Question about Whirlpool Duet GHW9150P Front Load Washer
I am getting an error message F11. I have no owners manuel so I do not know what it means
  • 5,911 Answers
"F11" is a Serial Communications error. This is an indication of a communications problem between the Central Control Unit (CCU), Motor Control Unit (MCU), or the interconnecting wiring between the two. The following link explains:
http://www.fixya.com/support/r3608695-f11_error_code
FYI: If you do determine that the CCU is the cause of the problem, the part number is 8182695. Some sites may carry a refurbished version that costs less than a new one.
For a full explanation of all the error codes, each one of these washers comes with a technical data sheet inside.
To access, you will need to remove the lower toe panel under the door. The access screws are located under the bottom front edge of the panel. You may have to prop the two front feet of the washer up for better access ( a 2x4 works well for this). With the screws removed, the panel should drop down, then come off. If the tech sheet isn't directly behind the panel, it will be affixed to one of the interior cabinet walls.
The tech sheet lists all error code definitions, troubleshooting data, diagnostics procedures and wiring diagrams. I mention the tech sheet because you may need it to troubleshoot this error code.
Replacement parts (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices will vary between sites so shop and compare. The first three sites on the list include helpful exploded view parts illustrations to assist you with locating and properly identifying any parts you may need. If you have questions, or need additional assistance, please post back and let me know.
Read through the information provided and if you have questions, please post back and let me know. I hope you find this information helpful.
Posted on Aug 04, 2010
Frigidair range I would like to know what f11 means
Hello, Floyd -
Without knowing the model of your Frigidaire range, I cannot look for the owner's manual for your particular model and find what F11 (a fault code) means for your specific appliance.
However, I did find a web page listing fault codes for newer Frigidaire ranges. See the information here:
http://www.applianceaid.com/newer-frigidaire-fault-codes.php
From that information, the EOC (Electronic Oven Control) may need replacing.
Dec 22, 2017 | Kitchen Ranges
WHAT MEANS ERROR CODE FOR MY DRYER MACHINE F11?
  • Troubleshooting and Repairing the F11 Error Code in a ... www.youtube.com/watch?v=RXH5MWzZJKM
    • BY SAMURAIREPAIRMAN
    • 6 MIN
    • 121K VIEWS
    • ADDED 2013-10-22
    Video embedded · Troubleshooting and Repairing the F11 Error Code in a ... Troubleshooting the F35 Sud Error Code in the Whirlpool Duet Steam ... Washer Dryer ...
  • Kenmore Elite He3 F11 Error Code - WordPress.com https://hydripinri.files.wordpress.com/2015/10/kenmore-elite-he3... · PDF file Kenmore Elite He3 F11 Error Code circuitboardmedics.com/whirlpool-duet-fdl-ccu-repair/ How to troubleshoot the ... Kenmore F1 Error Code He2 Dryer Problems Amp Solutions
  • Kenmore Washing Machine Error Code F11 - WordPress.com https://meofapitri.files.wordpress.com/2015/07/kenmore-washing... · PDF file Kenmore Washing Machine Error Code F11 what does f11 mean - Kenmore Elite HE3 Washing Machine. The F11 code is from a communication break in the serial link from ...
  • Related searches for ERROR CODE DRYER F11
  • Whirlpool Duet F11 Error Repair ' Circuit Board Medics circuitboardmedics.com/whirlpool-f11-code Whirlpool F11 Error. This is a repair service for the Whirlpool Duet F11 error code on a Whirlpool Duet washer.
  • Bosch Tumble Dryer Fault Code F11 - prapmumbmihe https://prapmumbmihe.files.wordpress.com/2015/08/bosch-tumble... · PDF file Bosch Tumble Dryer Fault Code F11 Bosch Exxcel tumble dryer error code F:09 · Bosch Exxcel WVT. Asciugatrice Bosch Wts86511It: Errore F11 Hello, My dryer ...
  • Whirlpool F11 error code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • LAST UPDATED: 2014-02-18
    • 6 POSTS
    • FIRST POST: 2012-02-18
    I got an F11 error code on the washer and tried some of the things discussed on the Applianceblog.com site for simiilar duet washers and found a link to this site ...
  • Jan 30, 2016 | Dryers
    The water is not draining during the spin cycle. I'm getting an error message f11
    F11 means there is a serial communication error. The communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly. Check the wire harness connectors to the MCU, the motor and the CCU. Check the drive system for any worn or failed components. Check the MCU, the CCU, the motor and the wire harness.
    Nov 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool Duet washer GIVES ME f11 ERROR CODE
    The F11 error code means that there is a communication error between the CCU (central control unit) and the MCU (Motor Control Unit) and it is not sending the message correctly. Check the wire harness connectors to the MCU and the CCU. Check the drive system for any worn or failed components. Check the MCU and the CCU and the motor. You may need a qualified repair technician for this one.
    Nov 08, 2009 | Whirlpool Washing Machines
    WHAT DOSE F 11 MEAN AND HOW CAN I GET USER MANUAL
    "F11" is a Serial Communications error. In a nut shell, the Central Control Unit (CCU) isn't communicating properly with one or more components. The following link explains:
    http://www.fixya.com/support/r666194-f11_error_whirpool_duet_kenmore_elite
    This problem can be attributed to wiring, a bad connector plug, or the CCU itself has failed. You can attempt to reset the CCU by unplugging the washer for at least 30 minutes. Sometimes these error codes are erroneous and a reset will correct momentary glitches. If the error code reappears following a reset, you have a problem. Please read through the link provided. If you still require assistance, please let me know.
    If you're looking for technical data about the error code, there is a tech sheet affixed to the interior cabinet wall behind the lower panel under the door. There are three torx screws under the front edge of the panel that you will need to remove. With the screws removed, the panel will drop down then off.
    If you are looking for a User's Manual that explains the operation of the washer, you can go to Managemyhome.com and register (this is a FREE service). Once registered, look under the "Home Managers" heading and click on the "Owner's Manuals" link. Follow the instructions on the next page and your owner's manual will be available in a downloadable .pdf format.
    If you require additional assistance, please let me know. I hope this helps you.
    Feb 27, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    F11
    these error codes are not specific FDL can mean door latch failure .it can also mean the ccu board has failed also F11 can mean mean anything from motor to motor control board to ccu board to wiring harness connecting ccu to mcu to motor. if you do not know how to diagnose with out error code you may end up buying wrong part. sometimes doorlatch is not problem central control board CCU is
    Feb 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Could you tell me what F11 code means?
    F11 error code means there is a problem with the Control panel. Could be melted wiring, etc, since you left the oven standing. However, you can try unplugging the device from the power socket for about 5 minutes and reconnect. If the error goes away, then well and good; if not, you may have to replace the panel control.
    Oct 13, 2008 | Frigidaire Kitchen Ranges
    Error message F 11 appears on my front load Whirlpool. What is Failure notice F 11 mean?
    Click on the following link for a full explanation of the "F11" error.
    Please review the advice in the link carefully. If you need further assistance, please let me know. I hope this is helpful to you.
    Jun 16, 2008 | Whirlpool Washing Machines
    System error
    maybe it has just worn itself because it is quite a old console , hope i helped
    Oct 17, 2007 | Nintendo GameCube Console
    Whirlpool Duet GHW9150P Front Load Washer Logo
    52 people viewed this question
    Sal De
    Marvin
    Marvin
    Gerry Harvey
    Gerry Harvey
