My desktop computer has an opening right on top, for the air intake fan. Last night, my wife dropped her glass of water and unfortunately spilled right into that very opening. The CPU shut down almost immediately. I have tried using a hairdryer from a distance to dry out any moisture, so far it looks like it switches back on, all the lights running but it seems like there's nothing going on because there's nothing on the screen. I am no hardware expert so i'd like to know what's wrong though. I hope its an issue that could be dealt with ease. I am using Intel(R) Core (TM)2 6400 @2.13ghz 64 bit. Thank you, please advise.
  • 146 Answers
Check your internal fans to make sure they are spinning. Make sure memory is seated properly. Motherboard may also be in question. Try unplugging letting it sit for a few then plugging back in.
Posted on Aug 06, 2010
What would cause computer not to turn on when the power is loaded and the screen to stay black?
Im sorry about your situation.
Does the computer turn on??
If the computer turns on do you hear or can you see the fan working??
If the computer turns on does it stay on or does it shut down after a few minutes??
This will help us determine what is going on.
May 31, 2014 | Acer Computers & Internet
Tip
I take an old pair of hose (womens), buy some loose tobacco, cut the hose to...
I take an old pair of hose (womens), buy some loose tobacco, cut the hose to about 1 foot, 30cm long making sure there are no holes in the toe or elsewhere, put a 1/4 cup or so of tobacco into the sock, tie a knot so the tobacco stays put. Then open the bonnet of the car, find the windshield wiper water tank, drop the end of the sock into the solution or plain water, make sure the upper end of the sock is securely fastened to something outside the tank so you won't loose the bag you created and you'll be amazed at how clean the windscreen will be next time you use the wipers after squirting the windshield as usual.
An alternative would be to boil the sock in water like tea, but don't drink it! after 10 minutes of boiling, let it cool, squeeze the bag so all the "tobacco tea" goes into the pot. When cooled, pour it into your windscreen water tank. As you wash your windscreen with the wipers going the squirted liquid will clean the glass and make rain water sheet off rather than leave droplets. You can actually drive the car safely because you can see as if no rain was falling.
If your wipers stop working all together and you can't see to drive, take a sock, as the one I described above, get it wet and wipe the windscreen with it. The rain will then sheet off the glass as if there was no rain at all. no drops can form. The tobacco breaks the surface tension. Want proof? Take a glass of water, fill it to the top just short of spilling over. You'll notice the water actually rises above the edge drop one grain of tobacco or black pepper and the glass will immediately spill the water out of the top of the glass. I keep such a bag in a plastic bag under my seat. You never know when you might need it. You can use it many times before needing change the tobacco.
If you just want some cheap glass cleaner, mix a 50% solution of white vinegar and pour it in your window wiper water tank. It will keep your windscreen nice and clean; also streak free.
on Jun 14, 2010 | Kitchen Appliances - Others
Spilled water on ultra nova
Sounds ok to me. You might try to find some dessicant and put it in a box with the synthsizer.
Apr 10, 2014 | Novation UltraNova Synthesizer...
How to remove fan from gateway dx4200
for replacing the fan you must open computer case unplug all power cords, remove 4 screws near the rear fan and pull out the power supply from the top interior. then you have at leat more 4 screws to remove the power supply cover out. then you will see the other 4 screws to remove the fan. if you just simply want to clean the fan open the computer case go to outside, take an air compressor and blow air into the fan and at the rear od the power supply on the air intake and you are done.
Aug 26, 2012 | Gateway DX4200-09 PC Desktop
Hi, I spilled a large quantity of water on my HP dv7t laptop last night. It was a huge glass, and because of this the laptop just automatically shut off and i didn't even have time to turn it off. I...
I am assuming your motherboard is fried, but your Hard Drive is still OK. The laptop may not work anymore, but your files are more than likely recoverable.
Apr 17, 2011 | HP Pavilion DV7T 17" Laptop
I have an Amana side by side refrigerator. Last night I noticed water running from underneath and the ice cream in the freezer melting. I found dog hair clogging a vent and cleaned it. This morning the...
usually when the bottomof the freezer is cold and the top isn't it's the evap fan motor isn't working and all the cold air sits at the bottom.when you open the freezer door you should hear the fan running inside the freezer,also tried to look up your model but it didn't come up.open the fridge door,look up on the right and hear the cieling and you'll see a tag with the model and serial numbers,i just need the model number and i can help you better
Jan 30, 2011 | Amana ARSE66MB Side by Side Refrigerator
Why does my computer always shut down on me? It get hot, sure but i got a fan for it and it's really annoying! My brother's laptop never shuts down on him although it gets more hot than mine. Please Help!
This is long, and 'Windy', warning you in advance.
The cooling provided for the laptop is the air that is drawn in.
The air cools the hardware components inside, to keep them to a specific temperature.
(Thermal Limit)
A small fan is used to draw the air in, and then the air goes to the cooling components inside.
The air that is drawn in picks up all kinds of foreign debris.
