Question about Toshiba Computers & Internet
Internal speakers do not work at all, external headphone output jack works fine so drivers are working. I really don't think that both speakers would just quit (Model # L355) so is it possibly the MB?
    President:
  • 2,559 Answers
Have u tried pressing the FN and F5 key at the same time or opening the speaker icon near the clock and checking the settings?
Posted on Aug 03, 2010
Looking for old Logitech S-100 driver
These are analog speakers and do not need a driver. First, make sure they're plugged into the speaker/headphone jack and not the microphone jack. Second, make sure the computer's sound output is enabled and set the headphone/speaker jack. Third, verify that the sound output is working by plugging in a headphone set or a different pair of speakers. If the computer sound checks out, the speaker cable is bad or the power supply is not working.
Nov 14, 2017 | Dell Computers & Internet
My dell latitude d510 internal spk is ready but output headfone jek not working
these are fairly passive in that if a headphone or earpiece is plugged in, they switch the output from the internal speaker to the external speaker. So, it's usually one of a few problems.
  • The jack is mucked up, and needs replaced.
  • The headphone plug wires have a broken connection
  • The headphone needs power to amplify, and that's not working.
If trying another headphone or earpiece you know is working doesn't work, it's the jack itself. They can only handle so many uses before they either fail closed, or open or completely. Depending on which one, either:
  • neither speakers nor headphones work.
  • only speakers work
  • only headphones work
Replacement necessitates opening the case and replacing the jack. For that, there's no help.
Sep 02, 2015 | Dell Latitude D510 Notebook
Internal speakers are disabeled. Extearnal speakers work just fine
Headphone jack may be faulty as there is a contact that tells the uProcessor that the socket is in use and turns the internal speakers off. If the contacts are tarnished, they might not be opperating correcty.
Dec 03, 2013 | Computers & Internet
IMac G5 17" no sound from internal speakers and no start up gong,, OK on external speakers and headset
The first thing you should try is to hold down the keys command-option-P-R as you power up the system. That should reset the PRAM in case there is any funny muting information stuck in there. If you hear your optical drive reset more than twice and there is still no chime sounding, let go of the keys because that's not the problem.
Go to System Preferences / Sound. Choose the Output tab. It should say something like "Internal speakers, built-in." When you plug in headphones, it should switch to saying something like "Headphones, Headphone port." If (as I suspect) the output is stuck on "Headphones, Headphone port" whether the headphones are in or out, the problem is most probably a very simple mechanical problem. There is a "shorting strip" in the output jack that makes an electrical connection back to the speakers when a plug is removed, and it may be dirty, bent, or broken off. If it's not broken, it's possible to clean it and/or move it back into position with really fine gauge tools and a steady hand. If it's broken off, you're out of luck unless you want to solder a new jack onto the motherboard (I wouldn't recommend it).
Apr 14, 2013 | Computers & Internet
Dv6000 no sound from internal speakers
If the stereo jack works, then there is no problem with the sound card or its drivers. Your speakers have played their last, most likely some internal wiring broken as speakers themselves rarely just quit.
Jan 12, 2012 | HP Pavilion dv6000 dv6100 dv6200 dv6300...
Headphone jack not working
I find that there is a problem with your headphone speaker.
Try with some other headphone, even if it is not working, then you need to take it to the service center.
Cheers,
Mr.Maduraikaran.
Jan 10, 2012 | Acer Computers & Internet
Hi plz help me i am using IBM r51 laptop which has all drivers but not able to get sound of it. but when i connect a headphone i can get sound of it. but my laptops speakers r working as i tested mt...
ibm sound card is not faulty, because you are getting sound with your head phone. The head phone jack have two functions 1. to give output to head phone 2. to disconnect internal speakers when you plug in head phone.
The jack for headphone in normal position not give connectivity to internal speakers.
SOLUTION : REPLACE THE HEADPHONE JACK.
I think it will help you.
Sep 15, 2011 | IBM ThinkPad Soundcard
No sound from external speakers with toshiba dynadock
if using XP, go to start control panel , sound and audio devices.Under the audio tab make sure the C Media CM106 sound device is selected under sound playback. Then under the volume tab set the volume somewhere in the middle or at the top if you don;t have active speakers . Then Under Speaker settings advanced, make sure the speaker setup is set to Laptop Stereo speakers. Also make sure the speaker volumes are up on the speaker volume button. click ok. If no result check that the cm106 sound decvice was cemented in as I saw it dissaper when I thought i had slected it. I think the key thing here is the device and the laptop speakers setting.
Aug 26, 2009 | Toshiba Dynadock Port Replicator, Docking...
No volume
do they plug in with a 3.5mm audio jack?
if so, i think you need to check your drivers for laptop output socket.
have you tried output with any headphones etc? do they work on laptop?
Feb 25, 2009 | Cambridge Soundworks SWBL SoundWorks PC...
Speakers port not working properly...
It must be a hardware problem it can't be the driver which is software.If I were u i would have had a look inside the pc at the jack or ask toshiba for a repair/replace if in warranty but i think it's more likely the jack ur intrested in.Try putting a drop of water when inserting the jack(don't be affraid nothing can happen) and rotate it a bit and see if it comes only in the external device.This worked for me I hope it did for u.
Oct 29, 2008 | Compaq Presario 700 470024-192 Notebook
Computers & Internet Logo
99 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
