I would like to know the steps to reset my desktop to factory defaults, I've done it several time before but I forget the key combination to reach the page, I have a emachines ET1641-w2
    Scholar:
  • 151 Answers
Http://support.gateway.com/s/Manuals/Desktops/8510406.pdf
This link will lead you to the PDF document with instruction on how to access your system recovery partition.
Posted on Aug 07, 2010
Forgot my security code n i dont know how to reset it
Option 1, How to Hard Reset Nokia E7 with Software Menu:
  1. Turn On Nokia E7
  2. Go to Menu: Menu > Settings > Phone > Phone management > Factory settings > Delete data and restore
  3. Nokia E7 will ask the default security lock code is: 12345
  4. The rest will do by itself to master reset Nokia E7, this process will erase or wipe all important data
#Option 2, How to Hard Reset Nokia E7 with Hardware Button Combinations Key:
  1. Before doing the master reset and format Nokia E7, you have to backup any important data
  2. Battery Nokia E7 should full charge
  3. Turn Off Nokia E7
  4. Press and hold together: Volume Down Button key + Camera Button key + Menu Button key, after that continue with press Power Button (do not release the first three button)
  5. The process will do format to factory default Nokia E7
#Option 3, How to Hard Reset Nokia E7 with Secret Security Code:
  1. Make Sure Nokia E7 is already charge properly
  2. Turn on Nokia E7
  3. Press at Dial pad: *#7370# and wait
  4. Nokia E7 will ask for default security code, enter: 12345
  5. Nokai E7 will do format to factory default
How the Right Step to Flash and Restore Nokia E7 Unlock?
Have a good smartphone should know how to restore especially while the smartphone of Nokia E7 got problem. First step is do the soft reset first, if the Nokia E7 still get the problem, second try by doing the hard reset or restore to factory default with some options step above.
What should I do to Fix forgot or Lost Password of Nokia E7 Default Security Code?
If you never change the Nokia default security code is 12345, maybe sometime you every change the default security code and you forgot what you have change, in this case you have to go to nearest authorize service center for repair Nokia E7.
How to Restore Clean Setting at Nokia E7 Reinstall the Operating System?
Restoring the Clean setting of Nokia E7 can be done with doing the soft reset without delete any important data. If you want to reinstall clean operating system for Nokia E7, this can be done with doing the hard reset, but your data important will be deleted.
Help for Slow Respond Nokia E7, How to Make Nokia E7 Run Faster?
It will hurt to use slowly Nokia E7 smartphone, maybe it have a lot of applications or you ever try to setting the Nokia E7 with wrong way. This problem can make our Nokia E7 running slowly, so to make Nokia E7 run faster, you can try to do the soft reset and also hard reset. It depend on what the main problem with your Nokia E7.
How to Fix Forgot Nokia E7 Pin or Password ?
If you assign a pin or security password for Nokia E7 and forget about it, you have to do the hard reset of Nokia E7 with step above
The information from this page describe about nokia e7 hard reset,hard reset nokia e7,how to hard reset nokia E7,how to format nokia e7,how to reset nokia e7,e7 hard reset,hard reset e7,nokia e7 format code,nokia e7 hard reset button,how to unlock nokia e7 security code. If you need another resource for hard reset, use search function at this homepage or find from our related posts.
Mar 23, 2014 | Nokia E7 (16 GB) Smartphone
Bios fw140e reset vgn vergine
Follow these steps to access the BIOS on a VAIO computer.
WARNING: Other than resetting the BIOS to the default values, making changes to the BIOS is an advanced procedure that can produce unintended results if not done properly. For instance, if you set a Machine Password and later forget that password, it will require advanced technical support and possibly service to regain access to the computer.
  1. Turn off the computer.IMPORTANT: If you are having difficulty accessing the BIOS, or are doing so as a step in troubleshooting an issue, it is recommended that you remove all media or any peripheral devices connected to the computer before trying to access the BIOS.
  2. Restart the computer.
  3. At the black VAIO logo screen, press the F2 key.
If you are accessing the BIOS as a step in troubleshooting an issue, you may need to reset the BIOS to the default settings. While the exact steps will vary slightly based on the version of the BIOS installed on the computer, these general steps will allow you to reset the BIOS to the factory default values:
  1. In the Setup Utility window, use the arrow key to select Exit.
  2. At the Exit screen, press the down arrow key to select Get Default Values, and then press the Enter key.
  3. At the Get Default Values prompt, use the arrow keys to select Yes, and then press the Enter key.
  4. At the Exit screen, with Exit Setup selected, press the Enter key.
  5. At the Exit prompt, use the arrow keys to select Yes, and then press the Enter key.
  6. The computer will restart.
Reference: How to reset the BIOS to the default settings
Oct 24, 2013 | Sony VAIO VGN-FW140E/W Laptop
Forgot pass code for android go phone
Hey Hi. I had faced this problem and i was told to Press emergency call in idle mode.and input star key ,nine eight three star key nine eight seven pound keyit will go to the factory reset interface and reset the handset to Default and yea do not forget to update the data so that your personal information will not erased Gud Luck
Mar 14, 2013 | ZTE At&t Avail Z990 Touchscreen Android...