Dirt, dust, lint, hair, and even food crumbs.
Even if you are the best housekeeper in the world, the above mentioned foreign debris always collects inside your computer.
This foreign debris clogs the fan, and the cooling components inside the computer. The cooling capacity drops tremendously.
When it does the Processor overheats, and turns off.
[It's a Fail-Safe feature to keep the Processor from burning up ]
For this reason the inside of the computer should be cleaned, on a regular basis as needed.
I state regular basis as needed, because environments vary.
Some computers because of the area they're in need to be cleaned more frequently, than others.
Desktop computer:
1) Computer unplugged from power
2) Computer on a table, computer case open, observe Anti-Static Precautions
3) Use a can of compressed air for computers, and clean out the inside of the computer.
Also clean out the inside of the Power Supply the best you can.
The can of compressed air for computers comes with a plastic 'straw'.
The straw is inserted into the can of air's nozzle, and the lock tab on top of the nozzle is removed.
(Used for shipping)
Start at the top inside of the computer on one side. Pick whichever side you want.
Squeeze the trigger in all the way, and go across.
When you reach the other side, let go of the trigger.
You will be spraying air like a painter uses a spray paint gun.
Now drop down a row, and spray across again.
How far you drop down is up to you. You can see how the air spray is working, and can judge accordingly.
Keep dropping down in rows until you reach the Processor Fan.
For the Processor Fan use Short Bursts.
Squeeze the trigger in all the way, then let go quickly.
You do Not want to spin the fan faster than it was designed for.
This can lead to premature failure of the fan's bearings.
After you're done with the Processor fan, keep going down in rows until you reach the bottom of the computer case.
Hold the computer case at the top with one hand, use the other hand for the can of air.
Tilt the top of the computer slightly towards you, and spray the bottom of the computer out
Laptop computer:
A) Laptop on, and running, observe where the air is drawn in. It may be drawn in on the side, or up from the bottom. The vented grille on this air opening is the Air Intake Duct.
You want this duct.
You Do Not want the Exhaust Duct. This is where the hot air comes out.
B) ALL power removed from the laptop. Remove the AC adapter (Charger), and Battery.
C) If the Air Intake Duct is on the bottom of the laptop, tilt, and hold the laptop up at an angle with one hand.
Use the other hand for the can of air.
Put the straw against the Air Intake Duct's grille opening, use Short Bursts of air.
(Again, you do not want to spin the Fan too fast. If you hear it go > Z-z-z-z-ing, it is spinning too fast)
After you are satisfied that it is clean, sit the laptop down, wait 10 minutes.
Then reinstall the Battery, (First), and then the AC adapter. (Charger)
If the Air Intake Duct is on the side, use Short Bursts of air until you are satisfied it is clean.
Follow the above.
Sometimes using a can of compressed air will not work. The foreign debris is clogged in there so tightly, that the can of air cannot remove it. A computer repair shop has to open the laptop, and physically remove it.
The term 'Laptop' is a fallacy, a joke, for some laptop models.
1) Your clothes,
2) Bedsheets, or blanket,
3) Directly on a couch,
4) On your lap,
5) Or sitting it directly on a carpet floor, will block the Air Intake Duct, and cause the laptop to overheat.
For laptops with the Air Intake Duct on the bottom, they should sit on a flat surface such as a table.
(Like a desktop computer. See the joke?)
Or on a hard flat surface on your lap.
You can use a cooling pad to help.
Example of a cooling pad,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4662503&CatId=3486
Some laptops have a poor cooling system. No matter how you treat the laptop it will overheat.
Laptops with an Intel processor, will run hotter than laptops with an AMD processor, before they turn off.
(And AMD processors run hotter than a comparable Intel! Sheesh!)
Just some ideas, and information. Don't shoot the messenger.
Regards,
joecoolvette
Nov 21, 2010 | Computers & Internet
My computer turn on and off contantly just stay 5 second on and then turn off same thing
THIS SHOULD HAPPEND WITH RAM PROBLEM REMOVE THE RAM ONCE AND CHECKOUT THE SLOTS ONCE CLEAN THE RAM WITH COTTON CLOTH THEN INSERT PROPERLY IF IT IS NOT WORKING TRY ON OTHER SLOT ON THIS ALSO IT IS NOT WORKING THEN YOU SHOUL CHANGE YOUR RAM
Jan 31, 2010 | Dell Dimension 2350 PC Desktop
Spilled some water on top ge micro wave while cleaning cabinets
YOUR BLOWER FAN MAY HAVE QUIT AND WITHOUT THE AIR CIRCULATION IT OVERHEATIND THE INTERNALS OF IT AND UNFORTUNATELY THIS UNIT WILL COST YOU MORE TO FIX THAN GETTING A NEW ONE. RED HOT IS VERY BAD ON A MICROWAVE
Apr 11, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Computers & Internet Logo
32 people viewed this question
Alun Cox
David Payne
David Payne
