Question about Pentair MINIMAX NT TSI IGNITER
I have a minimax ch 150 heater and the heater is running but the water coming out is not as hot as it used to be. Though the heater is extremely hot on the outside. Any tips?
Check your SENSOR. With the Minimax ch heater, you might be using an 'IntelliTouch' panel that controls your equipment. If you are, check the reading that the panel says the water temperature is and then check the temperature of the water 'coming out' (spa??) manually with a floating thermometer. When the heater cycles off, check the difference between the 2 numbers. Say the panel says 102 & the thermometer says 95?? - that is a faulty sensor, telling the heater that the water has reached 102, so it cycles off before ever getting hot. If you're not using the IntelliTouch, you will be checking the display panel on the actual heater itself & again the floating thermometer. Now... if the temperature is less than a 4 degree difference you can always calibrate/or have calibrated the heater.
Posted on Aug 04, 2010
What would cause the return manifold get so hot it would melt? Water was running thru the manifold and was returning to the pool.
It sounds like the internal by-pass is stuck open, and is not forcing enough water through the heat exchange. The Hi-Limit switches should have shut off the heater before damage occurred, so you have more than one problem with this heater.
Sep 09, 2011 | Pentair Minimax Ch 250,000 Btu Natural Gas...
My heater will not shut off, i lower the thermosat and shut the switich off and it still run, water gets very hot, thank you
You cannot fix this as is ... You need to contact your pool supplier and get a new control panel for this heater.
May 30, 2011 | Pentair MiniMax CH Natural Gas Pool...
Heater Manifold Return Header Assembly 471991: I have water leaking from my minimax CH 200 heater...
This is likely a leaking heat exchanger. These usually fail due to improper water chemistry. This can happen in less than a year if the chemistry is messed up enough. Most culprits are putting chlorine tablets in the skimmer and running the pH or Total Alkalinity tooo low. HTH
May 17, 2010 | Pentair Heater Manifold Return Header...
Pentair MINIMAX NT TSI IGNITER Logo
208 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
