Question about Tappan TGF320 Gas Kitchen Range
How do you which from natural gas to proan - Tappan TGF320 Gas Kitchen Range
    Champion:
  • 274 Answers
Are you asking how to switch from natural gas to propane? call a propane company they can get you started,disconect the gas meter and they may be able to hook the propane tank to that line.
Posted on Aug 03, 2010
PRoane to natural gas
Natural gas has a much lower calorific value than either propane or butane and so the burner will need to use a much larger volume of gas to produce a similar amount of heat.
If the supply pipework is able to provide the increased flow of gas and the exhaust vent is suitable it should be possible to fit a new burner or perhaps re-jet it.
I suggest you direct your enquiries to the manufacturer, there might be a conversion kit available. For your own safety such work should be carried out only by a suitably qualified person who can ensure the burner is efficient and unlikely to poison the users.
Jul 18, 2016 | Pool & Spa
Tip
Changing your gas appliance from natural gas to LP or vice versa.
You have an LP gas stove which you really like and would like to take to a new home but the new home has a natural gas hookup. Since natural gas is already available it would be convenient to be able to use it. Can you convert your unit over to work on natural gas?
Yes it is possible to convert any LP gas appliance to natural gas or from natural gas to LP. The only difference is the size of the orifice used in the burner.
LP gas is composed of a much larger molecule than natural gas and requires a larger orifice to output the same amount of gas as a natural gas unit at the same setting. Therefore if you used an LP stove on natural gas it would produce too much heat and burn rather intensely. If you used a natural gas stove on LP it would not have much flame at all. You can see the problem. The solution is also obvious. You need the correct orifice.
Changing the orifice is easy. It is located in the middle of the burner and unscrews out of the unit. Install the new one the opposite way. Do not overtighten it.Usually the burners are made of soft metal and can strip easily.
The parts you would need are available at most good appliance stores but I would recommend the following site http://www.repairclinic.com . The parts will be cheaper at repairclinic. They have parts for almost any brand and a great search engine. They also have excellent videos showing how to make the repair.
Thanks for using FixYa and for the great rating.
hardrocko
on Dec 10, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
How do I know if my Caloric Heritage gas range is propane or natural gas? It is a used stove that was given to us
Stoves are usually sent from the factory set for natural gas. they have to be converted to Propane. If it is set for propane the flame will be very low on natural gas. If set for natural gas on propane the flame will be very large. The orifices for natural gas are much larger than propane orifices. and the regulator is converted acordingly.
Nov 10, 2014 | Kitchen Ranges
I have a imperial so24 is this model natural gas or proane
Hello there
All the info about their products are available here http://imperialrange.com/resourcecenter.php
I cannot seem to find your Model
From their site, I got this.
All Imperial Mfg. Co. equipment is manufactured for use with the type of gas specified on the rating plate
RATING PLATE:
Before making any connections to the fryer, check the rating plate to be sure the fryer specifications concur
with the type of gas to be supplied to the fryer. The rating plate is located on the inside of the door
Information on this plate includes model and serial numbers. When communicating with the factory about a unit or requesting special parts or information, this data is essential for proper identification. Other information on this plate is the BTU/hr input of the burners, operating gas pressure in inches WC, and whether the unit is orificed
for natural or propane gas. Pilot lighting instructions are also located in the same area
Have a look at the rating plate on the machine for the type.
http://imperialrange.com/PDFs/ifsManual.pdf
Sep 23, 2014 | Imperial Kitchen Appliances - Others
Btu rating on natural gas meter
Gas meters are usually rated in cubic feet per minute (CFM) not BTU. there are 1027 BTU per cubic foot so do the math. Try the link below Btu rating on natural gas meter
May 14, 2014 | Rheem EcoSense by 7.4 GPM Tankless Water...
Problem with Kenmore 970-334780 Gas Kitchen Range / propane gas /to natural gas
hello Lorraine,
Most gascookers heve the possibility to change from LPG to natural gas.
You need to change the injectors. The holes in the injectors for LPG are smaller that the ones for natural gas.
I send you a link of Ebay where you can see what you need to look for.
Sometimes the oven can give a problem when it is gas too.
Kind regards, Dik
14results for natural gas cooker nozzles
Nov 20, 2017 | Kenmore Kitchen Ranges
Hooked up proane tank used once then no flame on grill. There is propane in the tank but no propane flows out of it either when hooked up to the grill or when opening the valve directly on the tank. This...
The valve on the tank has an internal valve that will not allow you to release propane into the atmosphere. It must be connected to a regulator line in order to open.
It sounds like your regulator has failed. Remove the regulator assembly, inspect it carefully for blockage or hose kinks. If there none, try replacing the regulator assembly.
Gary
Sep 24, 2011 | Weber Genesis E-310 Gas Grill
Is there any other makes,models or years using the same compressor and/or comp. clutch. as my 2001 saturm L series with 2.2dohc. the original and a remanufactured both seized clutch the latest after only 2...
2001 to 2003 is the same for your car with a 2.2 DOHC
Year Make Model Trim Engine Notes 2003 Saturn L200 Base Sedan 4-Door 2.2L 2198CC 134Cu. In. l4 GAS DOHC Naturally Aspirated 2003 Saturn LW200 Base Wagon 4-Door 2.2L 2198CC 134Cu. In. l4 GAS DOHC Naturally Aspirated 2002 Saturn L200 Base Sedan 4-Door 2.2L 2198CC 134Cu. In. l4 GAS DOHC Naturally Aspirated 2002 Saturn LW200 Base Wagon 4-Door 2.2L 2198CC 134Cu. In. l4 GAS DOHC Naturally Aspirated 2001 Saturn L200 Base Sedan 4-Door 2.2L 2198CC 134Cu. In. l4 GAS DOHC Naturally Aspirated 2001 Saturn LW200 Base Wagon 4-Door 2.2L 2198CC 134Cu. In. l4 GAS DOHC Naturally Aspirated 2000 Saturn LS Base Sedan 4-Door 2.2L 2198CC 134Cu. In. l4 GAS DOHC Naturally Aspirated 2000 Saturn LS1 Base Sedan 4-Door 2.2L 2198CC 134Cu. In. l4 GAS DOHC Naturally Aspirated 2000 Saturn LW1 Base Wagon 4-Door 2.2L 2198CC 134Cu. In. l4 GAS DOHC Naturally Aspirated
Aug 12, 2011 | Saturn L-Series Cars & Trucks
I have a small counter top fryer set up for lp gas how do i change to nat
check the supplier for the conversion kit.the kit contains burner orifice, pilot orifice and gas valve spring which are commonly needed for conversion from propane to natural gas or from natural gas to propane.
****natural gas orifice has larger bore than propane, gas valve spring for propane is thicker than for natural gas.
Mar 29, 2011 | Cecilware FMS-40 Deep Fryer
Looking into how to convert from proane to Nat gas. Magic Chef Stove Uniburner Model# 31FA-7
Go to their website (Magic Chef) and there should be a conversion kit. Simple to do - you just change out a few parts. Good luck
Feb 14, 2010 | Magic Chef 31000 Gas Kitchen Range
Tappan TGF320 Gas Kitchen Range Logo
113 people viewed this question
Top Tappan Kitchen Ranges Experts
Paul Carew
Sal De
Craig Butler
Craig Butler
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
