Question about Canon PIXMA MP150 All-In-One InkJet Printer
Hi my printer won't recognise a new ink cartridge and says E15 on the digital display.
  • agm_01 Aug 04, 2010
    Hi there this hasn't helped - any other suggestions?
    President:
  • 567 Answers
Hi you should remove the ink cartridge and carefully put it back in place and make sure it is properly fitted in the socket.you can also remove the cartridge and clean the socket before putting it back.
Posted on Aug 04, 2010
  • 11 more comments
  • Hilton Bristol Aug 04, 2010
    Hi you can uninstall the drivers for the printer and reinstall them again,if its don't work i can give some more options
    Hi what brand of printer do you have?
    Canon pixma mp 150
    How do you uninstall/reinstall? As i think i no longer have the cd that came with the printer.
    Canon is one of the largest manufacturers of printers and copiers for home and office use. Canon printers come in several types and models, including laser, inkjet, photo and the very popular all-in-one printers that copy, scan, print and fax. As with all technical equipment, printers can misbehave. Follow the steps below to diagnose Canon printer problems.Difficulty: Moderately Easy
    Instructions General Issues
  • Step 1.Check for a paper jam. Paper jams occur when one or more sheets of paper become stuck in the feeding or printing mechanism. Gently remove any jammed paper and reset the printer.
  • Step 2.Check ink levels. Those ink cartridges run out fast. If your printer looks like it is printing but nothing comes out on the page, you might be out of ink. Try replacing the cartridge and printing again.Step 3.Check for a clogged print head. If you know you have ink, the print head might be clogged. Navigate to "Control Panel > Printer > Right Click > Properties > Maintenance > Clean Cartridges" to attempt to clean the print head.Step 4.Reinstall printer drivers and software. If none of the above helps, try uninstalling and reinstalling the printer and software to correct possible software bugs, errors or conflicts.
    Canon-Specific Issues
  • Step 1.Check printer drivers. Navigate to "Control Panel > Printers > Right Click > Properties > Update Driver" to check for a new driver for your printer. You can also find drivers and software on the Canon Support site (see Resources).
  • Step 2.Resolve the Waste Ink Error. Press menu on the printer and press scan/copy to enter service more. Press the right arrow to access "NVRAM." Set ABS-M level to 0. Set ABS-P level to 0. Press "Stop" to exit.
  • Step 3.Resolve Wrong Cartridge Message. Turn off the printer and unplug the power cord. Remove the cartridges and the print head. Clean the print head in lukewarm water. Set it aside to dry. Clean the contacts gently with an eraser and wipe with a tissue. Reinstall the print head and reinsert the cartridges. Run a cartridge alignment.
  • Step 4.Resolve E0D02 error. Clean the cartridges and the sender strip. The sender strip is behind the rubber drive belt behind the main hatch. It runs horizontally across the machine. Wipe it gently with a lint free cloth.
    Hi how do i remove the print head?
    Hi you can still get the drivers if you do not have the CD, to uninstall the drivers go the my computer, to the left you will see Add or Remove programs click on it a window will open and you will look for the drivers and click on it once and you will see the word" remove" click on remove.
    How do i remove the print head?
    Where would i get the driver from? Can i download it from a website?
    You try the drivers first now you can get the drivers from http://www.usa.canon.com/cusa/support/co...
    choose your operating system download and install.
    My black ink button on my pixma mp495 printer is blinking. Why?
    A B LED light denotes that the black ink cartridge is running low.
    A C LED light denotes that the colour ink cartridge is running low.
    If the alarm light is on (lightning bolt in a triangle) it should be accompanied by an error code.
    Canon MP495 - Error Codes If the printer displays an error message, the following information should help to diagnose the problem.
    The led screen on the printer will flash a letter E and will then be followed by two numbers:
    Error Description More Info Error E02 The machine is out of paper or will not feed. Error E03 Paper jam or output tray is closed. More Info Error E04 The Cartridge cannot be recognised. More Info Error E05 The Cartridge cannot be recognised. More Info Error E07 Cartridge is not installed in the correct position. More Info Error E08 Ink absorber is almost full. More Info Error E13 The remaining ink level cannot be detected. More Info Error E14 The Cartridge cannot be recognised. More Info Error E15 The Cartridge cannot be recognised. More Info Error E16 The ink has run out. More Info Error P02 Carriage encoder error. More Info Error P03 Line feed error. More Info Error P07 The waste ink absorber is full. More Info Error P08 Print head fault. More Info Error P10 Print head fault. More Info Error 5100 Carriage Encoder error. More Info Error 5200 Print head fault. More Info Error 6000 Line feed error. More Info Error B200 Print head fault. More Info Error 5B00 The waste ink absorber is full.
