Question about Dewalt 3700 Pressure Washer
Were can I buy water pumt for dewalt presure washer
  • 2,005 Answers
Http://www.ereplacementparts.com/dewalt-parts-c-1009.html
Posted on Aug 04, 2010
Hi, My Dewalt 3100 pressure washer pump wash leaking water from a check valve or overflow plug Do you know whats wrong?
The Dewalt 3100 came with 2 different pumps. The Blue Cat pump and the oil free pump that was made by DeWalt.
You may just have a bad Thermal relief Valve on the unit.
You can find the parts diagram at www.allpartsinc.com
Sep 08, 2011 | Dewalt DPH3100 Gas Pressure Washer
DPD 3100 gas pressure washer. No water going through pressure washer. Have taken screen completely out and still no water moving through
See this diagram:
http://www.mastertoolrepair.com/images/DPD3100_pump.jpg?osCsid=1f3m03ijp5lcht6569kran6rk2
Remove Items 122 (Un;loader) and 138 (Thermail relief). Clean them up as best you can with a nylon brush under some slow running water. Dis-assemble the unloader valve completly to clean (both ends). Then lubrcate them with White Grease and reinstall both parts AFTER placing White grease in the cavity the valves mount into. Very briefly... Test water flow with the engine not running Then start the unit with water off and let run 30 seconds. Turn off engine. Turn ON water supply and test water flow engine OFF. Note you will get a certain amount of white grease initially that passes through the unit. Start unit and rapidly actuate the trigger 1/2 second on 1/2 second off multiple times to force the unloader valve to cycle.
You can get parts here if either of the valves have completly failed:
http://www.mastertoolrepair.com/dewalt-dpd3100-n001194-pump-p-59405.html
The above steps should get your presure washer working properly again.
Thanks for choosing FixYa,
Kelly
Sep 03, 2011 | Dewalt DPD3100 Gas Pressure Washer
Cam shaft bearings are seized in Dewalt DPD3100 presure washer. does anyone know where to purchase the roller bearings. can not find a part number, do not want to purchase new pump
hi there perrinex22x
here is web site for parts
http://www.ereplacementparts.com/dewalt-dpd3100-pressure-washer-parts-c-1009_7440_7445.html
from diagram looks like not listed as seperate part
may need to remove them and see if your local bearing/ belt store distributor in your area may be able to source them
from list pt number N001194 pump assy is 505 $
sorry
here is another web site that may help for needle roller brgs - give a try
http://www.locateballbearings.com/roller-bearing-suppliers.html
cheers hope it helps pauly46
Jun 07, 2011 | Dewalt DPD3100 Gas Pressure Washer
Willnot pumt water out
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Dec 24, 2010 | Maytag Washing Machines
Can I use a 200 gal. water tank that is not pressurized for my dewalt dp3900 3750 psi pressure washer? the manual says that you should use a water source that has a minimum of 20 psi 5 gallon per miniute....
My name is Dane and I am going to help you solve your problem.
A pressure washer pump is lubricated by the water running though it. You never, ever even start one when not connected to an approved water source. If the manual says that it has to have that presure, don't risk it. I would get an auxillary pump and install on your tank.
Well, I hope I've helped. If you found this information useful, please leave me some THUMBS UP if you think I'm deserving! :-) Thank you! Dane
Dec 05, 2010 | Garden
Plenty of presure front washers, tailgate washer not working
It may have a seperate reservoir for the back wipers
Jul 11, 2009 | 2001 Volvo V70
My DeWalt Gas Pressure Washer Model DPD3100 is
Hi
Just try the following steps
  • Inspect the water supply connections
  • Inspect the drain hose
  • Inspect the water pump
  • Inspect outer tub for cracks or corrosion
  • Inspect the tub seal
  • Inspect the tub bearing
Good luck
Regards
PCmania
Jul 05, 2009 | Dewalt DPD3100 Gas Pressure Washer
I need help fixing my washing machine
fluss saup box vith hott vater i 5,min remeber have open fra the pumt end fluss
Nov 25, 2008 | AEG Lavamat 16810 Front Load Washer/Dryer
Dewalt 3700 Pressure Washer  Logo
90 people viewed this question
Top Dewalt Garden Experts
John Trevino
JOHN LAPIER
Tim Venetis
Are you a Dewalt Garden Expert? Answer questions, earn points and help others
