Question about Dell Inspiron 6000 Notebook
Using Dragon Speak, 8: Blocked access due to, "Vocabulary General-Large is incompatible"???
I am very frustrated with DNS, version 8. After using same user name for over 1 yr. I now get a 'blocking' message, ""VOCABULARY you have chosen, General-Large is incompatible or invalid".to my knowledge I never changed any of the 'specs'. How do I correct this and avoid this from happening again?
ALSO- will DNS 8 work if I remove it from hard drive (C) on my laptop and put it onto its own portable flash drive? It takes up so-o much space on hard drive... How do I do this?
Thanks! (from a newbie)
If your computer is running kind of sluggish, you can fix it with an easy clean up of your registry. Here's a link to a free scan that works well:
www.your-free-info.com/RegCure
I've used this one and it sped up my computer by quite a bit. Hopefully this helps.
Posted on May 10, 2008
  • 3,940 Answers
The issue is likely caused by a Windows System Restore. You have a couple options to resolve. If you backed up your user training files, restore them, if not, then Create a new user training profile. CLICK HERE for easy-to-follow directions for creating a new user training profile.
As for installing it to a USB drive, I'm not sure, but the application make numerous writes to the windows registry, so I would not recommend installing to a removable drive.
Siri doesn't understand a word I ask while using Bluetooth. And dictating through Bluetooth is slow to start and full of mistakes. Help.
Do you speak slowly and clearly so the app can understand your vocal implications, it needs to learn your voice characteristics.
Nov 27, 2016 | Cell Phones
Lookup serial number
The key might be on the manual or the box if its not on the cd.
Dragon Naturally Speaking is a software program designed by Nuance Communications that enables a user to speak instead of type to both transcribe information and control his computer. This is beneficial if you don't like typing or physically cannot do it.
The software requires a headset microphone to work and some configuration to get started. To continue using Dragon Naturally Speaking, you must register it or it disables itself.
Activation is done online and requires a product serial number.
The location of the serial number varies depending on the software version, but it should be located on the box, CD case or manual.
Start Dragon Naturally Speaking.
When it completes the loading process, click "Activate Now" when prompted and then click "Activate Automatically."
Enter the serial number in the space provided and click "Generate Activation Key."
Copy the activation key into the activation text box and click "OK" to activate Dragon Naturally Speaking.
How to activate Dragon NaturallySpeaking without an Internet connection
http://www.spectronicsinoz.com/article/how-to-activate-dragon-naturallyspeaking-without-an-internet-connection
Apr 25, 2013 | Nuance Dragon Naturally Speaking 11 Home
I want to get my youtube unblocked at work. do you know a site thats works?
This depends on how your IT dept has blocked access (there are many ways of blocking site/content/IP access). Try the below (I am assuming you are using Windows XP as your OS)
(all of these when you are at work, not sure if you are using a desktop or laptop)
1. Open command prompt and check ipconfig /all (note down the IP for your DNS servers; you should have at least 1 if not two. Make sure you note down the first IP)2. Go to network connections (from Control Panel), if you are using LAN (using an ethernet cable) then go to Local Area Connection properties or if you are using Wireless then go to Wireless Network Connection properties3. Under general tab, select Internet Protocol (TCP/IP) & click on properties4. Under general tab, below you'll find an option 'use the below DNS server address' - select this option5. Under preffered DNS server add 4.2.2.26. Under Alternate DNS server add the IP address you noted in step #17. Restart your system and try using Youtube
Hope this helps. Sorry, if the steps were too detailed out.
Oct 07, 2010 | Computers & Internet
I can't access via browser to the Digia II because appears the message: "Please check the Digia2.ocx installation. Current version is 1.0.0.70. I'm using Internet Expplorer 8.
I can't access via browser to the Digia II because appears the message: 'Please check the Digia2.ocx installation. Current version is 1.0.0.61.I'm using Internet Expplorer SP2
Jun 24, 2010 | General Electric GE Security Digia II DVR
Syncing Sony ICD-MX20 with Dragon Naturally Speaking 10 on Vista
the workaround seems to be
buy an Olympus recorder (supposedly they issued a patch for DNS 10 in a couple of days)
or
tell DNS that the source is a PDA generating WAV, MP3, etc.
havn't tried this myself yet. some say it it isn't that awful. But I too am very dissappointed.
Mar 14, 2010 | Sony ICD-MX20 Digital Voice Recorder
Recently I purchased the Dragon Naturally Speaking 10. It works very well on straight dictation. However, I cannot seem to load my recordings from the Olympus VN-3100 PC unto the Dragon Speaking. Any...
There are several "flavours" of DNS 10, and only the Preferred and Professional versions will allow you to submit a pre-recorded sound for recognition (from the Sound menu). If you have a lower version such as the Standard, you will need to upgrade to at least Preferred.
I hope this helps
Jun 26, 2009 | Olympus VN-3100PC Digital Voice Recorder
Error81003005
See below
Hope this helps
Here's how I solve it:
1. Open your Internet Explorer
2. Go to Tools > Internet Options then click the Connections tab
3.Click the LAN Settings button and a new dialog box will open
4. At the new dialog box, look for the Proxy server checkbox, if this is checked, uncheck it.
5. Then your done, click OK button for the dialog boxes.
6. Try logging in to your Yahoo Messenger account.
My solution is good only if you have set your proxy server previously in your Internet Explorer. I've noticed this behaviour since in our school, I need to set the proxy server to access the internet. But at home, I don't need to. So when I am at home, this is the normal situation I encounter when I forget to unset back the proxy settings.
On the other hand, the other way around should work. What I mean here is, if you connect to a network that has a proxy server, you need to setup the proxy settings in order for you to use their internet services. Thus, access to yahoo could be established.
[Solution #2]
One area to look also if the proxy is not the one causing the problem, you can check if you have your DNS Server address(es) set, which - in case you have changed your network, can't be accessible to the new network. Thus, it can cause this error.
So, you may unset the DNS Servers (Go to Network Properties >> General Tab >> TCP/IP Properties >> General Tab > Obtain DNS Server address automatically) and try logging in your YM.
[Solution #3]
If the above solutions does not go well, this last one might be the savior. Instead of constantly banging your heads with those re-logins and reconfigurations, you can track back your YM version and replace it with an old version instead. I did this and it works for me well. I had before a version 9 Yahoo Messenger and when I replace it with a version 8, the problem was solved. This should be your last resort if the previous won't work. Remember also to be patient. If it bugs you, don't bug down... bug up!
Dec 30, 2008 | Computers & Internet
Setup Problems/Can't Downolad Files
did u find a solution? it has been 6 months since u posted..... does anyone know the solution as i have the same problem....
May 02, 2007 | Sony ICD-MX20 Digital Voice Recorder
Dell Inspiron 6000 Notebook Logo
89 people viewed this question
Alun Cox
