you to dial your radio to a certain frequency (for example 88.9) and then you can plug your phone via a mini phone jack cable into the adapter unit and you should be able to hear your phone on the deck.
Sound quality is not as good as a deck that has an aux in port, but it works.
May 28, 2010 | Pioneer DEH-2800MP CD Player
Clearwire VOIP ph adapter + Can only connect 1 phone downstairs
http://www.allnet-italia.it/img/speciali/pdf/777702433.pdf
if you need more call me at 804-372-RROD
May 03, 2009 | Linksys SPA-2102 NA Analog VoIP Adapter...
No sounds
your connection is effed. call your provider, it's definitely their problem. and as for the dialing, you probably just have it on a setting where you can't hear the buttons pressing as you're pressing them. i think that is in settings.
Nov 26, 2007 | LG Chocolate Clamshell VX8600 Cellular...
Polycom soundstation Ex - no dial tone
Someone in our office recently damaged the RJ-45 cable for our Polycom Soundstation. Because the jack was damaged I could not determine the order of the cables. After a call to polycom, we found the pinout information we needed - so I thought I would share, in case anyone else finds themselves in a similar situation:
With the RJ-45 prong pointing down the wires, from left to right are:
  • Black
  • Brown
  • Red
  • Orange
  • Yellow
  • Green
  • Blue
  • White
Then Crimp and test. I got this information directly from Polycom for use with the Polycom Soundstation. This information was not easy to get. They originally told me they could not provide the information and I would have to buy a power adapter. This is not true, just trim the cable and follow the above instructions.
Sep 14, 2007 | Polycom PCY220016000001 SoundStation2...
Uniden DECT 6.0 Cordless Phone ID Logo
179 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
