Question about ASUS M2NPV-VM Motherboard
My computer won't always boot up. i push power on, starts drives start to wind up, then it shuts off. sometimes after several times it will start.
  • 21 Answers
Its hard to tell but there are various possibilities: it could be of a defective RAM, hard disk, or corrupted operating system try to perform a full format and reinstall ur windows the update all your drivers. If the problem persist u should check your Ram in case of wrong installation or damage.
Posted on Aug 04, 2010
Dell E6400 won't boot up (most of the time)
Computer does not boot up
The problem maybe the RAM, it could be faulty or just needs reseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you.
Just like you sometimes need a mechanic to repair your car, sometimes you do need a technician to diagnose and identify the fault or faults on your computer. Not only does a good service technican have the experience to deal with this type of problem, they also have the equipment that allows them to look at things the average computer user can't see, and he has a collection of replacement parts that can be used to quickly test individual components on your computer.
May 11, 2013 | Dell Latitude E6400 Laptop
Why won't my compressor stay running
Does it run at a low speed to start but then just quits, or goes back to low speed? Some compressors have a starting winding in the motor to get it running, then as it speeds up it kicks out the starting winding and goes to the normal run winding. I am thinking that the run winding may be bad. Or else you have a bad contact in the pressure switch and the compressor kicks on but the contact arcs and loses connection sometimes. The difference would be if the motors always does the same thing in about the same time it would be the motor problem. But is the compressor runs and then all of a sudden stops, sometimes in a minute, sometimes five minutes, I would look at the pressure switch.
Apr 23, 2012 | Air Tools & Compressors
My 2001 malibu sometimes won't start for several minutes and shuts off while driving and I lose power steering. I've had the ignition replace. Mechanic put on computer and they could not find a...
sometimes the cars anti theft can shut down the starter and/or the injectors. This might be your problem, especially after changing the ignition this problem is more common. The ignition is part of the antitheft security system. Check out this link for info and solutions. http://vatspasslockpasskeysecurityhelp.yolasite.com/
May 27, 2011 | 2001 Chevrolet Malibu
Laptop intermittent startup problems
if you need your laptop always in ready use change the time your computer is on in control panel then log off your device will be on always until you shut it down it constantly drains battery
There is a way to fix this try reinstalling windows
or just take it to software mechanic
Mar 21, 2017 | HP Compaq Presario v4000 Notebook
Pc not always booting,
blow out dirts on bord, then you pack the board to avoid any bridging with the cassing
Jul 20, 2009 | Computers & Internet
The laptop doesn't boot up always.
I would try the following:
1. Remove the battery completely. If the computer boots properly several times in a row, then the battery may be causing the power supply to do strange things.
2. If you have experience removing laptop components, try removing the hard drive. Because you say the screen goes black (I assume the system powers off) sometimes after the HP logo, I doubt its Windows or a software issue.
3. If HP has a diagnostic CD you can boot to, try that.
4. It may be the power supply acting up. If it charges the battery, and if you can boot to Windows with the battery, try getting a new power supply.
5. Otherwise, it may be the motherboard of the laptop.
Nov 28, 2008 | Computers & Internet
Computer won't start normaly
This is most likely do to a bad stick of RAM.
Try taking out all but one stick of ram and try booting. If it still doesn't boot try changing the stick out with another one you pulled (might be the stick you left in that is the problem)
In the case that it is bad RAM go to your local computer shop and get some new RAM for the computer or check if Gateway will replace the RAM.
If there is any display that comes on the monitor such as a 2 digit code try searching that or posting here with the code.
Jul 20, 2008 | Gateway GT5228 PC Desktop
Computer powers off during boot
Hmmm...try resetting CMOS & checking all external peripheral connections: (KB/mouse, monitor, etc.)
Oct 26, 2007 | ASUS A8N-E Motherboard
Laptop boots up intermittently or screen freezes
basing on the information you have given here are the possible solutions:
remove any external device connected to your system (printer, external hard drive and others) if removing this does not work and still gets a blank screen with blinking cursor try to go to safe mode with networking. if successful try to download the driver for your video adapter.
when you try to start the computer , do get anything on the screen like a logo? when does the blank screen occurs, is it during the turning ON of the computer or during the windows xp logo appears on the screen?
a blank screen could be caused by the following: defective video adapter, corrupted video driver, defective memory, unknown device causing the issue like the hard drive, optical drive or other peripheral installed inside the computer.
try also using an external monitor
Sep 19, 2007 | Toshiba Satelite 5205-S505 Notebook
ASUS M2NPV-VM Motherboard Logo
214 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
