Question about Yard Machines 11A08MB006 22Inch 139cc MTD OHV Gas Powered Side Discharge
My lawn mower will start and run for a few minutes, then it will shut off.
  • 43,501 Answers
There is a filter between the gas tank and the carb... pull that apart and get the dirt out...
heatman101
Posted on Aug 04, 2010
Why is the engine running rough after a few minutes and the spark plug gets carbon on it?
Could be your choke is not shutting off like it should and some mowers the choke is on when you put the throttle wide open. Cut the speed back just a little and see if that helps.
Aug 01, 2015 | Garden
We have a John deere 314 lawn mower. After you mow a few minutes there is a loud pop and the mower stops running. After it sets just a few minutes it will start right back and mow a few more minutes and...
Julie this sounds silly but try and run it with the exhaust and muffler removed. If it ticks over and then stops when it's engaged for a few minutes it sounds like its suffocating.
Sep 07, 2013 | Garden
Masport 4 stroke mower...started it up and it worked for a couple minutes with a strange rattling growling noise.. Oil ok and petrol filled but the mower just shut it's self down and im not sure w
It will run for a few minutes and then shut down?
Lets ignore the growl for now. Loosen Gas cap and see if it will keep running. The rattle might be in the pull cord mechanism..possibly not related to stalling issue
Dec 03, 2012 | Garden
My husqvarna 61 inch lawn mower will not stay running
Did you check the oil? Some engines have a low oil shut off switch to prevent the engine from running out of oil and burning themselves up. If it is low in oil and all the oil is up in the engine to lubricate, then the switch may be setting itself off. After a few minutes, the oil comes back down to satisfy the switch and it starts back up, but only till the switch is activated again. Might do it???
Dec 27, 2011 | Husqvarna Garden
What would cause the lawn mower to stop running when not out of gas? If you give it a few seconds and restart it it will run again for awhile then stops. I have noticed if I pump the primer a couple of...
Try using non-ethanol gas. It's death on small engines. Starter fluid gives it a boost if higher octane. Have a reputable repair place clean out the gunk, then use good gas. Best of luck finding non-ethanol. Boating marinas carry it.
Jul 20, 2010 | Mtd 22" Yard Machine Push Mower
Mower starts up after priming, runs for a few minutes then shuts off. Starts again after priming......runs a little then shuts off.
The carb needs to be taken off and cleaned. The ethanol in gasoline absorbs water and causes problems. Disassemble carb and clean with carb cleaner.
Jul 18, 2009 | Garden
Weedeater lawn mower shuts off, but still has 3/4 tank of gas
On some mowers...if the gas cap vent is not working properly, it will run fine for about 15 or 20 minutes, start spitting and sputtering, if you loosen the cap, and let air back into the tank it starts running normally again.
Apr 05, 2009 | Garden
Yard Machines 11A08MB006 22Inch 139cc MTD OHV Gas Powered Side Discharge Logo
408 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