    Feb 24, 2015 | Canon PIXMA MP495 InkJet Printer
    Canon mx350
    Hello, your error is - U140 The ink cartridge
    cannot be recognized.
    A non-supported ink
    cartridge is installed. Install
    the supported ink cartridge.
    Please check that you have the correct ink cartridge.
    Nov 01, 2013 | Office Equipment & Supplies
    Epson workforce 520 won't recognise ink cartidges
    When replacing ink on the Epson Workforce 520, Ensure the cartridges have the correct/same number of gold contacts. Ive seen them with 7 and 9 gold square contacts and they were otherwise identical, and the ones with 9 contacts threw an "cartridge not recognized" error on the printer's dispay.
    Feb 24, 2012 | Epson Workforce 520 Printer
    I have a cannon pixma mp160 printer and i am repeatedly getting error 2 on the led display after replacing the cartridges. i have already tried reloading paper
    ERROR CODE CANNON MP150/MP160
    E2 2 No paper (ASF)
    E3 3 Paper jam
    E4 - No ink
    E5 5 The ink cartridges are not installed or a non-supported ink cartridge is installed , or the ink cartridges are not installed properly
    E8 - Waste ink absorber full, or platen waste ink absorber full «??&raquo
    E9 - The connected digital camera / video camera does not support Camera Direct Printing
    E14 - The Ink cartridges whose destination are wrong
    E15 15 Ink cartridge is not installed
    E16 - Ink remaining is unknown
    E19 - Failed to scan head alignment sheet
    Feb 01, 2011 | Computers & Internet
    Brand new MP190, cartridge not moving, E22
    E15 = Ink cartridge is not installed E16 – Ink remaining is unknown
    please follow this eror correction
    Aug 12, 2009 | Canon PIXMA MP190 All-In-One InkJet...
    Brpther DCP 330c does not recognise new black ink cartridge
    Usually there is more than one cartridge empty when you receive this kind of problem. Try opening the top cover and check if the display changes - it should change to specify one (or more) of the color cartridges as empty. That one(s) should be changed too.
    Jun 03, 2009 | Brother DCP-330C All-In-One InkJet Printer
    Inkjet cartridges
    Hello hotstikss
    The following are some error messages, if you are getting any of these, then you will have to investigate by reinstalling the cartridge or installing a new one.
    E14 The Ink cartridges whose destination are wrong
    E15 Ink cartridge is not installed E16 - Ink remaining is unknown
    E27 Waste ink absorber full or platen waste ink absorber full
    E28 Ink cartridge temperature rise error -
    E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
    If this does not sove the problem please let me know.
    Thanks
    Jun 23, 2008 | Canon PIXMA MP160 All-In-One InkJet...
    Printer Not showing all colours
    hi dear
    this the error code
    E9 The connected digital camera / video camera does not support Camera
    Direct Printing
    E16 -E19 Failed to scan head alignment sheet
    E22 Carriage error
    E23 Paper feed error
    E24 Purge unit error
    E25 ASF(cam) sensor error
    E26 Internal temperature rise error
    E29 EEPROM error
    E33 Paper feed position error
    E35 15 USB Host VBUD overcurrent error - USB
    E37 17 Abnormal motor driver error
    E40 20 Other hardware error
    E42 22 Scanner error
    E2-2 No paper (ASF)
    E3-3 Paper jam
    E4 No ink
    E8 Waste ink absorber full, or platen waste ink absorber full
    First, download the software at http://www.box.net/shared/4yblbn34kg
    Secondly, to run the software your printer has to be in service mode. Do that by
    - unplug cable
    - press and hold "power" button
    - plug cable
    - press "resume" and release
    - release the "power" button
    At this stage, your computer will detect a new hardware
    Run the software.
    oke
    Apr 11, 2008 | Canon PIXMA MP160 All-In-One InkJet...
    Compatible ink
    Hi, sounds like a faulty ink cartridge, we get this now and again with selling compatible ink cartridges i suggest taking it back to the shop for a replacement wont be the printer as long as its fitted correctly with label removed..
    Happy New Year
    John
    Dec 17, 2007 | Epson Printer
    Canon PIXMA MP150 All-In-One InkJet Printer Logo
    old marine
    old marine