I've been at this all day and still have'nt gotten my laptop to reset to a factory default setting. Can you please guide me through this process, step by step. Thankyou.
You can always restore the computer to a point when it was working fine.
For a laptop when you say factory defaults we've two things
1)Factory defaults on the Bios - as soon as u turn on the laptop we press F8 key or DEL(depends on the brand of the laptop) to get to the BIOS and you've an option to revert to the factory defaults.
It is advisable not touch the BIOS if you are not sure about this firmware
2)The operating system (lik windows xp,vista & 7) there is nothing called factory defaults for this all we've is a installation of the Operating system itself. However we can revert or restore back to last know good configuration mode.
How to start your computer by using the Last Known Good Configuration feature To start your computer by using the Last Known Good Configuration feature, follow these steps:
  1. Start your computer.
  2. When you see the "Please select the operating system to start" message, press the F8 key.
  3. When the Windows Advanced Options menu appears, use the ARROW keys to select Last Known Good Configuration (your most recent settings that worked), and then press ENTER.
  4. If you are running other operating systems on your computer, use the ARROW keys to select Microsoft Windows XP, and then press ENTER
Aug 18, 2011 | Computers & Internet
Factory reset la gard 3715 electronic safe
Welcome to FixYa.
How to reset or change your lock combination:
  • 1. Enter "zero" six times.
  • 2. Enter your existing six (6) digit combination one time. (or 123456, factory default if you haven't changed the combination yet.
  • 3. Enter your NEW six (6) digit combination two times.
  • 4. If a mistake is made wait thirty (30) seconds and repeat steps 1 - 3.
  • 5. Test lock operation several times before closing the door.
CAUTION: When selecting a combination do not use birthday or other predictable data that could give correlation between the user and combination.
• Valid Combination Entry - Double signal after valid six (6) digit combination is entered.
• Invalid Combination Entry - Triple signal indicates the old combination is still valid.
Thank you for using FixYa.
Have a great day.
Jas247
Aug 01, 2011 | Office Equipment & Supplies
I have a Daewoo DSL22V1WCD combined tv/dvd with built in freeview, our area is in the grasp of the digital switchover - everything I look at says I need to retune the tv - but this tv has various "sources"...
Press the DTV menu button (<<)
Press the Down arrow until you reach Settings
Press OK
Press the Down arrow until you reach Installation
Press OK
Press the Down arrow until you reach First Time Installation
Press OK
Aug 04, 2010 | Daewoo Televison & Video
I have Samsonite suitcase with the lock type B. When I used it last time, it was working. Now the code system doesn't work at all. I carefully followed the instruction to lock it but the code doesn't work,...
did you do this...
STEP 1 Turn the number dials to the previously set combination, or to "0-0-0", the factory default combination for Samsonite luggage.
STEP 2 Locate the reset button, usually placed to the side of the combination dials.
STEP 3 Press the reset button and hold it while rotating the number dials to the desired combination. Set this to a sequence easy for you to remember but hard for others to figure out.
STEP 4 Release the reset button after you set the numbers to the new combination.
STEP 5 Test the combination by turning the dials to the new code to open the lock.
if you did this then I'd contact Samsonite Customer Service at 800-765-2247.
Happy New Year
Jan 01, 2018 | Health & Beauty
Changed ink, cleaned cartridge area, turned printer on and off, still have an error code 1203. what is my next step?
Hi there can only try and I hope it will do the job for you.
Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
Or try
Reset Factory Defaults on the Dell™ 962 Printer
To reset factory defaults on the printer, perform the following steps:
  1. Press the Mode button several times until the Copy LED is lit.
  2. Press the Menu button until Set Defaults is displayed, then press the Select button.
  3. Press the right arrow button until Restore Factory Defaults is displayed, then press the Select button. The printer will ask for the date, time and language.
  4. Enter the time, date and language, the press the Select button.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 15, 2010 | Dell 962 Photo All-In-One InkJet Printer
Can I restore my Casio TE100 cash regiter to clear memory?
There are 2 methods to do the reset to TE100
Method 1
1. On Power
2. Key turn to OFF
3. Keep pressing [FEED]
4. Key turn to PGM
5. Release [FEED]
6. Key turn to REG
7. done
Method 2
1. Off the Power
2. Take out the "AA" size backup battery
3. On the Power
4. The machine is reset
5. Install back the AA batteries
6. Program back Date & Time
7. Done
Sep 27, 2009 | Casio Parts Cash Register PC Desktop
I was trying to install my new Di 524 and forget the keys
From the DLink website:
Reset to default settings print.gif The following reset procedure will completely restore the default settings on the router including your password.
Step 1 Locate the reset pinhole on the back of the unit.
Step 2 With the router powered on, press and hold the Reset button.
Step 3 Hold the Reset button for about 10 seconds.
Step 4 Release the Reset button.
Step 5 The device is now at factory defaults.
The default username is admin and leave the password blank.
http://support.dlink.com/supportfaq/
Mar 24, 2009 | D-Link AirPlus DI-524 Wireless Router
Computers & Internet Logo
64 people viewed this question
Alun Cox
David Payne
David Payne
