Question about Bosch Axxis WTL 5410 Electric Dryer
Cant find the model number on Bosch Axxis dryer to order new dryer vent
  • Bosch Master
  • 2,605 Answers
Welcome to FixYa.
I`m not sure what locations you`ve already tried, but typically it will be on a tag on the inside of the door.
If not there you should be able to revert to the back of the unit and there will be a white tag with a bar code and also model and serial number.
Let me know how you make out or, if you`ve already exhausted those typical locations you can try along either side of the unit.
I`ll watch for your reply. Good luck.
macmarkus :)
Posted on Aug 03, 2010
FILTER/VENTING HOSE LIGHT IS ON
Clean lint filter screen and area were it slides in
Axxis lint screens are very fine fabric softener will clog it up may need new one hot water for about 40 min unit may need complete clean out
Jul 02, 2015 | Bosch WTV76100US White Axxis Series Vented...
Dryer doesn't power-on.
Simple answer: way too much dryer lint. Worth cleaning out.
Mar 04, 2018 | Bosch Axxis WTA 3510 Electric Dryer
Bosch axxis dryer isn't drying well
what is your model number is then we can get started then
Jan 31, 2013 | Bosch Axxis Condenser Dryer- White
Looking for a replacement belt for a bosch axxis wta4400us dryer there don't seem to be links or parts lists readily available. Where can I find one?
The Belt you need for this machine, is the same one needed for a Danby DCD5505W Dryer. You can find a replacement belt at Repair Clinic, belt #669956, and you can also look-up a supplier using the mfg belt number (8PH 1930). The belt, with shipping is about $20.00
May 04, 2011 | Bosch WTA4400US WTA 4400 US Axxis Vented...
Asko stackable dryer/Bosch stackable washer compatability
If you arer going to replace the washer with a Bosch Axxis model, it will simply plug into the back of the dryer (if it is electric) because normally the dryers are 220 VAC. Works A-OK.
Nov 23, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Rat in dryer vent
You can most likely fet a diagram on sears.com. Go to the parts section and put in your model number and it will let you access diagrams.
Nov 20, 2008 | Bosch Axxis WTA 3510 Electric Dryer
My Bosch Condensation dryer (W2L 5400) won't heat up -- can't find the reset button
you need to remove the centre metal plate,after powering off the dryer. The small red reset button is on one of the black plactic connects on my model (WTA4408)
Feb 24, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Bosch Self Venting
If you're asking about the Condensation - No Venting Required feature:
I've had one for about 4 years with no complaints. I have used plenty of traditional dryers -- even models with moisture sensors. In all of them, it was common to find clothing that was "hot to the touch" when finished.
Every Bosch load finishes with a hint of moisture. I believe this is the Bosch "anti-wrinkle" standard -- but have never used one of their vented dryers. Even a 10 min fluff seems to add a hint of moisture to the load. Either way, you can't throw everything in the laundry basket and leave it for a week.
Europe is short on McMansions -- favoring tiny old homes without proper laundry rooms. Ventless is the norm -- rather than the exception over there. The Bosch works as advertised --producing a trace amount of ambient moisture and/or heat.
Mildew can be an issue -- depending on the dryer's location -- and the areas relative temperature / humidity.
Functions best in a fully climate controlled indoor location.
Dec 22, 2007 | Bosch Axxis WTA 3510 Electric Dryer
Bosch Dryer venting
i think you will find that one of these caps should be off and preferably connected to a vent hose to go outside the house. the reason they are blowing off is that the air has nowhere to go
Jun 26, 2007 | Bosch Axxis WTA 3510 Electric Dryer
Bosch Axxis WTL 5410 Electric Dryer Logo
311 people viewed this question
Top Bosch Dryers Experts
Marvin
Marvin
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
